Cree changed production process for XP-G2 emitters!
541 posts / 0 new
FmC
FmC's picture
Last seen: 8 months 3 weeks ago
Interesting to see what kind of current these will handle.
Pretty sure they will be popping before 6 amps, though.
BobbyMK wrote:
I wonder what this led can do @ 6A in the GT. 2Mcd maybe?
The_Driver
The_Driver's picture
Last seen: 2 weeks 6 days ago
FmC wrote:
Interesting to see what kind of current these will handle. Pretty sure they will be popping before 6 amps, though.
This test from Köf3 shows the maximum possible brightness (I supplied him with the LED, it was a real one):
His sample seems to have an especially high Vf.
FmC
FmC's picture
From memory (which isn’t always that good), I think the problem I was having was with the buck driver spiking briefly at turn-on, which was blowing the bond wires.
The_Driver
That is possible. Some people had that problem with newer XM-L2 LEDs around two years ago. I would just set the buck driver to 5A and try that. The brightness difference is not visible anyway.
Jerommel
Jerommel's picture
Last seen: 8 months 2 days ago
luminarium iaculator
luminarium iaculator's picture
Last seen: 13 hours 41 min ago
Jerommel wrote:
Still 180 pcs in stock:
https://intl-outdoor.com/cree-xpg2-s4-2b-bare-led-p-885.html
LOL. I guess I was wrong Smile
ZozzV6
ZozzV6's picture
Last seen: 2 weeks 1 day ago
Just tested it in my L2 dedomed. 316 kcd and 975 lumens.
eas
eas's picture
Last seen: 11 months 3 weeks ago
I notice it is still showing 180pcs in stock, 6 months later.
ControlTheController
ControlTheController's picture
Last seen: 2 months 3 days ago
Now it’s still 180pcs in stock…
Umm, I want lumens but I want CRI too...
Guys save your money for better emitter. It is coming soon(very soon). That is all I will say for now.
Edit:
New throw king is OSRAM KW …. something
And of course you can buy it at L4P place here
I had already made some builds with it… Some of you wants test and numbers but that is not necessary. Numbers are here:
B158 Brinyte 430 kcd!
Mitko’s super reflector thrower 430 kcd!
Other 50mm aspherics (copyfire and similar) 300+ kcd!
Is that enough for you? Beer
Yes good old G2S42B is still good and more lumens but with new emitter dedoming is matter of past. With this Osram kids could make super thrower lights.
Although I am happy but at same time I am bit sad cause de doming made me feel that I am capable to make something unique after all. With new throw king emitter it is that easy as slap and play… Yes Smile Beer
ZozzV6
ZozzV6's picture
Edit:
Facepalm And I got my first 5 black flats today and putted two in a GT mini and a Convoy L2. Now I need to order these….
LOL… Yes you need Beer It is better, nicer and most important:
“The biggest difference compared to BLACK FLAT is thermal pad, which is ELECTRICALLY NEUTRAL, this means you can use this LED with any standard XP DTP boards – there is no need for LED PCB/driver GND isolation!”
ZozzV6
ZozzV6's picture
I literally finished the GT mini an hour ago.
Just to metion to everybody that you can use it with FET drivers also but you need to have low current cell like LG BD118650 or those Panasonic or Sanyo GA.
It will pull around 5.7 -6A on low current 18650 and more than 7.15 on Samsung 30q or better.
Worth to mention that performance will start to drop after 6A so don’t use it above that mark!
But the best would be linear driver with around 5.5A current draw.
One thing to mention… At 3.3A current draw little king gives same performance as the best G2S42B emitter at 4.8A!
Yes you heard that right…
You could easily have old g2s42b performance at only 3.3A draw and of course plenty… Really plenty of run time on single 18650 cell Thumbs Up
djozz
djozz's picture
Last seen: 56 min 46 sec ago
But the spot size will be less than the S42B.
nofearek9
nofearek9's picture
Last seen: 1 day 9 hours ago
anyone did a revied those led ,performance chart OSRAM KW Vs S42B chart? djozz ?
djozz
djozz's picture
Since these leds are pre-production samples exclusively available via led4power and only announced a day ago, there are no nice charts yet. But led4power has done some testing himself and gave the relevant numbers, and l.i. has done some very succesful mods. That should get people started prepared enough.
Is such a chart much needed?
nofearek9
nofearek9's picture
so its time to upgrade my courui d01 kd reflector
You sent a payment of €24.85 EUR to RA ELEKTRONIKA
Yes spot size is smaller…
Yes… Guys you don’t even have to afraid of direct driving these with fet drivers just use low current 18650 cells. I guarantee that Thumbs Up
But of course Samsung INR30Q or better high current cell could potentially kill it. As I said i did 2 minutes continuous test with 30Q and it survived. It pulled over 7A of current… Djozz and Ko3fe will do proper test anyway.
I would say that sweetspot for best performance is around 5.8-6A anything above and performance starts falling.
But if you’ll drive it to from 3.3-3.5A you will still have lux performance as best G2S42B! Isn’t that cool? Especially for smaller reflector or smaller aspheric lights?
Enderman
Enderman's picture
Last seen: 6 hours 36 min ago
How do you know they are pre production?
Several distributors already have them in stock.
Mouser doesn’t have them in stock but you can still purchase them as individual units.
https://octopart.com/search?q=KW%20CSLNM1.TG&start=0
Jerommel
Jerommel's picture
They have been produced, so how can it be pre production? Party
Jerommel
Jerommel's picture
Then you can use a shorter focal length aspheric, or put a pre-collimator lens in between, less light wasted, larger spot size with roughly the same intensity.
It will be good with smaller diameter optics too.
djozz
djozz's picture
Maybe l4p used some marketing talk here, but it says so on his site: “Limited pre-series production in stock!”
Well I know that certain guy from UK got exclusive on Osram 4715as(infrared) emitters. So bigger dealers can get pre-production series for testing that is for sure and 1000 pcs reel is like sample order or something like that.
If they find you interesting they will send if not they will reject offer.
Enderman
Enderman's picture
Oh, weird, idk.
led4power
led4power's picture
Last seen: 1 day 7 hours ago
It says on label: "Pre-series production", I guess that means they made several reels of those for customer testing purposes before they started mass production(it takes ~3months to make them).
Enderman
Enderman's picture
Huh interesting
AlexGT
AlexGT's picture
Last seen: 2 days 15 hours ago
led4power wrote:
It says on label: “Pre-series production”, I guess that means they made several reels of those for customer testing purposes before they started mass production(it takes ~3months to make them).
Not familiar with these, What Cree comparative tint are the LEDs? Will it cost an arm and a leg to have them shipped to the USA?
Might want to give them a try on some of my small EDC’s
Thanks!
AlexGT
eas
eas's picture
Check his site, led4power.com, for shipping options and costs.
