Review: Trustfire Mini-01
439 posts / 0 new
mags
mags's picture
Last seen: 5 years 4 months ago
JohnnyMac wrote:
I broke down and ordered one from the eBay seller. I think it was $14.40 shipped. Anyone else buy from him? If so, how long to receive?
was it from trading_one?
MattSPL
Mine was from trading_one. Took 3-4 weeks to Ireland.
mags
mags's picture
3 – 4 weeks delivery is nothing but painful for us flashaholics!!
JohnnyMac
JohnnyMac's picture
Last seen: 1 day 19 hours ago
It was rray009. http://rover.ebay.com/rover/0/e11400.m1842.l3160/7?euid=d51979e878c44474...
MattSPL
It sure is Big Smile
gloomywarfreak
gloomywarfreak's picture
Last seen: 2 weeks 2 days ago
Mine was ordered from trading_one also. The long wait is indeed torture.
JustFit
JustFit's picture
mine only draws 1.08 Amps on high , and 0.24 Amps on low , on a freshly new charged Trustfire Flame 16340 …and I’ve also connected a new Hi-Max 18650, 2600 mAh to the mini-01 , and the same thing , it draws around 1 – 1.05 Amps on high …
I can’t complain because it’s a lot of light for this little thingie … but it would have been nice to have a tiny monster, with double the output…
So , the question is…only mine draws ~ 1 Amp on high ?
Think twice, act fast!
MattSPL
How do I go about testing the current draw of my mini-01? I have a multimeter.
Cheers
Matt
JustFit
JustFit's picture
Cheers
Matt
Hi Matt!
It’s very easy , set the DMM like in the picture, hold the head of the flashlight , put the 16340 (RCR123A – CR123A) in , connect the black lead to the flat end of the battery (-) , and slide the red lead between the body and the battery to touch the outer ring of the flashlights circuit board, and that’s it , the DMM should show you how much Amps does you’re flashlight draw…
MattSPL
Thanks for the help, I’ll give it a go and post my results.
Cheers
Matt
MattSPL
Here’s my current draw results for the Mini-01
Trustfire primary – Low 0.08A, High 0.8A
Surefire primary – Low 0.06A, High 0.75A
Ultracell 3.2v LifeP04 – Low 0.1A, High 1A
AW 3.2v LifeP04 – Low 0.13A, High 1.09A
Yezl 3.7v 16340 – Low 0.25A, High 2.4A
This explains the brightness and hand burning heat when using the Yezl cell :bigsmile:
Edit: I have just tested the Mini-01’s current draw on 2 different 18650 cells.
Senybor 3100mAh(Panasonic) protected – Low 0.27A, High 2.55A
Panasonic GCR18650CH – Low 0.30A, High 2.9A
JustFit
JustFit's picture
Thank you Matt for the readings… it seems that I have a faulty one.
hmmm…
Anyone else has a mini-01 that draws only 1 Amps in High mode on 16340 ?
MattSPL
hmmm…
Is it possible that the Trustfire flame isn’t capable of delivering any more current, rather than the light being faulty, because your readings are very similar to mine, except for the Yezl cell?
JustFit
JustFit's picture
hmmm…
yeah, but don’t forget that trustfire flame is 4.2 fully charged , and I’ve also tested the mini-01 with Hi-Max 18650 cells which deliver a good 5 Amps on my Trustfire TR-J12 …
MattSPL
Yeah not sure to be honest. Have you any other cells to try?
Suncoaster
Suncoaster's picture
Last seen: 4 hours 38 min ago
Location: Where the girls are green and the grass is pretty.
I get
.08 and .85 on the original Trustfire CR123A
.11 and .98 on SOshine RCR-123 protected.
But my cheap DMM leads read low compared with better wire..
I need to make up some better leads.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
MattSPL
Suncoaster wrote:
I get
Thanks for testing your Mini-01.
Hopefully some other people can test theirs too.
alex21
Last seen: 6 days 8 hours ago
mags wrote:
Nice! Any way of posting some beam shots or perhaps a video?
Thanks man. Unfortunately the only camera I got is the one on my phone.. tried last night but it came out too crappy Sad
alex21
Nice.. got to get me some of that hand burning goodness for these winter nights Smile
mags
mags's picture
Glad I picked up the Yetzl cells…
MattSPL
Big Smile
Now i just need to get hold of an AW IMR 16340. That should be really fun :bigsmile:
alex21
MattSPL wrote:
Big Smile
Good one. Should be interesting J)
mags
mags's picture
Big Smile
Is the AW IMR better than the Yetzl? By how much?
MattSPL
Big Smile
I don’t know enough about flashlights and batteries to give a definite answer, but this is what i think: I bought the Yezl 16340 because it has the highest tested capacity ive seen, and it is rated to handle upto 3.2A discharge, which, from what i can tell, is very good for a 16340 cell.
The AW IMR 16340 is capable of 4.4A max discharge, but will also have a much lower internal resistance due to design and lack of any protection circuit. This means it will perform better in a light that needs high current delivery, especially a direct drive light like the Mini-01 seems to be.
So in theory, the AW IMR 16340 should make the Mini-01 even brighter. You would just have to take care not to let the IMR discharge below 2.5v(as it has no protection circuit), or it will shorten cell life.
Cheers
Matt
mags
mags's picture
Big Smile
Cheers
Matt
Thanks Matt
http://www.oveready.com/batteries-chargers/aw-imr-16340-rechargeable-bat...
JohnnyMac
JohnnyMac's picture
As soon as mine arrives I will post figures using my TF flames as well as OTF lumens in my IS.
Tecmo
Tecmo's picture
Flames work fine in mine. They’re from DX.
MattSPL
Thanks Smile
MattSPL
Yes, the Trustfire flames 880mAh seem to be a good 16340 also. Torchythebatteryboy tested them as having 658mAh capacity at 1A discharge.
feilox
So I heard it last 6-8 minutes on high. How much do i get with these AW & Yezl cells?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
