New EDC 18650, the first flashlight using the new CREE XP-G2 LED @ Intl-outdoor.com
168 posts / 0 new
singularity35
singularity35's picture
Last seen: 1 month 1 week ago
Ok, I’ll try. I’m using the same ultrafires that I use in my HD 2010, the purportedly 3000 mah ones.
I hope this pic is clear enough for you to be able to tell.
Chuck Roxas
scaru
scaru's picture
Last seen: 4 years 11 months ago
Yep, that is an XM-L. I have a feeling the problem is the battery though. Ultrafires aren't exactly known for their quality.
singularity35
scaru wrote:
Yep, that is an XM-L. I have a feeling the problem is the battery though. Ultrafires aren’t exactly known for their quality.
Thanks. I may just have overexpected after seeing the 800 lumens on both my HD2010 and Fenix TK35. The EDC 18650 is still a pretty good light for EDC. I’m probably going to get a couple more. And some better batts. Big Smile
Chuck Roxas
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 27 min ago
If you’re comparing against those two lights, the EDC18650 is going to look a lot dimmer even with good batteries. They get about 22k cd and 50k cd, respectively, compared to the 5k cd on the EDC18650. The issue could be the batteries, but I suspect it’s more due to comparing throwers against a flooder.
singularity35
Thanks!
Chuck Roxas
singularity35
I finally got my EDC 18650. It’s a black one with the convoy s3 marking. It isn’t as bright as I expected for around 700 lumens since it seems to be around as bright as my PD30.
I ordered one with the XM-L U2, is there any way to tell if I got what I ordered? Thanks.
The LED should look like this:
He also offers the XP-G2 emitter in those lights, which looks like this:
Other common types are XP-E and XP-G, shown in that order here:
As for the “U2” part, you probably can’t tell without taking the torch apart to look directly at the emitter star.
About brightness, do you mean the center of the beam isn’t as intense as you expected, or that it’s dimmer in a ceiling bounce test? I looked up the PD30’s specs and it’s rated at 145m of throw. That works out to 5256cd, which is approximately what I’d expect from an XM-L EDC18650. The PD30 has a much more focused beam, while the EDC is more floody. However, the EDC should light up the rest of a room much better than the PD30 does.
If you could put a bigger reflector on the EDC18650, it would produce a much brighter, smaller hotspot. For example, the XinTD C8 has roughly the same lumen output, but its beam is 4X to 5X as intense. Or the HD2010… again, similar total lumens, but it gets ~50k cd instead of 5k cd because it has a much bigger reflector.
I’m sorry I missed your post, thanks so much for taking the time to show this to me. I love this forum. Learn something new everyday. Big Smile
Chuck Roxas
vodokotlic
Last seen: 8 years 9 months ago
I got my Convoy S3 body, XP-G2 3-mode version this week but can’t get lower modes working. As far as I can see I only get one full brightness mode and one almost unnoticeably dimmer mode. No low mode to speak of. Cell is Samsung ICR18650-28A, charged with ML102 (ie. to 4.2V)
BababooeyHTJ
Last seen: 8 years 7 months ago
I love my EDC18650. I popped on the stainless steel clip that intloutdoor also sells and it works great. My only gripe is that the reflector isn’t as floody as my convoy S3. My S3 reflector puts out a smoother beam that I really like.
Haterade
Last seen: 5 years 10 months ago
surprised you noticed a different between the IO and Convoy reflectors
I like copper
BababooeyHTJ
Yeah I was surprised to see that too. I was expecting the two to be identical. The orange peel is definitely more aggressive on my S3 reflector.
Tom E
Tom E's picture
Last seen: 3 hours 54 min ago
Found the problem with low lumens/brightness on the EDC 18650! It's the centering ring - not sure if anyone pointed that out yet, it seems to sound familiar.
I've been disappointed with the output with it doing about 525 lumens with an XML U2, 2.8A Nanjg. So, I updated it to a U3 1C on a SinkPAD and 20 22 gauge wire - only improved it to 560 lumens. So looked at that centering ring and replaced it with a low profile type, and added a paper type of ring insulator because it was needed now - stock centering ring left a good gap between the star and the reflector. To raise it all up, I simply unscrewed the pill a bit and got it to a point where I could tighten up the SS bezel really well and have a good amount of pressure on the star (actually used the rubber strap of a strap wrench to tighten it).
 So those adjustments raised the lumens from 560 to 795 on a Sanyo battery, both readings at 30 seconds! Now that's what I'd expect! Oh - also got a AR lens in there, but it's been there all along - one of the first mods I ever did...
ooops -- edited the wire gauge above...
Haterade
well done Tom! Smile
I like copper
Tom E
Tom E's picture
Haterade wrote:
well done Tom! :)
It's hard to believe it made such a hugh difference.. I got several 18650 EDC style tube lights, and this has been the worse performer, now it's one of the best, only beaten out by my Convoy S4 host w/XM-L2 U2/SinkPAD, 3.5A Nanjg which does just over 1,000 lumens. I did one or two right about there in the 790-800 lumen range, same XML U3 Nanjg 2.8A setup.
JW980
Last seen: 3 years 3 months ago
I notice from the pics at OI that it appears there are two different LED centering spacers.
Looks like the grey and gold versions have a round spacer with a round hole, whereas the black version has the “butterfly” spacer with a square hole.
Can anyone comment on this?
I’ve been resisting buying the EDC host for months now…and finally pulled the trigger on the black one. I don’t yet have a tube light, as all my 18650 lights have larger heads.
Thinking of building it up with an XP-G2 R5 3C on copper, conservatively driven @ 1.9A (5×7135 380’s), flashed with customized Star1.1 firmware (1-minute turbo timer).
Thanks
-JW
Tom E
Tom E's picture
Just an fyi, this is the Convoy S3. I got both. Believe the round one was the bad one that blocked output.
JW980
I see-thanks for the heads-up on that.
-JW
JW980
I received my black IO EDC 18650 host yesterday. It seems to be of decent quality for the price.
While there are o-rings to seal between the body, tailcap, and bezel – there is nothing to seal between the lens and the bezel ring.
A thin flat gasket would probably work well, but I don’t want to make one if I don’t have to. Does anyone know where I might be able to buy one of the correct size?
On another note, I also received two more Qlite drivers. I don’t know if this is news to anyone, but these appear to have 24-gauge silicon wires instead of the usual PVC wires.
Thanks
-JW
