Copper MCPCB Mods
35 posts / 0 new
Nightbird95
Nightbird95's picture
Last seen: 1 year 8 months ago
Copper MCPCB Mods
After reading the results of djozz’ 20mm XML ledboard tests, I was convinced to go ahead with my planned copper MCPCB mod.
I started with drilling 2.5 mm holes in the dielectric layer of the copper MCPCB:
Here’s the front view of the copper MCPCB with the 2.5 mm hole. Yeah the holes are a little off centered but that’s the best I could do with the available tools:
Here’s the back view of the two copper MCPCBs with the holes:
To fill the hole, I used the copper from an AWG 10 wire:
Since the AWG 10 wire is 2.588 mm wide, I filed and sanded it until its fits snugly into the MCPCB holes:
I filed the edge of the copper wire before hammering it to the MCPCB holes. Here’s the front view of the copper MCPCBs with the AWG 10 wire fitted:
And the back view. The first MCPCB has its bottom (with the AWG wire) filed. I did not file the second MCPCB yet for comparison:
Here’s my finished mods beside two copper SinkPads:
And here’s the back view of the modded copper MCPCBs and the copper SinkPads.
Yes my modded copper stars are not as smooth as the SinkPads but I bet they should perform just like SinkPads and Noctigons. Smile
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
Nice!
Great modding work!
Nightbird95
WarHawk-AVG wrote:
Nice!
Djozz did the same thing, well minus the drilling, he used a knife to cut the center out, scraped the dielectric layer to raw copper, then filled the space with molten solder
Either way..great modding job!
Thanks WarHawk-AVG! Smile
WarHawk-AVG
Doh…I edited it beacuse you already mentioned you used Djozz’s method
Either way…excellent work! And nice drill press
Nightbird95
Yeah no problem. The drill press isn’t mine. I just requested a friend who has one to drill the holes for me. :bigsmile:
I’ll be doing the same with my aluminum MCPCBs and based on the results of djozz’ tests, I don’t think I’ll be needing to buy SinkPads or Noctigons for XM-L anymore. The dielectric strip of XP stars are very narrow and I don’t think I can drill a hole without messing the positive and negative contact points so I’ll have to try it yet. Smile
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
Good mod! Glad to see more budget mods around.
I never see single core wire that large around here. Every home wiring seem to have multiple smaller cores, probably to prevent AC skin effect. So I cannot do this mod without the material.
But I do look forward to see your aluminium version – that will be ultra-cheap mod with highest gain per $.
Nightbird95
Thanks Pulsar!
There’s plenty of those single core wires around here and they’re usually used in the electrical connections (lights, AC outlets, etc) of our homes. Actually I just ‘salvaged’ that wire from an AC outlet of a room which was destroyed by Haiyan last November. We need to ‘rewire’ before our electric cooperatives agree to re-energize our homes so I’m sure I won’t run out of AWG 10 single cores for my mods. Silly
Yes I’ll post my modified aluminum MCPCBs once done. My copper MCPCBs ordered from eBay won’t arrive till next month so I have all the time to mod my aluminum stars. Smile
djozz
djozz's picture
Last seen: 18 min 38 sec ago
Well done, it is nice to see people even more budget-minded than me, and less lazy Smile
Nightbird95
LOL! Thanks djozz. Without your tests, I couldn’t have done it. Smile
_the_
_the_'s picture
Last seen: 5 hours 25 min ago
Nightbird95 wrote:
Sliced fingers in 3, 2, 1, ... Sealed
That pic just reminds me of some of my own mistakes.. Would be better to secure the star with two screws (or anything else than your fingers) if/when the drill bit gets stuck. Wink
Other than that, thanks for sharing. Seems like a good method for enhancing non-conductive copper stars. Smile
=the=
Nightbird95
the wrote:
Nightbird95 wrote:
Sliced fingers in 3, 2, 1, … Sealed
You’re absolutely right!
This post left me pondering for a while. If the drill can go through that copper then it can certainly go through all my fingers like hot knife through butter. Shocked
The copper star also gets very hot during drilling. One wrong move can certainly lead to disaster. Oops
Thank you _the _ for pointing this out. Better safe than sorry. Beer
ImA4Wheelr
Nice work Nightbird.  I think some people assume you did this because you are cheap.  I do things like this too but for different reasons:
  1. There is a certain joy in building something for the lowest cost possible.
  2. Trying something new (to me) just to see if I can do it.
  3. Curious how it will work.
  4. OK, yeah, because I am cheap.  I save the good stuff for high current projects
Of course, the amount of time invested is a cost, but this is a hobby and not a business.  I'm curious why you think you did this particular mod.
It looks like you may have scraped off the dialectic layer.  Did you?  I would be inclined to leave it (other than the drill hole) because it helps with bringing your copper plug closer tot he led and because the mcpcb has a copper sheet on top of the dielectric layer that could also facilitate heat conduction.
Chloe
Chloe's picture
Last seen: 5 years 3 months ago
Nice mod! ^^ Resourceful mods like this can be more rewarding than buying pre-fab parts.
If you have a pair of thick jeans or an old leather belt you could buff the stars to a more polished finish.
Nightbird95
Of course, the amount of time invested is a cost, but this is a hobby and not a business.  I’m curious why you think you did this particular mod.
Yes I attempted to scrap the dielectric layer of one copper MCPCB but did not finish it because I decided to go ahead with this mod. I left the dielectric of the other MCPCB intact.
I long wanted to try this because from what I observed on SinkPads, a rectangle hole is punched in the MCPCB and this is plugged with a rectangular copper piece which fits snugly in the hole. This can be replicated by simply drilling a round hole in the copper MCPCB then plugging the hole with copper. I have AWG 10 single core wire with me so the the best thing to do is drill a hole big enough for the AWG 10 to fit snugly. Wink
I did all these because I love doing it, because I want to ‘improvise’ and because I want to try things that are new to me. Per djozz’ tests, aluminum SinkPads are not far behind in performance so my next project is doing this same mod to my aluminum MCPCBs. Not that I’ll be able to use all the modded aluminum MCPCBs, many of which are the former stars of some of my lights modded with SinkPads, I just love doing the modding. Smile
And yes I am cheap! This is a Budget Light Forum after all. :bigsmile:
Nightbird95
Thanks Chloe!
Actually I use an old leather belt in ‘maintaining’ the sharpness of my blades. And yes this is very effective in buffing the stars. Thanks for pointing this out. Smile
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 6 days ago
  1. wire is used between the main panel and sub panels and also for electric ovens and dryers. Last year someone did this to a triple 20 mm using either #12 or #14 so I tried using it to link a 10mm aluminum mcpcb to a copper plate. I had the same difficulty centering the hole but if you file the edge of the wire before pounding it in you can repair the dam between the pads with fujik or JB.
Scott
Nightbird95
Rufusbduck wrote:
#10 wire is used between the main panel and sub panels and also for electric ovens and dryers. Last year someone did this to a triple 20 mm using either #12 or #14 so I tried using it to link a 10mm aluminum mcpcb to a copper plate. I had the same difficulty centering the hole but if you file the edge of the wire before pounding it in you can repair the dam between the pads with fujik or JB.
I simply used the Mechanic Chips Repair Soldering Paste from FastTech to fill up the imperfections after the wire is fitted. I also filed the edge of the wire before inserting it to the hole because this would be very hard to do (without destroying the contact points) once it is already fitted in the MCPCB.
Regarding the triple 20 mm, were they copper or aluminum? Did the mod result to the desired results?
Rufusbduck
Aluminum and I think so. It was done about the time copper boards were coming around but still no copper triples so someone did the wire mod instead. Machinists like MRsDNF were milling out the center pad and dropping the star over a custom heat sink with a raised center pad.
Scott
ImA4Wheelr
Cool idea about doing this to aluminum stars for future projects.  I bet this mod can be done pretty quick after you do a couple.
Nice tip about polishing with leather or jeans Chloe.  Gotta keep that one in mind.
comfychair
comfychair's picture
Last seen: 5 years 5 months ago
http://75.65.123.78/6XL2/Dsc06972.jpg
~.080" holes drilled, top & bottom of holes chamfered:
http://75.65.123.78/6XL2/Dsc06974.jpg
http://75.65.123.78/6XL2/Dsc06975.jpg
12AWG pieces are a light press fit. Clean off all the solder on the topside so it can be laid down flat, then hammer the pins from the backside only - that way the LED side won't need any filing or sanding afterwards.
Before riveting:
http://75.65.123.78/6XL2/Dsc06977.jpg
After:
http://75.65.123.78/6XL2/Dsc06983.jpg
http://75.65.123.78/6XL2/Dsc06996.jpg
http://75.65.123.78/6XL2/Dsc06980.jpg
http://75.65.123.78/6XL2/Dsc06997.jpg
The chamfer on both sides of the holes lets the copper spread out and fill in the space, which leaves a flange on either side that locks the pins in forever.
Pulsar13
Pulsar13's picture
Being in international forum, I would like to highlight the difference in living standards.
Before anyone think about people being cheap or anything, it could be because some really couldn’t afford as much.
For example – the median wage for the US is about $50k while in Malaysia it’s $10k. That’s 1/5th purchasing power.
This is not exact, but quick calculation would bring it to this – would you have bought the copper Noctigons if they are 5 times the price e.g $8 apiece? No? Probably you’d still buy some to try out but not as much of course.
If there exist a way to use current aluminium or cheap dielectric copper board, we’d be glad to go that way, even if it means some mod is necessary.
Rufusbduck
I’ve go no problem with cheap. It’s a part of DIY.
Nice job CC.
Scott
musicmagic
Last seen: 6 years 8 months ago
Nice job CC.
+1
can you tell the difference in heat transfer?
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
Rufusbduck
In my case, not really as it’s in a solitaire which heats up quickly anyway. I’ll almost certainly continue to use this technique on occasion.
Scott
Nightbird95
~.080” holes drilled, top & bottom of holes chamfered:
12AWG pieces are a light press fit. Clean off all the solder on the topside so it can be laid down flat, then hammer the pins from the backside only – that way the LED side won’t need any filing or sanding afterwards.
Before riveting:
After:
Cool! 8)
So this is the right way to do it. I’ll follow this technique. Thanks comfychair! Beer
Nightbird95
Well said Pulsar13! Beer
Anyway, I don’t mind what others might think as long as I don’t offend anyone and I enjoy what I’m doing. I also think that many of us here think the same way too. Smile
WarHawk-AVG
Before riveting:
After:
Absolutely gorgeous job! Love the chamfer and riveting approach
Excellent job as always comfy!
All done with a drill press?
Reminds me of those copper core aluminum heatsinks for CPU’s
comfychair
WarHawk-AVG wrote:
Absolutely gorgeous job! Love the chamfer and riveting approach Excellent job as always comfy! All done with a drill press? Reminds me of those copper core aluminum heatsinks for CPU's !http://www.frostytech.com/articleimages/200706/intelC2Dstock_nofan.jpg![...
Those Intel HSFs work nice too.
http://75.65.123.78/Dsc05697.jpg
Nightbird95
comfychair wrote:
WarHawk-AVG wrote:
Absolutely gorgeous job! Love the chamfer and riveting approach Excellent job as always comfy! All done with a drill press? Reminds me of those copper core aluminum heatsinks for CPU’s !http://www.frostytech.com/articleimages/200706/intelC2Dstock_nofan.jpg!
Whoa! Shocked
Wat is dat? :~
comfychair
Nightbird95
Cool! That’s one bright LED at 9000-9500 lumens specs. Shocked
