I havenāt actually modded anything, but I have assembled 4 - LH351D 4000K LEDs on an mcpcb, a led4power LD-A4 driver, a Li-po 3700mAh cell, a switch, a 2 amp TP4056 charger and USB-C port plus a Convoy S2 pill and some copper pieces, into a test configuration for a light I am thinking about making.
Canāt wait to see what that is going into Don.
I made this the other day. 12V 2A wall wart power with dimmer and 4 12V LEDs to light up a MCM Spaghetti globe.
Final sanding and finish put on it today. Xmas giftā¦ the lighted stand.
Still unfinished.
Cool! I havenāt seen a spaghetti globe in a while. Itāll be nice with the dimmer.
It might take a while to complete my project, there are other things higher up the priority list. Plus now I need to complete the ways of carrying out the idea I have and turn it into something other than some parts that I have shown actually do work.
Not a flashlight mod but a mod none the less.
I took an old feit 9w led bulb and replaced the original some 2835 leds with some 5000k and 4000k Bridgelux Thrive 2835s. I alternated between 5000k and 4000k trying to get 4500k.
I didnāt take any before measurements with the Opple since I just received it and I had already had taken the bulb apart and was too eager to start reflowing some leds.
Overall Iām pretty happy with the CCT and obviously the CRI is great. I was hoping the tint wouldāve been closer to the BBL, but it only cost about $2.50 and less than an hour of my time. So, in the end it was definitely worth it.
Before shot
After shot
I spent many many hours filing, sanding, and polishing a cheapo AA flashlight in order to reuse a 5700K 519A LED that came with a Convoy S2+. I purchased the MAO S2+ with the intension of converting it into a triple dedomed 5000K 519A and it turned out great.
I made a makeshift lathe using a portable drill, a large drill bit, and plenty of tape. I think the host turned out pretty darn good. I added another hole for the lanyard so it will be able to tail stand.
The worse part of trying to use the cheapo AA flashlight as a host is the pressed in driver retaining ring. Itās not reusable and was very difficult to remove. So I took an S2+ retaining ring and added solder to the perimeter. Then screwed it back and forth onto the head along with some oil to cut new threads. Now Iāll be able to use it to secure the new copper (cap) pill and the driver that came with the S2+.
I just ordered the lens, reflector, silicone switch cover, etc. from Kaidomain so will have to patiently wait until the parts arrive.
New host bottom and right:
Damn, lotta work and looks good.
YinDing 5050 in a S11
Surprisingly intense beam for only 3A
I used a leftover 3A qlite driver.
Damn, thatās a nice tight beam for a tubelight.
T3 519A 5000K (dedome + 60 TIR) getting 3600-3750K (had to file down the TIR to fit the T3)
It's little to long like 0.1mm or so, to screw it down all the way, but there's an o-ring, so there shouldn't be a problem with water
WB 5000K, 1/60s, ISO50, f1.8
And teaser (I will try to finish it soon, for now it's a test fit, and it fit perfect)
innovative rotary design, you can change the brightness, and tint, by screwing in different bulb
very nice floody beam
do you have Opple data for Tint DUV?
100% center 3622K Duv -0.0032 97Ra
100% side 3707K Duv -0.0039 96.5Ra
20% center 3726K Duv -0.0040 97.3Ra
20% side 3833K Duv -0.0054 97.4Ra
20% near opple, center 3606K Duv -0.0031 97.3Ra
20% near opple, side 3676K Duv -0.0037 Ra 97.1
thanks
your pic looks so much more rose colored
than mine at DUV ā0.0042:
did you lock the white balance? at what value?
I don't remember if the picture was on, 100% or 20%. It could be 20%. so it's Duv -0.0040 center to Duv -0.0054 sides, and my wall is white...
noā¦
I have an iPhone w auto white balanceā¦
that is why I take the photo during daylight when the CCT is about 5300K and the Tint DUV is about 0.0032
I dont know if your photo would look like mine, if you took it at the same time of dayā¦ that is why I think it is helpful to compare Opple numbersā¦ they bypass photo WB differences.
anywayā¦ just pointing out how much photos can varyā¦ I do think it is great that you can lock WBā¦ your pic looks greatā¦
I didn't bother to take out the MPCB, I just cover it...
Soldering, with my FWAA CU in hand. You can tell, it's my 5 time soldering anything.
Isolation (it was sparking :D) didn't bother to heat shrink it.
parasitic drain is 256ĀµA
moonlight mode is 30mA (and it's working)
next mode is full brightness all the time, on any ramp mode 850/1400mA (depending if with 3W, or 6W bulb)
Strobe, battery check and so on, works ok.
The only problem is with the 6W bulb, as when screwed it, it's always in moon mode, you can't turn the flashlight off (the 3W bulb works fine, you can turn it on, and off)
No bad PWM (on any mode)
A lot less innovative on my side :
Convoy M2
SFT40 emitter & OP reflector
and ātacticalā forward switch (instead of the factory reverse clicky), you can see I got some trouble to get it working as I melted the first switch during soldering and had to āshaveā the rubber boot because the forward switch is taller than the factory one
(but it works, and I am really happy)
I removed 1 of the 7135 driver chips in my S2+ Nichia UV flashlight to make it less bright.
Few weeks back I modified Maglite ML25LT with better led. I used Samsung LH351D, because itās dome is somewhat diffused in hopes of cleaner beam with stock reflector. It was a real hurdle to disassemble this light. No parts that you usually find in led flashlights, but I managed to pull it through. Vastly improved light that is safe to give to kids.
Beamshot ~6m away
And another one, same 519A, 3500K. AceBeam Raider RX
Any advice on how to get this disassembled? I canāt get access to the MCPCB. Everything past the driver is a no-go for me.
if you take the pill out, the front blue bezel is rightly-loosey
