Yeah, there fun little things. I’m surprised how durable they are.
Great for real beginners like me. I would not have wanted to treat a more expensive drone the way I’ve treated this one! The camera can rather easily be moved but to keep weight down on these real cheapo things they have to be hacked up pretty good.
I made another… same weight as the the other before cutting it up:
I cut this this one up even more and managed to lower overall weight with 1.2 grams.
I tinkered a bit with Convoy’s 12V 2,5A GT-FC40 driver. I changed it to 6V output and adjusted boost converters input limit to higher value. It was limited to 10A, but MP3431 boost converter should handle higher. I also changed bigger 1R5 valued inductor to it from broken Convoy driver. With 6,7 mOhm current sense resistor mine gives an output of 6,2A and draws 12A from battery. This with battery voltage of 4,1.
I haven’t done anything with my flashlights anymore for several months, but today I added aux leds to my edc FWAA. Due to the fact that attiny85 sits inside, there is only one color - ice blue, but I think that’s enough for me. imgur gallery
I also finished a mod for a friend recently. He saw it at Vinh’s and wanted it too. 7x xhp50.2 5000k mule.
Apart from the auxes, I also added a blue GITD tape to the inner wall. I think it was a good idea. imgur gallery
Just for fun to see what would happen and get some practical experience with flashlight modding; Convoy L2 with B35AM. Maybe a high CRI thrower.
I’m considering this a work in progress. Some practical limitations, such as no OP reflector available and unfortunately no 2 cell 6V driver (used the 20mm Convoy B35AM driver). The dedicated B35AM gasket is just too small for the reflector hole, so had to use a unknown gasket that was much thicker, but fits (possibly XP). Also the stock L2 tail button is not suitable for controlling it. Need to find a replacement for that. But I’m was pleasantly surprised by the beamshot. Was expecting something floodier, but it actually shoots out pretty straight. It throws further than the DM11 with B35AM. But up close there are rings that I would like to get rid off, just don’t know the cause.
@Verodin, I believe those rings could be reduced by a flatter, more shallow gasket. The emmitter just needs to be level with the base reflecting surface of the reflector. It really isn't that bad and the beam is nice. The color comes from the lens anti-reflective coating.
