Simple review of the KD 1-mode 3-18V driver
37 posts / 0 new
RaceR86
RaceR86's picture
Last seen: 5 years 8 months ago
Just wanted to share my findings with the driver found in this drop-in.
This is not a very in depth review. It does lack some important measurements, but I believe it gives a fairly good picture of the driver.
Out of the P60
Close up
Here are some tail cap readings I did not long after I got it.
(battery voltage is not measured under load. These measurements were done with the P60, so in combination with XM-L2)
As you can see, its quite useless below 3,7V. Seems to be a 3,6-18V driver too me. Once again, KD messes up facts.
I measured amps to the emitter yesterday. Started out with a battery pack. Barely used eneloops that was charged around 2 weeks ago.
Emitter: XPG2 on copper.
1,5A to emitter
Im pretty sure I tested it with 3 batteries too. And saw about 1,5A (but not 100% certain when writing this)
Changed to powersupply (5-15V)
5V
6V
7,5V
9V
12V
15V
That gives me these numbers in the middle column below. I did the test once more with 22 AWG wires. Still same results. The small differences are most likely me not setting the power supply on precicely the same setting. (as pictures show, its only a scew, not a digital display with output value)
People are free to draw their own conclusions. Many people here have way more knowledge than me.
My thoughts:
Based on the numbers I would say its a mediocre if you are only using 1-lion. 2,1A input. About 1,5A to the emitter. Very roughly, efficiency seems at best to be up towards 70%, but generally lower. Problem is, when voltage sags below 3,7V its useless. So if using a battery like the NCR18650B (3400 mah) you will not get full advantage of all the capacity. By looking at tailcap readings, the numbers goes down when battery goes below 4,1A. Basically right away. I never measured amps to the emitter with a lower voltage single li-ion, but I suspect that output goes slightly downwards too (or maybe efficiency goes up). Whatever it does I would either way say its either best suited for 2 li-ions or 4-6 AA batteries.
You can push it beyond 9V, but output goes down a lot. Its quite noticeable when changing the voltage on the power supply from 7,5-15V.
My conclusion: All in all, very flexible simple little driver. Its cheap too. In order to get highest output and probably best efficiency, input voltage in the 4,0-8,4 V is recommended. 4xAA batteries looks to be a very nice combo for it. Its also very suitable for 4-6AA batteries or 2x li-ions.
Thanks for reading
Feel free to come with input on how to interpret the values I have measured.
Question to readers: Does anyone know of a better small 3-18V driver that are better with similar or higher output?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Edited by: RaceR86 on 04/14/2013 - 07:00
ryansoh3
ryansoh3's picture
Last seen: 9 months 2 days ago
Thanks for the review!
BLF ≠ B-grade Flashlight Forum
RaceR86
RaceR86's picture
Thanks. Not sure if many will show interest in the driver, but hopefully someone will find the info useful.
BTW, im pretty sure its this driver. KD sell it for 2.65$
TexasLumens
TexasLumens's picture
Last seen: 1 year 1 month ago
Thank you for the time spent on the review! This sort of info is ALWAYS useful. I use a lot of different driver / emitter configurations and its always good to see things like this.   Great images as well!!! Wink
Thanks Again. Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
E1320
E1320's picture
Last seen: 8 months 2 days ago
I use those drivers quite frequently for lots of different projects. That driver works much better with bigger wires so remove the stock small wires and use some 22awg and you will get much better results. They are quite sturdy drivers and when potted with Fujik into a P-60 or any other pill they are great for firearms or high shock usage and also pick up some decent amperage with bigger wires.
Great driver for a great price thanks for the review.
I am already visualizing the duct tape over your mouth.
TexasLumens
E1320 wrote:
I use those drivers quite frequently for lots of different projects. That driver works much better with bigger wires so remove the stock small wires and use some 22awg and you will get much better results. They are quite sturdy drivers and when potted with Fujik into a P-60 or any other pill they are great for firearms or high shock usage and also pick up some decent amperage with bigger wires. Great driver for a great price thanks for the review.
Thats good advice.  We replace the wires on every driver that we buy. Surprised I have yet to see one with anything that is sufficient. I get tired of doing it but it just makes a better light in my opinion. I like the silicone / teflon wire better anyway. Wink
Dan.
RaceR86
RaceR86's picture
As pictures show.. This was done with stock, very thin wires. Ill switch them out with 22 AWG silicone wire.. Curious to see the difference.
Should have done that before I did the measurements.
JohnnyMac
JohnnyMac's picture
Last seen: 2 weeks 6 days ago
Looks like a great option for a 2 x 14500 Minimag running an xp-g2. Beatiful macro shot as well! 8)
garrybunk
garrybunk's picture
Last seen: 3 weeks 1 day ago
Thanks for the review & measurements. I bought two of these for a modding my mower headlights (12v source) but haven't got around to it. At least you confirmed what e1320 told me - 2A @ 12v to an XM-L.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
RaceR86
RaceR86's picture
Did some minor changes to OP. Tested with new wires today.. Same result.
JohnnyMac wrote:
Looks like a great option for a 2 × 14500 Minimag running an xp-g2. Beatiful macro shot as well! 8)
Thanks, and I agree. … A light similar to the mini mag was the main intent for the driver.. But I may find it suitable for another light too… Smile
garrybunk wrote:
At least you confirmed what e1320 told me – 2A @ 12v to an XM-L.
-Garry
At 12V I am getting output of 1,27A to an XPG-2 on copper.
With three 14500 below 4 volt (total of 11,34) im getting 0,69A on the tail (in combination with XM-L2 emitter)
Microa
Last seen: 8 hours 30 min ago
For your information, The driver IC is YB1682 2A 20V PWM Buck DC/DC Converter.
The data sheet’s link http://www.yobon.com.tw/pdf/YB1682%20Rev.1.0.pdf
18sixfifty
18sixfifty's picture
Last seen: 1 year 12 months ago
thanks for the review, I have seen that driver and wondered about it.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
garrybunk
garrybunk's picture
RaceR86 wrote:
*Question to readers:* Does anyone know of a better small 3-18V driver that are better with similar or higher output?
BUMP?  I'm specifically interested in the 8.4v to 15v range.  I'd like 2A or more output to an XM-L / XM-L2.  Oh, and the cheaper the better.  Single mode is ok.
-Garry
garrybunk
garrybunk's picture
So I was testing my work so far on my lawnmower LED headlight project and my testing included this single mode 3-18v KD driver so I thought I'd post my measurements here too.
I used this 3v to 12v power supply rated up to 2A (until I touched the leads together and blew the fuse with no spares on-hand):
1
I mounted a spare XM-L U2 1B to my heatsink (it was 16mm and my heatsink is tapped for a 20mm star):
1
EDIT 9/11/2013 - Just realized that I used my meter which is known for being "out of calibration" for the voltage measurements.  When I rechecked with my good meter the voltage levels were within .02v of the dial setting. END OF EDIT.
LED lit up just fine from 3v (yes, at 3v on the supply) to 12v.  I didn't get an actual voltage measurement of what the power supply puts out at the 3v selection:
11
Interesting to note is that my power supply voltage only showed 10.46v when set to 12v and driving the LED (it read about 12.1v with no load):
1
At the 6v setting I read 6.10v load or no load:
1
Here are my emitter current measurements at each voltage selection:
@3v = 1.39A
@4.5v = 1.39A
@6v = 1.47A
@7.5v = 1.29A
@9v = 1.30A
@12v = 1.36A
After I blew the fuse in my power supply (DOH!), I had to come up with a way to measure from another 12v source:
1
From the car battery I measured an input current of 0.58A and emitter current of 1.26A.  (I don't think there is any voltage sag through the 6ga jumper cables! Smile )
I only used my Elenco for voltage measurements.  I used my Mastech clone for current measurements along with my custom short 12ga leads.
I guess these measurements are inline with RaceR86's though not as consistent as his.
So this driver doesn't put out the 2A to 3A I was hoping for, which is why I asked for another cheap +/- 8.4v to 15v driver.
-Garry
EDIT - no objects were staged / posed in any of the above photos.
RaceR86
RaceR86's picture
Great work Garry! Im fairly confidend my PS output was consistent when I used it back then. Although, I relied on the ouput reading which are impossible to adjust 100% precisely. For some reason my power supply does not have that consistent output in the 7,5A range anymore. I really need to put a digital voltmeter on it.
Our numbers were pretty similar, and showed the same tendency. About 1,5A was max emitter current, and generally ouput was 1,3A+.
Yours did work down to 3 volt though, mine did not..
Btw, that R120 resistor might limit current. Like some others have done with similar drivers. A little resistor mod might increase the current to around 2A?
garrybunk
garrybunk's picture
Do tell more (or link)!  I'd love to hear on successfully resistor modding this driver.
EDIT - What about shorting that resistor?  What might that do? Risk too much current?
-Garry
RaceR86
RaceR86's picture
Im not sure anyone have done it on the driver circuit that we got.. Some have done it on this. See this review.
I dont have the driver that I originally tested anymore. But I do have a brand new one in a bag. You see there is R120 where the negative wire connects. I could stack something on top of it if you want me to try it out. ^^
garrybunk
garrybunk's picture
Sure!  (Better you burn up your driver than me burn up mine! Smile
-Garry
RaceR86
RaceR86's picture
No problem!
Done! Wink
I did not test this driver below 5V, and it was not the same as the one in OP, it was also bought many week later.
At 5V input, i was seeing 1,8A to the emitter. This was higher than the other driver where I was seeing 1,5A.  With a bit higher input numbers I saw fairly similar numbers as with the driver tested in OP.
When I set power supply to 7+ish volt. I saw 1,52A to the emitter.
Added R500 on top of the R120 resistor. Same input voltage (7+ ish volt) output was then 1,82A (first 3 seconds was close to 2A). After a few minutes on that setting it was 1,78A. I did not run it for a long period of time, 3-4 minutes. Driver was just sitting in the air with no heatsinking attached to it.  And with the efficiency of it, it gets quite warm.
After resistor mod it was 2,13A at 5V input. At 16V, emitter current was down to 1,3A.
In short. R500 on top of R120 increased current with around 0,3A through the range I tested it.
Hope you find the numbers helpful, I can not speak of long term reliability, or how efficiency was affected. I assume its pretty much the same as before. When it comes to long term reliability, this is where you come into the picture! Wink  Big Smile
Beer
garrybunk
garrybunk's picture
Thanks, that was quick!  (I was about to post "Are you done yet?" but you beat me to it! LOL!)
You say it's not the same driver as in the OP, so was it the DX driver you tested?  Or was it just a different KD driver?  So if I add an R500 (hope I have one) you expect I'll see about 1.66A @ 12v input?  You said yours got quite warm.  Mine is mounted in a P60 pill which has been filed down flat and screwed & JB welded to the side of the heatsink (with anodizing removed).  Do you think it's ok this way?  Perhaps I should bench test it awhile and see how it holds up (I do have an extra driver).  Also seems I better bench test my other driver and see if the outputs match the first driver (of course I can only measure at 12v - I had to order fuses online as I refused to pay $8 for two fuses locally). .
EDIT - If I am at 1.66A with an R500 added, what would I add (instead of the R500, not on top of the R500) to get to 1.8A or 2.0A?
EDIT #2 - I have these 0.5R from FT, are these the same as R500?
EDIT #3 - Ah, yes.  Verified 0.5R is 0.5 ohm (same as R500).  Now if I can find them in on my workbench in one of those envelopes!!!
-Garry
RaceR86
RaceR86's picture
-Garry
Same SKU from KD, just not the same sample as in OP. Do not ask me why I saw slightly higher output.
Yeah, the resistor you linked to from FT was the same as I used.
Not sure if I followed you in edit 1. But you want to see 1,8A+ and you only want to use one resistor.
If you have something in the R330 - R430 range you might want to try one of those. If not, R500 will give you a little increase. I don't know your input current though. As said, R500 gave me roughly 0,3A increase from what I started with..
garrybunk
garrybunk's picture
RaceR86 wrote:
-Garry
What I meant was, if I am getting 1.36A emitter current at 12v now with no add'l resistors, what would I add on top of the R120 to get to 1.8A or even 2.0A?
I have 0.5R, 0.22R, & 0.12R as far as low value resistors go.  What would adding a 0.22R instead of the 0.5R do?
-Garry
RaceR86
RaceR86's picture
I would just put on the 0.22R and see where that takes you. Just make sure you see the emitter amps when you turn on the driver. Some drivers work in mysterious ways, so just be ready to turn it off in case you get very high current for some strange reason. Always test on a emitter that you do don't care about. Again, in case the driver work in mysterious ways.. Silly
Id guess you need around that 0.22R in order to get where you want to go. I have not done the math though. Give it a shot..
Oh, dont blame me if something goes bad..  0:)
photon1k
photon1k's picture
Last seen: 4 years 7 months ago
Ohm’s law in different forms can help you here.
1. E = I x R
2. R = E / I
3. I = E / R
1. SenseVoltage = StockCurrent x StockResistance ***(from unmodifed driver)
2. TotalResistanceNeeded = SenseVoltage / DesiredCurrent ***(Desired modification)
To calculate the total resistance of multiple same value resistors just divide one resistor value by the number of resistors used.
Example: .5R + .5R + .5R + .5R = .5 / 4 = .125
To calculate the total resistance of multiple different value resistors:
TotalResistance = 1 / ((1 / RValue1) + (1 / RValue2) + …)
Example: .2 R + .5 R = 1 / (1 / .2) + (1 / .5) = 1 / (5 + 2) = .14
I find this easiest to do by setting it up in a spreadsheet and then just plugging in the values I know.
Edit: This is the theory, and assumes that the other components of the driver can handle in the increase current. I have found it to be a pretty good predictor in the few drivers I’ve modified. Your driver may react differently. Smile
garrybunk
garrybunk's picture
Exactly the response I expected! Smile . I'll post back my reading if/when I get to it.
-Garry
garrybunk
garrybunk's picture
Ugh! Last time I listen to you! Yell Installed resistor (its smaller than the R120 original). Tested with a single Li-ion @ 4.14v gave 1.68A. Connected to car battery and within a second "POOF"! Dead! Driver outputs test showing a short (0.2 ohms) and the LED won't light direct drive from an 18650. Ugh!
Think I'll leave the remaining two drivers alone.
-Garry
Gj
Gj's picture
Be ye warned what happens when mere mortals tamper with powers beyond their ken.
garrybunk
garrybunk's picture
I really didn't expect this to happen.  Does it make sense?  Or do you think I might have done something else like overheat the new resistor when I soldered it on?  Since the new resistor was smaller than the original, I had to "drag" solder across the top of the bottom resistor to connect to the new one.  Here is a pic but I don't know that you can tell much (pic prior to burning up the driver), best I could get with my phone:
1
The black lead is coming right over top of the sense resistor I added.  You can see my solder blob to the right side of that resistor where I "drug" the solder over top of the bottom resistor.
-Garry
RaceR86
RaceR86's picture
Garry, you did not listen to me. I said specifically, do not blame me. Silly
As for what happened? Too much power for something probably happened. Shit happens when limits get pushed too far.
This is a new close up of my driver with the resistor. (looks the same as the on pictures in OP)
If you are going to buy a new one, you might consider to try this. 1,8$ if you find a 10% coupon.
Btw, is there a reason why you can not use this?
garrybunk
garrybunk's picture
The first link - that's what I bought originally and am using now.  The second link - I forgot about that driver.  Biggest issue I see is that I need a "pill" of some sort to mount the driver in.  I would also really like to get rid of the next mode memory.
-Garry
garrybunk
garrybunk's picture
Ah, FastTech does have a "driver pillar" which takes a 22mm driver and should have about 15mm depth.  $3.96 each though, so this & 2 new drivers raise the price of my build.  I won't pursue this until someone can remove that next-mode memory on that driver though!
-Garry
