Required battery type: 18650 lithium battery which can bear 5amps current
Driver: maximum current output 5000mA in 12 group mode, internal temperature protection management
12 groups:
Click the switch to turn on / off the flashlight, touch the switch to select the mode
If the flashlight is on, tap the switch 20 times quickly to enter setup mode. (In a visual interface, whenever you click an option, it means that the option is selected. The flashlight has no visual interface. It blinks to represent an option, and “touch the switch in the process of blinking” means to select the option. )
Option 1 (normal-flash 1 time + buzz-flash): Touch the switch to enter the sub-option to select the mode group, if the user has no operation. Configuration mode will enter option 2.
Option 2 (normal-flash 2 times + buzz-flash): Tap the switch to activate the mode memory or inactive, if the user has no operation. The flashlight will enter the last mode.
PayPal payment is not available for my order – so I’m out . I’m not purchasing e-cigs or Li-ion products what goes on here?
Hi Paul321,
You can contact our Customer service to manually create an order and send a PayPal link to you. Thank you.
I sorted this out I bought a gift card with PayPal for the balance of my order and then used the gift card to complete the order.
I’m good right now, I just have to wait.
We are glad to hear that this issue has been resolved. Shall you have any questions, please do not hesitate to contact us. We’re always here to service you.
FASTTECH - LED Flashlights, Lasers and Electronics
Low voltage warning: automatic power off
Required battery type: 3*21700 batteries (without protective plate)
Head diameter: 69mm
Battery tube diameter: 51.8mm
Please note:
Reverse polarity protection: None, all the positive poles should face the head, otherwise, the battery will be burnt.
If you carry the flashlight in your bag, please loosen the battery tube half a turn to prevent the flashlight from accidentally lighting up and burning the valuables in the bag.
Convoy S2+ EDC LED Flashlight
12-group / 50-100m throw / 5A output / SMO reflector
12 groups:
Battery check Instructions:
<2.95 V (1 flash)
2.95-3.25 (2 flashes)
3.25-3.55 (3 flashes)
3.55-3.85 (4 flashes)
> 3.85 (5 flashes)
Paul-
Convoy 3×21B 12000LM LED Flashlight
3*XHP70.3 Hi LEDs / smooth/stepped ramping / 3*21700 / USB-C charging / 529m throw / 70kcd
Head diameter: 69mm
Please note:
