What is the lumens per emitter at 150mA? You say it’s identical for both 2700K and 5000k? This can’t be the case, can it? It seems like warm emitters are always more inefficient since the phosphor layer is thicker?
Correct for optical losses and higher temperature and you’re in the same ballpark but higher colour rendering and rosier.
BTW, I’ve notice a Refond “Sunfeel” mentioned in the catalogue with nicely looking spectrum but I fail to find any details.
https://www.tme.eu/Document/297bac1c849d293b517ecf72110c4a89/catalouge-REFOND.pdf
Does anyone know more about them?
Yeah I’m not so sure about this project. The LT1 emitters are already pretty nice. The uneven glare is a bit annoying though.
When I proposed this I expected the benefits would be:
- Cooler head temperature
- Slightly brighter
- Better colour rendering
- Smoother beam
It looks like the head temperature might not be cooler and the brightness increase wouldn’t be too substantial.
I’m not sure about the stock tint of the light. It might get a bit rosier? I’ve never thought of my LT1 as being green so it’s not an improvement imo
Wrong
It will be about 600lm, not 1000. I mean with diffuser
BTW, I never use my LT1 above 2700K. I’d like to go warmer.
I’d like to have some cooler spectrum as well because I’d like the candle mode to vary CCT.
But for this to happen without going above 2700K I need some warmer LEDs. So unless I find something warmer it looks like 2700K at both channels would be the best choice for me…
I have a feeling that kapton converters from 7135 to E21A footprint would be a bad idea….but an entertaining one.
Warmer would be nice but it seems like we don’t have that option unless we find some different LEDs. My guess is that the diffuser should affect the LH351Ds and threes 2835 SOL emitters the same so brightness should be close if not higher with the sunlike emitters.
There was the LH351B in 2200K a while back, but it’s only 80 CRI.
I am interested in one.
2700K + 5000K is ok, but my ideal combination would probably be 2000K + 4000K.
Luminus Cube and Nichia E17A and E21A are available in some warmer color temperatures.
The Nichia are available through Eurekatronix, although that probably affects the cost.
The Luminus are available in a 2016 package (2.0mm x 1.6mm) and a 3030 package and may be easier to solder than the Nichias, which are chip scale package.
Add me for one. Thank you.
I think I will add this board to my site, customers will place an order after that I will give paypal from my business partner from China for payment. After 10+ payments I will order this flashlight. After I received (seems like 2-3 month) it I will finalized project and give it to the factory and after 1.5-2 month I will received 100-150pcbs and stencil
All done! Who need this pcb, just place order HERE and I will send paypal account for payment (with 5% fee)
It is possible to place order without registration, and there’s english language with button on the top
I think that will be better to add this to head comment
As you can see, way to speed up the project is send flashlight to me faster that Sofirn Official Store from aliexpress.
It will be 18+18 leds. I can soldering not all
And who want more warm spectrum, the 1 way to get it, it it is order 10-20k pcs 2835 leds in the factory or add 660nm. But red leds is 2.2v, so I need to test how it will work. Now I have spectrometer PG200N, so I can test ready pcbs with leds better that anyone without it
s. Do not spend my time anymore please. The only way why I do it, it is money! Yes, I like flashlights, but I can spend my time to creating head flashlight with 12w SunLike COB 36v LED (I still waiting leds from Seoul)
pps. 14.8$ (2.5+1.5+10.8) + 6$ (shipping for any order) + 5% paypal fee
Interested in one also.
Hi Lampman, I made the order and asked for Paypal in a reply mail. Nice initiative, thanks Sunnysunsun and Lampman!
Check spam folder. Fu…ing gmail =(
paypal is: 50380707[d0g]qq.com
add paypal fee 5%
add mark: for Adam for BLF LT1 pcb order#
Done
Good luck with the work!
Thanks! You’re first who payed =)
Red should be possible without any problems. The AMC7135s will drop down the voltage and feed them a constant current.
I will make an order once I sort out the address I will be at in a few months time.
Is there a reason for 18+18 instead of the evenness of 20+20? Is it space needed for pcb trace routing?
yes, from out - and from +
so, 18+18 it is maximum
They will be MUCH brighter?
Do you know when these will become available?
Do you have any data to compare to the 2nd generation SOL2835?
Id assume they will be more efficient at the same current (Higher flux BIN/higher lumen per watt).
If that’s the case, Id rather wait for the 3rd gen SOL2838 to justify the emitter swap and proposed higher efficiency.
First, need to raise money at all to start this project. And after pcbs are ready, it will be very easy to solder any other LEDs there. But at this rate of raising money, I suspect that the 5th generation will come out before the boards will be ready…
