FastTech New Arrivals & Promotion
1248 posts / 0 new
fasttech
fasttech's picture
Last seen: 2 min 52 sec ago
Convoy 4×18A 5400LM 5700K LED Flashlight
Luminus SBT90.2 LED / 9-mode / 4*18650 / USB-C charging / 1122m beam range / temperature control
Head diameter: 69mm Tube diameter: 50mm Waterproof level: Life waterproof Low voltage warning: automatic power off Illumination: Maximum 314.7KCD Reverse polarity protection: None, the positive side of the battery should be facing the head Mode operation instructions: Click the button -> flashlight is turned on with last brightness -> press the button, brightness ramping up -> release and press the button again, brightness ramping down Flashlight off, press the button -> moonlight mode 0.01A (0.2%) (This brightness will not be remembered) Flashlight on or off, 2-click the button -> turbo 100% Flashlight off, 3-click the button -> strobe Flashlight off, 4-click the button -> tactical mode, only 100%, 4-click the button again to quit tactical mode. Flashlight off, 5-click the button -> voltage detection (* means “flash”, *** suspend ******* means 3.7V ) Flashlight off, 6-click the button -> ramping mode switch to 4modes 1%-10%-40%-100% Flashlight off, 10-click the button -> Lock mode, The flashlight will flash once under any operation, which means the flashlight is locked. 10-click the button again to quit lock mode, please note that this is the only way to unlock. Please note: If you put the flashlight in a bag, be sure to loosen the connection between the battery tube and the head. Otherwise, the flashlight may be turned on by mistake, which has a risk of burning the contents in the bag. Please use a USB Type-A to USB Type C cable and 5V adapter to charge the battery. battery should be facing the head
FASTTECH - LED Flashlights, Lasers and Electronics
fasttech
fasttech's picture
NEXTORCH TA30 MAX 2100LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 6-mode / USB-C charging / IPX8 / 250m throw
Max 2100 lumen blinding high light and 250m flood-light long shot; the patented dual-function tactical switch can access to momentary on or one-step strobe under any working conditions by halfway or fully pressing the switch; rotational magnetic switch around the tail cap for easy one-handed mode switch; strike bezel embedded with super-hard nano-ceramic beads to efficiently break car windows.
TA30 MAX comes with a USB Type C direct-charge 21700 battery, to reduce the frequency of changing batteries, more environmentally-friendly; 5000mAh large capacity, to ensure the long endurance and lower battery anxiety
Waterproof: IPX8 (Submersible to 2m) Head diameter: 38mm Tube diameter: 28mm Impact resistance: 2m
fasttech
fasttech's picture
NEXTORCH TA41 2600LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 7-mode / USB charging / IPX8 / 272m throw / nano-ceramic strike tip
USB direct charge design Super hard ceramic strike tips: Escaping from car windows & close quarter defense Waterproof: IPX8 (Submersible to 2m) Impact resistance: 2m Head diameter: 38mm Tube diameter: 27mm
fasttech
fasttech's picture
ARCHON J2 2-in-1 1000LM 6500K 100-Meter Diving LED Flashlight w/21700 Battery
Luminus SST20 LED / green laser / 7-mode / 100-200m throw
Head diameter: 46mm Tube diameter: 28mm Angle of light beam for White light: 10’ With battery over-discharging protection Operation voltage: 4.2V to 3V
fasttech
fasttech's picture
TANK007 TC01 800LM 6500K LED Flashlight w/18650 Battery
Cree XM-L2 LED / 5-mode / IPX8 / 200m throw / glass breaker function
Head diameter: 34mm
Tail diameter: 29mm
Voltage: 3.7-4.2V
Impact resistance: 1.5m
fasttech
fasttech's picture
Nitecore HC65 V2 1750LM Triple Output LED Headlamp w/18650 Battery
Luminus SST-40-W 6500K LED / 4500K & red LED / CRI ≥90 / 11-mode / 1*18650/2*CR123/2*RCR123 / USB-C charging / IP68 / 165m throw
Enter coupon code MAP on the shopping cart page to see our unbeatable price.
Flashlight modes: Primary White Light Turbo > Primary White Light Hi > Primary White Light Mid > Primary White Light Lo > Primary White Light Ultra Lo > Auxiliary Red Light Hi > Auxiliary Red Light Lo > Auxiliary Red Light Flashing > Auxiliary White Light > Beacon > SOS Waterproof: IP68 (Submersible to 2m) Impact resistance: 2m Max beam intensity: 7000cd 100’ wide range flood beam 180’ all-round adjustable Elastic and breathable headband with silicone sweat diverting strip Highly efficient constant current circuit (non-PWM) ATR (Advanced Temperature Regulation) The power indicator can display the battery voltage (+/-0.1V)
fasttech
fasttech's picture
WUBEN E12R 1200LM 6500K Camping Light LED Flashlight
OSRAM P9 LED / 6-mode / 1*18650 / USB-C charging / IP68 / 179m throw / power bank function
E12R delivers up to 1200 lumens with a beam throw of up to 179 meters, it can be used as a camping light or floodlight. It utilizes a 18650 Li-ion battery with a circuit protection board, which has a run time of up to 173 hours. Premium temperature control design Waterproof: IP68 (Submersible to 2m) Impact resistance: 1m
fasttech
fasttech's picture
Black Friday & Cyber Monday Sale 2021 – Sitewide 12% Off! Code: BFCM2021
Hey, guys!
Here comes the 2021 FastTech Black Friday & Cyber Monday Big Sale! FastTech offers a 5-days promotion that saves up to 15% on your order!
Blowout 1:
Black Friday & Cyber Monday Sitewide Coupon
Offer: Sitewide 12% off
Valid Date: Nov 25, 2021 – Nov 29, 2021 (UTC-6)
Coupon Code: BFCM2021
Blowout 2:
FastTech gift card limited offer: Get gift card 3% Free
Buy FastTech Gift Card Now →
Agro
Agro's picture
Last seen: 9 hours 25 min ago
Fasttech, any news about shipping knives to EU?
fasttech
fasttech's picture
TANK007 UV-AA02 3W 365nm UV LED Flashlight
1-mode / 2*AA / IPX8 / 50m throw
UV-AA02 has multiple uses as below: Check the leaks in an air conditioner or automobile circulatory system Crime scene inspection of marks or blood Treasure and minerals search; antique appraisal Ink curing and glue curing Identify counterfeit bills Gas leaks inspection Spot the fluorescence of special substances LED Lifespan: above 20,000 hours UV Intensity: 9000μW/cm2 (38cm), 56500μW/cm2 (15cm) Voltage: 1-3.6V Chip characteristics: Constant current circuit chip which maintains constant brightness Anti-dropping height: 1.5m Tail diameter: 21.2mm
fasttech
fasttech's picture
I am sorry to tell you that there is still no shipping method that can ship knives to the EU.
fasttech
fasttech's picture
TANK007 UV-L03C 365nm UV LED Flashlight
1-mode / 1*18650 / USB-C charging / IPX8 / 50m throw
Head diameter: 26.7mm Tail diameter: 24.6mm UV intensity: 52000uW/cm2 (15cm), 11000uW/cm2 (38cm) Voltage: 2.8-4.2V Waterproof: IPX8 (Submersible to 1.5m for 30 minutes) Impact resistance: 1.5m UV anti-counterfeit lamp Low carbon and eco-friendly; High power which equals to output supplied from 150W high voltage The polymerization isn’t effected by high temperature High thermal conductivity copper substrate – heat dissipation performance Constant-current: Keep the stable output within 1A for protecting LED lifespan. Specialized black filter lens: 99% stray light filtered by specialized UV filter black lens, which makes fluorescent inspection easier, faster, and more reliable. Since tail emission is visible as deep violet light, adding the UV-A pass filter eliminates the glare and makes the background of the part surface darker. This increases the contrast between fluorescent indications and the darkened part surface when using fluorescent magnetic particle or penetrant techniques.
fasttech
fasttech's picture
TANK007 UVC31 365nm UV LED Flashlight w/US Charger
Nichia LED / 1-mode / 1*18650 / USB-C charging / IPX7 / 50m throw
Head diameter: 40mm Tail diameter: 26mm Voltage: 3V-4.5V Anti dropping height: 1.5m LED Lifespan: Above 20,000 hours UV intensity: > 72000uW/cm2 (15cm), > 30000uW/cm2 (38cm)
fasttech
fasttech's picture
fasttech
fasttech's picture
TANK007 UV122 400LM 6500K 365nm UV LED Flashlight
Cree XP-G2 & UV LED / 3-mode / 1*18650 / USB-C charging / IPX7 / 200m throw
Dual LEDs (Lighting +UV Detection) UV light mode: Non-destructive testing of special gas, oil tubes, machines, etc. Crime Scene Investigation of fingerprint, blood, sperm, flammable chemicals, etc Conservation and restoration of artworks, antiques, etc. Anti-counterfeit detection of documents, passports, ID cards, etc. Biological research, treasures and minerals hunting White light mode: Outdoor lighting, hiking, exploration, camping, etc. UV intensity: 52000uW/cm2 (15cm), 9100uW/cm2 (38cm) Waterproof: IPX7 (Submersible to 6.5 feet or 2 meters for 30 minutes.) Anti-drop height: 1.5m Head diameter: 35mm Tail diameter: 26mm
fasttech
fasttech's picture
Nitecore UT27 520LM 5700K & 3000K Dual Output LED Headlamp w/2*Battery Packs
authentic / 2*Cree XP-G3 S3 white & 2*red LEDs / 7-mode / 2*battery packs/3*AAA / IP66 / 128m throw / 90’ adjustable / APC technology
Equipped with a spotlight, floodlight, and auxiliary red light with a max output of 520 lumens Spotlight uses a Cree XP-G3 S3 LED (3000K) and a TIR optic lens with a max throw of 128m and a max peak beam intensity of 4,120cd Floodlight uses a Cree XP-G3 S3 LED (5700K) and a TIR optic lens with TrueVision Technology for an ultra-smooth flood beam Powered by a proprietary Li-ion battery pack and compatible with 3*AAA batteries HLB1300 rechargeable Li-ion battery pack (1,300mAh) included with a built-in USB Type C charging port Glow-in-the-dark battery compartment for easy battery replacement and location A highly efficient constant current circuit provides a stable output of up to 13 hours Dual switch design for easy access to various light sources, brightness levels, and modes Power indicators can indicate the remaining battery power Advanced Power Cut-Off (APC) technology for an ultra-low standby power consumption 90’ adjustable tilt angle for various lighting needs Specially designed lightweight and breathable headband and diffusing stuff sack included Waterproof and dustproof rating in accordance with IP66 Impact-resistant to 1 meter Lockout Mode: Both buttons will be locked in lockout mode to prevent accidental activation so that the UT27 can be stored or transported in the pocket or the backpack.
fasttech
fasttech's picture
TANK007 CI05 395nm UV LED Flashlight w/18650 Battery
authentic / 1-mode / USB-C charging / IPX7 / < 50m throw
Professional applications:
Crime scene investigation, forensics, inspection, searching, laboratory research, etc. Preservation, conservation, and inspection of artworks, antiques, paintings in the workroom, on-site visits, artworks center, museums, galleries and auctions, archives, private conservation studio, etc. Anti-counterfeit detection of banknotes/passport/ID cards/documents, etc.
LED Specifications:
UV intensity: 6200μW/cm2 (15cm); 950μW/cm2 (38cm)
Spot Diameter:
Diameter 150mm (at distance of 300mm)Diameter 250mm (at distance of 500mm) Diameter 500mm (at distance of 1000mm) Uniform light spot without dazzling or stray light, uniformity >= 93%
Circuit Specifications
Voltage: 3.0-4.2V Circuit characteristics: Constant current chip/constant brightness. Charging indicator: Solid red when charging, solid green when fully charged; power less than 20%, the indicator flashes one time per second.
Physical Specifications:
Head diameter: 33mm IPX7 waterproof, work normally for 30 minutes when immersed in 1m water. Anti dropping height: 1.5m Please note: Avoid direct exposure to the eyes or skin, UV light may harm your eyes or skin. Children should use it under the supervision of adults.
