OL did some serious work over there. Original pill doesn’t have to be changed, that’s true but it is the weakest point of this light and for this light to be impressive pill has to be replaced. I would really like to make one by myself but unfortunately only tools that I have are dremel and basic drill (most of my drill bits are for wood, have some for concrete but not for metal), no late, no drill press (very useful tool), I don’t have copper sheets or copper pipes, I have some small pieces of copper rods (20mm and 25mm dia x 25mm length) but they are extremely hard to cut with dremel, warm up crazy fast and I don’t have anything else to cut them with. I think that most people that buy them do so because they don’t have proper tools to make them.
Anyway I don’t see anyone using this light in stock form, without modification and we all know that modification (mostly in parts) can cost more than the light itself.
I will have to spend some more time studying available modification threads to see what needs to be done and what can be done with limited resources and then decide, but the gray one looks really nice
If you mean changing driver and led then sure, I don’t put much praise in the stock components.
However you mentioned the cost of a copper pill as the thing that is putting you off.
I definitely wouldn’t put a copper pill at the top of the list of required changes. Again my original courui uses a bone stock pill shelf (don’t intend on getting a copper pill for it) and is running an xml2 at 6Amps, I mainly only interested in the copper pill because I ended up running a much hotter led in the setup. (Sbt-70 @ 14Amps = ~50watts vs XML2 @ 6Amps = max ~25watts)
Oh that’s nice, do you have a build thread, I would like to see how you mounted SBT inside, more particularly have you modified reflector, I am looking for best solution for my luminus PT54 build. Thought I would use TN31 but grinding that reflector would be an abomination
could someone suggest me a different( more powerful) driver for this flashlight that i own?
is preferable to change the original xm-l2 with a new one improved quality or bin ?
The next sbt-70 is going into a slightly more conventional Courui, designed around the 86mm kaidomain reflector.
That’s a good option with a large 20mm opening especially useful for large emitters. Bit of a beast to fit into a host but if you don’t want to take a hacksaw to an existing one it’s a good option.
Urgh, I have too many projects ongoing at the moment I haven’t had time to upload any threads. But I’m optimistic for the performance of this combination and it should be a relatively straight forward mod for others to do if they want to make use of this great reflector in a Courui.
It’s just a stock courui head with two interlocking lens hoods stacked on top. A 77mm and an 82mm hood from ebay. The front will be finished off with an 86mm multicoated UV filter.
Going with this setup will require taking a little bit off the O/D (~1mm) off the reflector to make it fit, alternatively I have a third stage lens hood (86mm) that I can add and make it work with the raw reflector but requires a 95mm UCLp lens and filter ring 95-86mm step down adapter ring to finish off the front.
The hoods and things are pretty cheap and available on ebay, I’ll post something up with specific parts once I’ve had a chance to assemble it all. Don’t want to recommend specific parts until I know they are compatible.
Oh and just to be clear, you would also need to build a pedestal on top of the shelf/pill to raise the emitter some to meet up with the reflector.
This looks very cool Linus i look forward to see what performance result you will get.
I have been craving a big reflector light for some modding adventures, but i can’t justify buying one of those big expensive reflector light just to rip it apart to get me a host, it is not enough BLF for me but this looks the most promising idea yet.
Did some work on the light today removing some material from the reflector to make it fit into the compact configuration (2x hoods + uv filter lens)
Here’s after the first assembly.
The reflector is a beast, though it doesn’t have the most perfectly smooth mirror finish. A very slight OP surface can be seen here.
I have yet to see how it performs in this config but this feature/flaw may make it a good option for an mt-g2 or similar just to help smooth over the honeycomb artefacts slightly. Just a thought, I’m sure it will also produce a very respectable beam with a normal die.
The UV filter and lens on the front: This is a really cheap UV filter but has what it claims is a multiband AR coating. Multiband? Hmm, probably not. But it definitely knocks down the reflections and the unusual green bias has the added benefit of counteracting the green tint shift seen from a dedomed cree led. So this may not be a bad option at all.
Still waiting on some parts to do a working assembly of the full light (led will be an sbt-70), but so far everything is lining up nicely. I like!
I received 3 Grey Courui’s yesterday, and one will not turn on, the same batteries powered up the other two, so I think the driver is bad, possibly the switch? I’m dealing with GearBest now, let’s see how it will be handled? The lights(all 3) are typically dirty inside and out. The reflectors show pitting but it looks like it was there before the Vap Coating was applied. GearBest order #WW1504201453507112. Out of the 6 I have got recently, really only one was what I would call very good?
I haven’t seen a gray one yet, but I also get the feeling that the quality of the recent batches from Gearbest is on a general downward trend.
The latest black one I received had some generally sharper/rougher machining on the battery tube and worn anodizing on parts of the knurling. The head and reflector also shows signs of being of a lower general quality though no hazing this time.
Anodizing colour is also inconsistent between the last two I ordered, one is a deep black and the more recent one slightly gray.
GearBest has come thru on this by sending another light for $6.00 for shipping, thanks GearBest! Hopefully this one will be clean and working? Thanks Angelia!!!
