About the driver for that new monster. What about a FET (+1) driver from Richard? I believe there has to be some changes made to let our current FET (+1) driver work with 6V leds.
And dont forget to give Simon a big THANKS on behalf of BLF! Seriously the way he listens to us is just exceptional.
Well, maybe it's bout time he looks into cutting a deal with Richard. I'd love to see one of Richard's driver in there, then we can re-program it as we see fit . Certainly Simon could get the drivers made over there cheaper, just like with the A6 driver being sold by BangGood now. Heck, he can use my e-switch firmware is he wants to.
Whenever an owner has time, I’d love to see pictures of the inside of the head and driver pocket, and also a comparison lineup with a C8 and an X3 or Couri or something.
Received my light and host just now. Very well packaged, zero damage, pretty fast shipping! As always
great quality and nice matte ano! The shelf is 4mm thick, but has a .500mm deep roughing process drill tip divot and is anodized. No big deal remove the ano and fill the divot with AS5. I like using that or Loctite metal putty? But naturally would not want it at all. The mcpcb shelf is over size (20mm-mcpcb is sloppy) with a some what large radius about a #3, plenty of room to float your emitter centering ring into the reflector? Again I like straight walled, and a little under size to make contact with the star? The driver (17mm) pocket is kind of sloppy, with what looks to be a #3 radius on the turning tool, so not straight walled, the shelf for the driver is thin, I wouldn’t think it would best for heat sinking a LD-2 or Buck driver? It is 9.16 deep from the driver shelf to back of the emitter shelf. Me, I’m going to open up the mcpcb emitter pocket and machine the divot out (1mm deeper) and put a stripped copper mcpcb (26mm-maxtoch) underneath a 26mm maxtoch, and a de-domed xpl direct solder bonded with a FETDD and call it GOOD!
I’m measuring 71.21mm? Does that help? Sorry I don’t have a 26700. But I have a Vapower and added 2 copper washers at 3.81mm plus the battery at 67.4 naturally bottomed out the springs but the light came on? Now if you need more, you could shim the Battery tube out at least .5mm f need be?
sweet, that sounds promising. I also asked simon how long of cells it accepts, so I’ll see what he says. I think 71mm should be plenty. I might just get a host to play with. My only gripe (in single-cell form) is that it has the M1 bezel instead of a nice stainless one (like L5), and I wish it took a 20mm driver. 17mm is getting tight with all the new features we’re getting on drivers. To that end, I’m glad the driver shelf is thin. Minor gripes.
Yep, affirmative! The I.D. of the driver shelf is 16.180mm, the O.D. of a LD-2 is 16.9 which only gives you .360mm(.014”) on the radius? .720mm (.028”) on the diameter? But it’s really thin thickness wise too? Most of your heat sinking would be the brass ring? No what I mean Vern!! :bigsmile:
That’s exactly what we are going for. Simon has a bunch of details to get worked out but it should be a remote switch with two wires going back to the board. This one will take a bit as it’s the first XHP70 light Simon has built but all is looking very promising. Oh and I told him we would like an AR coated lens and he agreed to do that too. :bigsmile:
Your welcome! I de-domed the stock light last night, just to see what it would do stock with spring bypass’s, 136cd. But the beam got a little ringy, with a big ring from the reflector base. The reflector will sit on the board with out the centering ring, with out shorting out. Upon further investigation…………Edit: The reflector is shouldered and locked/trapped between the head and bezel, I had to add a stripped 20mm Noctigon to raise the emitter star closer to get a better focus, and solder the leads to the outside of the contacts to clear the reflector base. I would leave the dome on! The e-switch, I would like to see a rubber boot for sealing purpose’s, I like the Crelant 7”G”10 and the SD75 button they work really well!
BLF doesn’t owe me. I’m just glad I can contribute in some way. People here are way cool and have helped me plenty of times. I don’t have the skills to mod a flashlight. I can’t even swap an emitter to be honest. It’s on the list of things I want to learn but until I have the time to learn to properly solder and desolder components I just don’t want to mess up my lights. I am persistent though and I sure can talk. :D. Sure it’s frustrating sometimes but it’s also very rewarding. I get to help Simon and BLF… talk about a win-win.
