If you ever upgrade to xml2, it would nice to see how the current changes with the same driver config. If you do such a mod, please keep the xml current numbers posted in your OP. I haven’t seen any apples to apples comparisons out there. This might be an excellent example if you do.
EDIT: Nix the above idea. I guess the difference won’t be that much at 3.5 amps.
Thanks. I don’t know anything about resistors or diodes, but your photos make me feel like I could do this. So you added a resistor to the empty spot and removed and added two more for each LED?
Where would I buy some of these resistors?
I saw you edited your post, but here is the answer I was writing... Others might find it useful...
I have done XM-L to XM-L2 before.. When I did my SRK with resistors, I started with stock XM-Ls just in case of "poof".. I measured with XM-Ls and with XM-L2s, on each emitter. The drop when changing to XM-L2 was close to nothing. But that was at around 3,1A.
Example of a quite recent driver I played with, the one in the Small Sun ZY-T13 I have had XM-L, XM-L2, XP-G2 on it, and emitter current was pretty much the same. But then again, that was 2 cell in series, so vf was no issue.
The main area where you could see drop, is when you start pushing beyond 3,3-3,5A and are using single cell/parallel cells. Then its harder to achieve high current to XM-L2. In this case, I don't think the drop will be that much.
I have some XP-G2s on Noctigon that has been ready for a triple for a long time. My plan is to try those in this light. Ill check emitter current, but I don't expect the current to be more than 3,3A at max with fresh cells. XP-G2s are even harder to push beyond 3A.
The resistors limit current. But these are in parallel, adding more resistors in parallel makes more current flow through.
I used these resistors for this mod. If you want to add less resistors, then you need lower value on the resistors. But I used the lowest I had at the moment. Basically, I added 3x R120 to R17(see marking on driver circuit), 3XR120 to R13(see marking on driver circuit) and 3xR120 to R9 (see marking on driver circuit). Instead of stacking 3 in height, I just added the 3 resistor onto some of the others, all of them are in parallel, so it does not matter where you put them...
I added a total of 9 resistors. Adding resistors are easy. Much easier than stacking 7135s.
Edit: Did some minor changes to OP, hopefully its easier to understand if the text above was not clear.
Okay. I looked at the photo closer and now I see they’ve been stacked. I think I’m definitely going to give this a whirl when my light arrives. I’ll most likely swap XM-L2s on Noctigons too.
I’ll probably have some more questions when the time comes.
EDIT: I may wait to see how your XP-G2 swap goes. I’ve been considering the same thing for a while, and wondered why nobody ever uses anything but XM-L in these triples.
nice write up, I’ve just received my m6 and I’m thinking the same as you, nw or hi cri xp-g2’s would be the way I’m thinking of doing things, yes there would be a lumen drop, but the throw increase would be interesting.
It would be the equivalent of adding an R040, if there were such a thing. So adding a R030 instead would result in even more current flowing to the emitters. That is, if the cells and other components can deliver it.
EDIT: Adding a R030 would be the same as adding 4 R120’s.
thanks! not too knowledgeable with the electronic parts of this hobby. should have divided the original resistance by three, instead i divided the r060 by two, which would be dividing by 4
The stock M6 is already hotter than a hot SRK ;) I increased output with more than 43% with the resistors I used. That adds a lot of extra heat to a light that is already hot on high. 0:)
[quote=gords1001]
nice write up, I've just received my m6 and I'm thinking the same as you, nw or hi cri xp-g2's would be the way I'm thinking of doing things, yes there would be a lumen drop, but the throw increase would be interesting.
[/quote]
Thanks.
I have some XP-G2 R5 3Cs, ill see if im happy with that combo, if not, ill just swap the emitters. It might take a week before I try it. Have to play with the stock XM-Ls a little first. :)
Might even swap the driver circuit one day too, ill see how the "off" feature grows on me. UI would be so much better if strobe and SOS were hidden. Its annoying to cycle through them in order to get to off, and its a bit annoying to wait for 3 seconds in order to turn the light off too. The normal SRK is much nicer in that way. No regrets buying the light though! :) Its nicely built. I always considered it a mod host, like all other lights I buy... 0:)
The advantage with this light compared to the kings are that I can more comfortably adjust high higher due to having a medium, which is now basically a high... :p I now consider high to be turbo.. J)
I know I have a stack of xm-l 4c emitters so I’ll likely fit them, cw is far too harsh these days and that’ll get me by till I can properly mod it, it is a good quality host that’s for sure. I just lock out when I want it off, quicker than a 3 sec button press lol
