SinkPads copper 20mm and XM-L2 U2 initial results
131 posts / 0 new
Tom E
Tom E's picture
Last seen: 4 hours 16 min ago
This is what I'm seeing:
Crelant 7G9, before, at 3.85A:
-      1057 lumens start, 992 lumens @30 secs, throw: 75 kcd
Crelant 7G9 After, @4.2A (added a 7135, and XM-L2 U2 1C on a 20mm SinkPAD):
-      1264 lumens start, 1248 lumens @30 secs, throw: 121 kcd
HD2010, before w/U3 1C, at 4.09A (KD V2 w/3 350 7135’s added):
-      986 lumens start, 945 lumens @30 secs, throw: 63 kcd
HD2010, after, only change of XM-L2 U2 1C on a SinkPAD:
-      1360 lumens start, 1329 lumens @30 secs, throw: 91 kcd
** All on freshly charged batteries. On the HD 2010, using KK ICR26650E, unprotected
So far, the XM-L2 U2's and SinkPAD combo seem to be outstanding.
Updates 02/10:
XinTD C8, before w/U3 1C at 3.5A Nanjg, stock emitter, stock driver but added 2 350 7135's:
  986 lumens start, 948 lumens @30 secs, throw: 36 kcd
XinTD C8 after, add 1 7135: 3.85A now, XM-L2 U2 1C on a SinkPAD:
-   1101 lumens start, 1060 lumens @30 secs, throw: 44 kcd (pana 3400 4.16v, 3.4A measured)
SupFire X5, before totally stock w/T6, 2.56A measured:
 -    635 lumens start, 612 lumens @30 secs, throw: 24 kcd (fresh Pana 3100)
 SupFire X5 after, U3 1C on a SinkPAD, 3.85A Nanjg:
 -   1122 lumens start, 1081 lumens @30 secs, throw: 35 kcd (Pana 3400 4.19v, 3.63A measured)
Update 02/18:
LightMalls UF C8 before: KD V2 3.8A, U3 1C emitter, UCL lens:
 -    1013 lumens start, 982 lumens @30 secs, throw: 38 kcd (fresh Pana 2900)
LightMalls UF C8 after: custom programmed Nanjg - 3.85A, brass C8 pill (FastTech) w/copper discs, XM-L2 U2 1C on 20mm SinkPAD:
 -   1203 lumens @start, 1173 lumens @30 secs, 48 kcd (measured at 4.31 meters, fresh Pana 3400)
Maybe a new C8 single emitter record? Smile
Edited by: Tom E on 02/18/2013 - 21:28
nitro
nitro's picture
Very nice results
MattSPL
Last seen: 3 months 4 weeks ago
Impressive Smile
relic38
relic38's picture
Last seen: 3 years 11 months ago
Those are great improvements! Looking forward to working with mine.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
dthrckt
dthrckt's picture
Last seen: 1 week 1 day ago
Shocked WOW Shocked
manxbuggy1
Awesome results Tom! Both lights are impressive but who would have thought that the HD 2010 could be such a beast? Wow!
Tom E
Tom E's picture
 The HD 2010 results are kinda blowing me away, but think I nailed it with tight-fitting a trimmed 20mm star in there, and sanding star and top of pill surfaces all the way to 2500 grit. The HD2010 pill is far from stock, lots of copper added inside, plus a small brass pill, but I didn't touch the pill from the pre-mod. Maybe the SinkPAD though gets some real advantage from this. Oh, also got a UCL/p lens in there, also pre-mod.
 Oh, also, I left the SinkPAD indent on the bottom as-is, and used Arctic MX-2 grease rather than epoxy I had before. Filled the indent with grease though.
Tom E
Tom E's picture
 Just hope others can re-produce these results, hoping I'm not crazy or got it all wrong somehow Smile.
Gotta run - Super bowl party at my daughter and future son-in-laws...
dthrckt
dthrckt's picture
where’d you get your sandpaper assortment? I need to resupply my higher grits and its been a long time since I shopped around
Tom E
Tom E's picture
Got the fine stuff from Amazon, direct. Ordered 2 assorted packs, 1000-2500 wet/dry:
http://www.amazon.com/gp/product/B005JPGTNI/ref=oh_details_o00_s00_i00
ChimpOnABike
ChimpOnABike's picture
Last seen: 8 years 2 months ago
Having seen the impact that lapping can have on CPU cooling the results with the 2010 seem to show what can be achieved with elbow grease. I can see now why people were getting excited about these.
Don’t be a chump, be a chimp!
Bort
Bort's picture
Last seen: 30 min ago
Why is the XM-L U3 100 lumens brighter then the XM-L2 U2 even though the U2 has slightly higher amperage?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
JackCY
JackCY's picture
Last seen: 6 years 6 months ago
@30sec?
A bit useless IMHO.
What are the results on 5-10minutes?
Something useable. Unless You plan to use your light under 1 minute?
jmpaul320
jmpaul320's picture
Last seen: 4 days 13 hours ago
Tom – where did u find a ucl for the hd2010?
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
dthrckt
dthrckt's picture
nice, thanks, I also grabbed two of the 320-800 assorted. That should be enough to do the 30 boards sitting here Smile
manxbuggy1
It’s not. The XM-L2 U2 is 387 lumens brighter than the XM-L U3. Sure makes my stock HD 2010 look sick. Lol. It ended up 770 lumens otf after 30 seconds and throws about 53k
Bort
Bort's picture
you are correct, i misread the results
however, why does the post mod hd2010 have 1360 lumen @ 4.09A and the 7G9 have 1264 lumen at 4.2A?
zizo
Last seen: 1 year 8 months ago
What is a good soldering paste to mount led’s on a copper star? I have destroyed 1 star so far with no luck. :bigsmile:
dthrckt
dthrckt's picture
Bort wrote:
you are correct, i misread the results however, why does the post mod hd2010 have 1360 lumen @ 4.09A and the 7G9 have 1264 lumen at 4.2A?
I’m assuming those are tail current measurements, not current at the emitter, so assuming the measurements are accurate – driver efficiency, and the acceptable deviation of emitter performance (7% range for each bin?)
Bort
Bort's picture
emitter current, good point, perhaps someone should test emitter current and voltage drops, a table of this would make a great sticky thread
Tom E
Tom E's picture
jmpaul320 wrote:
Tom - where did u find a ucl for the hd2010?
flashlightlens.com - it's a little big, think it's thicker. You got usually 1mm to play with in width. Pretty sure I can't fully screw down the bezel as far as it used to, but its over the o-ring.
Tom E
Tom E's picture
Bort - as far as the HD2010 doing better in lumens then the 7G9, amps helps but it's not the only thing that matters. We are talking minor differences here, and that HD2010 reflector does well for putting a lot of light out - good in throw, while the 7G9 targets throw more - tighter hot spot. So is my lightbox perfect? No, no chance, but could the HD2010 be a little better at putting out lumens in it's setup than the 7G9, certainly could be. There's also signifcant differences in batteries, LED emitter from one to another, etc. For example a binned 1C can be all over the place, more cool or more neutral sample to sample.
 One difference is certainly the battery configuration - HD2010 running a 26650 (good one - KK) while the 7G9 uses 3 18650's in parallel - tested with Panasonic 2900's unprotected. Batteries make a big difference in measurements I've taken. You put 10 mins of runtime on a battery, brightness suffers quite a bit, even with regulated drivers.
mattthemuppet
Last seen: 6 months 1 week ago
great results, particularly the reduced output drop with the sinkpads. Possible lower Vf might help too, but everything else (host etc) should be equal. Although output after 5min or longer would be interesting, you’ll then be looking at the thermal properties of the host/ dropin etc, not the LED star.
Tom E
Tom E's picture
zizo wrote:
What is a good soldering paste to mount led's on a copper star? I have destroyed 1 star so far with no luck. :bigsmile:
Well, I used a paste that was marked to do aluminum, but it would do other metals as well - bit expensive because of it supposedly for soldering aluminum but I didn't have much luck with it, so, used the same stuff for the LED mounts - worked well.
Got it here: http://www.amazon.com/dp/B0058ED0LE/ref=pe_175190_21431760_3p_M3T1_ST1_dp_1
bdiddle
Last seen: 6 days 18 hours ago
Where did u get the sinkpads?
Newb
Tom E
Tom E's picture
nitro organized a group buy thing - nitro posted above. Not sure, but he may have more left. I wish I ordered more now Smile, but 16 mm's would be great, but the 16's are not stock items at SinkPAD, the 20's were. Possible plan is to put another group buy together for 16's (or 14's), but include payment for the tooling costs to SinkPAD, so it will cost more but the more we buy, the less % is the tooling cost.
comfychair
comfychair's picture
Last seen: 5 years 6 months ago
Thermal compound/paste is only good for bridging vewwy vewwy tiny gaps, such as microscopic irregularities in surface finish, down to the scale where you can't see any roughness with the naked eye. If you have a divot or pocket or wide gap, skip the paste, it won't do anything but make a huge mess later on when you take it apart again. Heat just doesn't transfer thru a big glob of paste.
I know a lot of you guys just like tweaking things for the sake of tweaking, but the fancy expensive exotic compounds aren't doing anything but lightening your wallets... just pick up a giant tube of white silicone-based paste from the electronics store. It'll last you thirty-seven forevers, and performance, when used correctly, will be within the margin of error for whatever equipment you're measuring with. Changes in ambient temp during the test will show more variation than between the most expensive and cheapest stuff.
Similarly, for filling gaps or pockets so you can correctly use thermal paste, or for permanently mounting stuff, plain ol' JB Weld is just as good as Arctic Alumina or any of the other fancy ones. And like the white thermal paste, you can get it in giant tubes that last forever ('Industro-Weld' - exact same JB Weld, just in bigger tubes). Skip the JB Quik - it's not as strong or as good at heat transfer. If you're curious, squirt out some of the black JB, and poke at it with a magnet... (hint: it's got lots and lots of metal in it, but it's not electrically conductive).
Tongue Out
relic38
relic38's picture
Interesting, comfychair. I’ve used superglue to bond stars to a heatsink before. apply a small amount, press with a lot of weight for about 10 seconds, and it’s on. I was surprised to see the star only be 4-5 degrees hotter than the heatsink. Worked quite well, and it’s temporary since the glue will not bond good to smooth aluminum. I would not use it in a real application unless in a pinch, Shock or lateral pressure seems to jar them loose sometimes.
I either use Fujik (probably a fancy name for overpriced silicone sealer) or thermal paste when I have something to hold the star down.
Welcome the night.
PilotPTK
Last seen: 7 years 10 months ago
Has nothing to do with driver efficiency, I promise. They’re both linear drivers (AMC7135 Based) which means that tail current = emitter current.
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
Bort
Bort's picture
PPtk
i see, do you know anything about voltage drops, as i am looking to order a driver very soon and would like the one with the least drop
PilotPTK
If you’re wanting to stay with a Linear driver, then any AMC7135 based driver will have VERY similar voltage drop. If you are looking for switching buck, then they’re all going to be vastly different in how much overhead they need in order to maintain regulation. You’d have to ask the vendors.
PPtk
