40 metre beamshots - Lots of large pictures
67 posts / 0 new
Don
Don's picture
I had a nice break in a very peaceful place. One nice thing about being so far from the road is that you couldn't hear the traffic. Here's the assistant checking out the little remaining icy snow.
Assistant
I took a few lights (126 of them to be precise)
126 lights
Checked out some of the wildlife - red squirrels are seriously endangered here - someone imported American grey squirrels in the nineteenth century and they are displacing the reds. They carry squirrel-pox which is fatal to reds and harmless to greys. In my city the greys have displaced the reds in the last twenty years - in the shire they are feeding contraceptives to every grey squirrel they can find.
Squiddle
But enough of "What I done on my vacation"
I tried for some 385 metre (1250 feet) beamshots but the camera's sensor refused to pick up hotspots I could see clearly.
This was the first test range. The green firs are 385 metres away according to Google Earth. The river Don (Which is as high as I've ever seen it) is between the first two power poles.
test 1
Here's the little tripod arrangement I used to hold the lights on target. It turned out to be too floppy for the job.
mini tripod
Anyway, here's a result from one of my most powerful lights, the EastwardYJ J06 with an XM-L. The third power pole is roughly 200m away. I could clearly see the hotspot on the trees at 385m but ever-increasing exposures didn't help.
EastwardYJ J06 385m
So I gave up on that approach and moved off into the trees. I found a nice fire-break. The branch on the ground with the faint red writing on it is a measured 40 metres (130 feet).
40 metre target
So on to the shots - there was little moon and the nights were clear and very cold. The nearest light pollution is around 25km away.
Control - not a lot of light. I found my Zebralight H50 on low (around 3 lumens) was perfectly adequate for taking notes of which shot was which - and in fact for wandering through the forest.
Control
So here's what 66 lumens, the H50 on high (With a lithium AA primary) looked like on the test range. The exposure was set for the much more powerful lights. It is not a thrower, nor is it intended to be. You can see that what beam there is is wider than the camera's field of view.
Zebralight
Varapower 2000 (SST-90 driven hard) on maximum - measured at over 1500 lumens. 4C NiMH in a 3D body.
Varapower 2000
You can clearly see the branch at 40 metres and the point where the ridge drops away at around 55 metres (180 feet)
KD RQ Raidfire Spear clone on high (Cree XR-E Q5 or R2). You can clearly see the pencil beam of the dedicated thrower - and the almost complete lack of spill. This is the throwiest light I have. Its output is not enormous but it'll push that pencil spot for over 1000 feet. If I don't say otherwise, all these lights are single 18650s.
RQ high
Lumapower MRV High (Again an XR-E - a Q5 I think)
MRV
Fusion 36 dropin in a Mag 3D (Running 3D NiMH). I didn't find this one too useful for huge black dog spotting amongst the trees or on open ground - the throwers did it a lot better in the open ground (Usually the HS-802) and the LT3 on level 1 or 2 amongst the trees.
Fusion 36
Piritlight SG-L8 high. Yet another Raidfire Spear clone - this one with an MC-E in it making about 550 lumens. It doesn't throw as well as the RQ but puts out a lot more light.
Romisen RC-T6 High - 6xXR-E Q5 (Or Q3 or something). Mine does around 840 lumens from memory. Throws out to about 35 metres. 2x18650
Romisen RC-T6 High
Solarforce Skyline 1 - Yet another XR-E thrower - a bit underpowered. This is with two CR123 primaries. Again a typical thrower with little or no spill.
EastwardYJ J06 (Cree XM-L T6)
EastwardYJ J06
Uniquefire HS-802  with an XM-L T6 and a 3A driver. The LED is mounted off-centre, well nobody ever accused me of being a neat worker.
Uniquefire HS-802 XM-L T6 Mod
Romisen RC-T5 4x Cree XR-E Qsomething 2x18650
RC-T5
Aurora AK-P7 High - this was my first P7 light and is still pretty respectable in output (around 430lumens)
Aurora AK-P7 High
Yezl S5 Cree XP-G R5 14500 high. A nice light, but it gets too hot. It is the same body as the Trustfire F22 which is a better balanced light - and I still miss mine...
Yezl S5 High
My only XP-G R4 dropin. It used to be a five-mode but it turned out not to be capable of handling 8.4V and is now a single mode.
XP-G R4
DX P7 dropin, high. This is the $23.49 one they've been selling since the P7 appeared.
DX P7 High
M bin MC-E dropin high - this one is bright, the brightest MC-E I have.
MC-E M bin
Mr.Lite J4 XM-L and reflector mod. High. 14500
J4
Golston 7W. A Chinese Lixeon 3 clone LED. Crazy bright in its time, 5-6 years ago. Runs on two 16340's. There are lots and lots of clones of this one around. Some claimed as much as 18W output.
Golston
Manafont XM-L T6 dropin high.
T6
Ultrafire C303 High. XP-G R5
C303
Aurora SH-034 High. 16340. Probably the best-made light of all the ones I own. Cree XR-E R2
SH-034
Mr.Lite LT3 Mode 5 (XP-G R5 16340)
LT3
Romisen RC-C6 zoomie at high full zoom (16340)
zoomie
Romisen RC-C6 full flood - this one is an XR-E Q3
wide
Aurora SH-032 High
SH-032
Ultrafire RL-118 - An Osram running on a 16340
RL-118
Trustfire R5-A3 from the first batch with the silly high "low" level/ 14500/XP-G R5 high
R5-A3
Ultrafire C3 R5 14500
C3 R5
KD XM-L T6 dropin high
KD XM-L T6
Trustfire TR-801 with the TIR optic from a Mr.Lite J4.
TR-801
Trustfire Z1 high (16340 - Cree XP-E)
Z1
I can do the mediums and lows if anyone wants them.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Edited by: sb56637 on 08/26/2014 - 17:02
pounder
pounder's picture
nice Don!
man the xml drop-ins are awesome in that setting..is your kd drop-in still with the OP reflector?
Don
Don's picture
pounder wrote:
nice Don!
Pity I hadn't made the exposure shorter, this just shows that pretty much all of them can do 40 metres.
It's completely stock apart from a KD coated lens instead of the original one that came with the body.
sb56637
sb56637's picture
Last seen: 19 hours 2 min ago
Wow! Impressive selection of shots here, Don. That must have been a lot of fun. And a lot of work too in order to take so many controlled shots.
This post is going sticky. Thanks for your time on this!
motodeficient
Last seen: 5 years 7 months ago
Great post really enjoyed looking at those beamshots. Thanks for posting them. The XMLs really just put out a ton of light, huge spill and still pretty good throw. I love using my nailbender XML/L2P light, but have to admit I have more fun with my MPP-1/L2. That thing just throws like crazy.
Don
Don's picture
I reckon that throw is a lot less of an issue after 600 lumens which all the XM-Ls can hit with ease. In what is essentially a tunnel between the trees, they are actually too bright - the 3 lumens from a Zebralight H50 on low was plenty. Much over 100 lumens in that sort of environment just dazzles you. Though I must confess to having a huge grin and a 1500 lumen light with me as the assistant and I wandered through those trees at night.
pounder
pounder's picture
Don wrote:
pounder wrote:
nice Don!
yeah 40 meters for sure..I use a smooth reflector on my kd and it turned it into a pretty good thrower with a defined hotspot..much like the manafont beam profile..worthy upgrade..
Essexman
Last seen: 6 days 23 hours ago
Don - Thanks for all your hard work, I really enjoyed reading that, cheers
Don
Don's picture
It was actually fun to do, if a bit chilly. I need to find a slightly longer range area though, for those lights 55 metres wasn't enough. I've never had much luck with beamshots with my DSLR but need to give it another try the next time I'm up there.
Which will be after I fix my exhaust.
jb1
Last seen: 1 day 6 hours ago
Wow Don, thanks for all the beamshots/work. For those of us with little to no collection of lights, this helps out a lot. What host are you using for the Manafont XM-L drop-in?
how2
Last seen: 4 hours 19 min ago
Nice shoots Don.
Can you re-roder then with the Xm-L ,xpg and xre etc.
fishinfool
fishinfool's picture
Thanks Don!  I'm glad you and the assistant are having lots of fun.  That area reminds me a lot of Alaska but with a whole lot less snow.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Don
Don's picture
Solarforce L2m with a KD coated glass lens. If you've had the light a while, the coated lens gives you something like two brightness bins increase in light output. Just cleaning the plain glass one gave something like a bin's worth of increased output.
jb1
Thanks pal. Wanna guess what I'm ordering when I get home from work?  Laughing
Don
Don's picture
how2 wrote:
Nice shoots Don.
Can do, quite easily.
XM-L lights
EastwardYJ J06
J06
Uniquefire HS-802 XM-L 3A driver
HS-802
KD XM-L T6 dropin
KD Dropin
Manafont dropin
Mr.Lite J4 XM-L mod (14500)
J4
XP-G Lights
Ultrafire C3 R5 (14500)
C3
Mr.Lite LT3 (16340)
lt3
Ultrafire C303
C303
Yezl S5 (14500)
S5
Trustfire R5-A3
r5a3
R4 P60 dropin
r4
MC-E Lights
Piritlight SG-L8
L8
M-bin MC-E dropin
dropin
P7 Lights
Aurora AK-P7
P7
DX P7 dropin
DX P7
XR-E Lights
Aurora SH-032
32
Aurora SH-034 (16340)
34
Trustfire TR-801
801
Romisen RC-C6 Zoom
zoom
Romisen RC-C6 Flood
flood
Romisen RC-T5 (2x18650)
t5
Romisen RC-T6 (2x18650)
t6
1
MRV
mrv
RQ
rq
Zebralight H50
h50
SST90 LED
Varapower 2000
varapower
XP-E LED
Trustfire Z1
z1
Osram LED
Ultrafire RL-118
rl118
Chinese Luxeon 3 clone
Golston 7W
golston
36 Nichia GS 5mm LEDs in a Fusion 36 Mag dropin
showerhead
how2
Thanks Don
FlashPilot
FlashPilot's picture
Last seen: 1 hour 34 min ago
126 lights
Welcome back Don! Its a good thing that you brought along only a small portion of your flashlight collection, or else your car might have bottomed out from all the extra weight! There's nothing better than being able to use flashlights out in the woods and away from the ambient city light. Its quite obvious that you had a lot of fun with them. Thanks for the great pics. The Manafont XM-L dropin sure puts out an unbelievable amount of light for a P60.
mizjif
mizjif's picture
Last seen: 10 hours 43 min ago
Huge thanks Don for the awesome shots. They really put into perspective how powerful some of those lights are, especially the xm-l's. This will be a very handy reference. Muchly appreciated:)
SecaRob
Last seen: 3 years 1 month ago
Don,  is that Manafont sku# 5720 ?   How/what are you running it in?
I think I am going to have to get one of those
Don,  also thank you very much.  Your pictures are indeed a great point of reference for these lights
jb1
So while we're in the question asking phase of this thread Laughing, do you have the sku for the coated lens at KD? I'll owe you a beamshot with Texas coyotes in it.
pounder
pounder's picture
yes that is the bright one..the hi, mid, strobe one is crap..
Don
Don's picture
Yes, that's the one. Fed with a single 18650. Pity it isn't 8.4V capable for use with 2 18650s for better runtime. It's put in a Uniquefire L2 (Solarforce L2 clone) or a Solarforce L2m. Wrapped with enough foil to make it difficult to shove the dropin into the head - I use the head threads to force the dropin into place.
Don
Don's picture
Sounds good.
Can't remember offhand but I got the link from here.
I'm pretty sure it is 28mm in diameter and I know they were $2.99 each so I think it is this one.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1766
SashiX
SashiX's picture
Last seen: 7 years 2 months ago
Excellent shots, Don. Looks like Eastward J06 and Manafont XM-L droppin are the winers, a lot of light Shocked
Don
Don's picture
Combined, they don't make as many lumens as the Varapower. But throw a bit better.
Vectrex
Vectrex's picture
Last seen: 5 months 1 day ago
Nice pics Don. I wanted to try out that mouse in/out function for a long time on the 2 XML dropins.
This is the perfect opportunity. Hover with the mouse in or outside the pic below for comparision.
Mouse out= KD
Mouse in = Manafont
KD dropin (mouse out) vs Manafont dropin (in)
pounder
pounder's picture
wow after seeing the beamshots the kd looks depressing vs that manafont..Don what is your kd drawing on high? I know your manafont is 3.4a..just asking because my kd is drawing 3.2~3.3a with the cell I have in it..just wondering if they're drawing the same where the difference would be coming from? efficiency?
jb1
Vectrex, that's a really cool feature. I opened up 3 windows and looked at the 2 XM-Ls and the Varapower. Old school.   LOL
fishinfool
Mouse out= KD
Mouse in = Manafont
After seeing this I had to double check and see whether I ordered from KD or MF.
Whew!  Manafont it was. Smile
SashiX
SashiX's picture
Yeah, but not price vs. power Silly XML will be my next light for sure Cash
BTW, Vectrex, very cool hover feature Shocked I think this is the best way to compare two images.
Vectrex
Vectrex's picture
And it is built-in on BLF ... the third tab on the picture symbol (tree)... so it is even easier than animated GIFs... which can be annoying sometimes.
Little how-to: insert the picture (pic1) as you would normally (with "100 %"-trick ) after that -> picture symbol (tree) -> Advanced ( third tab) -> Swap image -> for mouse over (pic2) -> for mouse out (pic1)
Downside is that only 2 images can be compared this way.
