Convoy designed me (us) a hunting flashlight (L21B)
Simon has a sample but there’s an issue with the reflector so have to wait
Was this released?
my two cents is that it should have little to no grip. A bumpy grip for me means it’s harder to wipe down and get clean. If I need any grip I slap some hockey tape on it which is easy to remove.
I have a couple samples and it performs incredibly well. The issue that needs to be corrected is very poor focus, the reflector needs lifting higher when using the Osram LEDs. Simon is waiting for some final measurements from me before ordering new thicker gaskets.
I haven’t tested the CULPM1 yet, but below are the range measurements I get using the CSLNM1
Red - 820m
Green - 1,674m
Body diameter ended up being 26mm instead of 27mm which I absolutely love since it’ll still fit most 25.4mm mounting brackets. I hope Simon gets into making lighter weight models because there’ll be many who’d prefer them. The L21A is better for heat dissipation, but felt quite bulky, this L21B is only 210g vs 354g. I just wish he’d get a little more creative with the naming as I’m sure many potential customers would be put off from the confusion. I mean there’s the C8+ and the 21700 version is called the M21A, how confusing is that
It’s really decent. This will give all hunting brands out there a real run for their money.
Could you show us this sample? Next to the L21A and C8+/M21A?
Is it available from Simon?
I mean, the prices in your store are a bit high compared to Simon
Prices are very high if you’re looking at them in usd, but it’s nzd :slight_smile: although I still need to make a living somehow
New Zealand customers only as exporting is problematic. I give lifetime upgrades and free labour on repairs after 1 yr warranty to make the prices worth it
The focus is bad without height adjustment of the reflector and so I’ve told Simon the thickness gasket of what’s needed.
Oh and btw, I don’t just resell as is, I install dual springs, align LED, tighten screws and retaining rings, and clean all contacts
Ah, thanks for the explanation, forgot that its NZ$ which is obvious different than US$.
No need to excuse, i understand that its part of your business and you have to make a living.
Was just hoping that BLF enthusiasts can buy it from Simon, since most of us are familiar with Convoy and modding.
Just flick Simon a message and ask for it :slight_smile: he has them ready, but just with the focus issue.
First look at the performance using the Osram CSLNM1 Red
Would you be able to do a store demo of L21B STF40 VS Osram?
I don’t have the SFT40 to be able. I might get one, but unsure as most love a gun light to be a very narrow beam like the Osram cslnm1 and culpm1.
My customers are mainly those needing 600+ meters for deer
I definitely understand. we wouldn’t want the spill from the light to disable, distance vision. Poaching must be minimal out there. Most state’s here, if you have a rifle and a good light at night, Someone will investigate you.
oh boy
I have the C8 (which i use for hunting, with the remote tail cap), and also the L21A.
This L21B sounds perfect as an upgrade to the C8. Can you confirm if it fits the weapon mount “Olight X-WM03” ?
I am curious Funtastic, can you guys “legally” hunt deer at night in New Zeland??
It’s 26mm so it’ll fit even if it can’t clamp in all the way.
This needs some major adjustments though for the Osram LEDs, but okay for the Luminus SFT40.
The focus is way out and the reflector needs lifting up. I’ve been modding these for my store and they’ve been selling like crazy. I made $1500 in two days, that’s usually 1 month of sales right there.
You can’t use the 8A Convoy driver since it doesn’t have a positive spring so you’ll dent in the batteries from the recoil and possibly damage the driver over time. Okay as a handheld though.
Pressure switches are in production.
Check out my YouTube videos of the Osram culpm1, cslnm1, and green, red
If you have a bit of modding experience you can turn this into the best budget gun light available
I don’t personally, but yes, very much so
Good info, thank you. :white_check_mark:
