DBSAR Lantern Mini-Review: -Zanflare T1 (UPDATE: Second T1 failed!
182 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 2 years 2 months ago
JasonWW wrote:
Jerommel wrote:
Would be fair though, to test it with the cell it came with and see if the problem still occurs.
And for good measure, test it with a Japan made cell.
Just to make sure it’s not your old battery.
That would NOT be fair. It should be tested with a wide variety of cells.
Isn’t that what i said then?
Testing with the old cell, with the cell it came with, and with a Japan made cell.
Quote:
It is either safe with all 18650 (like all devices using that size battery on the market) or its not.
I have some old laptop pulls i don’t use anymore, and although they keep their charge and have a decent capacity, they can get quite hot under load.
Although this light probably draws only some 1.3 Amperes max, an old low drain cell may heat itself up a little, additional to the poor thermal path of the light itself..
Anyway, meanwhile DBSAR did test it with an ‘old cell’, the stock cell (or not?) and a Japan made cell, and it still gets quite hot.
I’m thinking about the spring now, in the tailcap.
I’ve read reports of crappy springs, probably iron, with the chrome / nickel flaking off.
Dunno if those may get hot while conducting 1.3 Amperes.
ggf31416
Last seen: 2 days 19 hours ago
Calm down, there is no conspiracy here. DBSAR and JasonWW are well-known users with thousands of posts. For sure they don’t have a secret agenda to trash or promote Gearbest/Zanflare or some other company.
There is clearly a serious issue in some units that needs to be fixed, but not all units are affected. OTOH a Convoy S2+, with a 8×7135 driver on high, heats as fast or even faster (edit: source) and we don’t hear about batteries flaming inside them, so the cell likely had some defect to start with (i.e. the issue only becomes critical if the lantern has this overheating problem and the cell is weak). However, since people are likely to put any 18650 cell on the lantern, including fake no-name 9800mah cells that belong to the trash, this issue that affects some units needs to be addressed.
Coscar
Coscar's picture
Last seen: 3 hours 46 min ago
There has been a lot of these sold. What we need is some accurate readings from other users. Im guessing the temps will be acceptable unless it is a defective unit or a defective battery is used and if that is the case, it would be on the User. Improvements could be made and a disclaimer should be included.
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
RobertB
RobertB's picture
Last seen: 1 day 17 hours ago
Just tested the Fenix CL25R (NCR-GA battery). After 20 minutes, the cap heats up to 91ºF (32C). So yeah, I think it is a feature for cold weather. Even in warm weather, it’s still 140ºF+ away from any thermal runaway potential.
joechina
Last seen: 4 hours 21 min ago
In post 40 are readings from a german forum
http://budgetlightforum.com/comment/1373877#comment-1373877
Coscar
Coscar's picture
Lux-Perpetua wrote:
A member of the German TLF just checked his Zanflare T1 with the original batteries. He also used an IR thermometer. These are the results:
Discharge start @ 4.12V, maximum brightness in coldwhite:
o IR-temp. on tailcap: 0:00h 25°C, 0:15h 41°C, 0:30h 48°C, 0:45h 51°C, 1:00h 51°C
o IR-temp. after 1:00h on battery inner tube, max. 10s after interruption of operation / removal of battery: 53°C, 3.7V resting voltage
That’s lower than even I thought it would be(51°C after an hour)………. and definitely acceptable
A little John Prine
sb56637
sb56637's picture
Last seen: 5 hours 13 min ago
Wimpy Water wrote:
you cannot be for sure that manufacturers and affiliates are not within this Forum.
Hi, as the administrator of this forum I can assure you that there are indeed both manufacturers and affiliates here in this forum. We make no attempts to hide that fact. Whether that affects any particular user’s judgment and/or opinions is up to each individual:
BLF Rules wrote:
8. All opinions expressed by users of this website may or may not be accurate, and as such BudgetLightForum.com does not officially endorse them. BudgetLightForum.com does not encourage risky behavior, and will not be responsible for physical, emotional, financial or other damages resulting from the use or misuse of any information or misinformation expressed herein. All users are encouraged to use good judgement before making any physical, financial or other decisions based on the information or misinformation expressed on BudgetLightForum.com.
So please drop the “deep forum” conspiracy theories. And please stop arguing:
BLF Rules wrote:
1. Please don’t be rude. Rude people will have their accounts deleted.
4. Please avoid fighting. If you or somebody else is losing their calm, please drop the subject.
Thanks.
Coscar
Coscar's picture
Boy……. sure got quiet all of a sudden Sushi …….. Anyone else have temps?
A little John Prine
Lightbringer
Lightbringer's picture
Last seen: 2 hours 36 min ago
Guess we’re all now homeless from our burned-down houses after the testing. Evil
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 9 months 3 weeks ago
bansuri
Last seen: 4 days 12 hours ago
If anyone wants to modify theirs without destroying it I’ve managed to get the diffusor top off and retain 3 of the 4 locking tabs.
Wrap your thumb and index finger around the white section right above the black base.
With your other hand, crush your index finger into the diffusor while lifting up slightly.
Work your way around the light a couple times and it will eventually pop free.
The adhesive is very weak and you will hear it separating. Be careful when it does pop free because that’s when one of the tabs may break.
Sorry if this has already been addressed.
I was thinking of putting an insulating layer and a heatsink between the emitter strips and the battery tube. Or gutting it and doing something else with it.
With some of the issues I’ve seen it’s not good for gifting but could be a nice host.
edit: this thing looks like a sci-fi prop from a few years ago with the cover off! Kinda harsh on the eyes but may leave it like this for a while.
JasonWW
JasonWW's picture
Last seen: 1 week 9 hours ago
Keep in mind the heat has to get out some how. The battery tube and tail cap is about the only way it can do that.
I’m off work and can do some tests on my two lights. I only have a temp probe from my DMM, though. I guess I can insulate my finger and hold it up against what I’m measuring. Will that work?
I need a good IR thermal reader that’s not too pricey.
JasonWW
JasonWW's picture
Okay, here is how I tested my two lights. One used the stock battery and the other an Evva brand protected Panny B 3400mah (69mm). Both fully charged.
Ambient was 25°C. Lamps where laid in their side.
I let them run about 10 to 12 minutes at a time, then checked the tail cap temp, the inner battery tube temp and the battery temp (the negative electrode was the hottest part). I probably lost a good bit of heat just from checking every 10 minutes so at the 40 minute mark I decided to let it run 20 minutes continous to try and max out the temps.
I took amp draws before the test with each cell and ran all tests on the CW setting as that seems to pull the highest amps.
Here’s how and where I measured. The bare aluminum on the tail cap seemed to be the hottest part.
The two batteries.
All the temps seemed to be pretty accurate. They steadily climbed and then stated to level off. There are a couple measurements at 30 minutes that are a couple degrees cooler than before. Those might be anomalies. It’s tricky getting the probe to press against things hard enough so they might be about 2° too low.
Anyway, here are the results:
I hope you guys can understand them.
Max tail cap temp was 54°C.
Max battery tube inner wall was 55°C.
Max battery temps were 52°C. It was hard to hold them. This might be a safe battery temp, but I still don’t like it. I’m certainly not used to it.
I stopped testing after 60 minutes since the temps were leveling off. If they had run for 60 minutes continous (no interrupting to check temps) I think all temps might have gone one or maybe 2 degrees higher. I’m not sure. Both batteries were in the 3.6v range after the tests so their output might have have been going down. Total runtime was probably closer to 75 minutes. After recharging both batteries, the capacity added to each was right at 1480mah.
About the battery temps, it seems like the heat shrink acts as an insulator not only electrically, but also thermally. I suspect most of the heat is going through the tail cap, up the spring and into the bottom of the battery. It’s an all metal heat path so conduction is good.
Some of the heat probably comes through the plastic heat shrink, but not most of it. It’s just not a good conductor. This is my theory, at least.
The positive electrode was the coolest. It only makes contact with the upper circuit board, not the battery tube.
The_Driver
The_Driver's picture
Last seen: 7 hours 18 min ago
52°C is not a problem. It actually improves performance, especially in the cold.
Zulumoose
Zulumoose's picture
Not good test conditions, the problem is obviously going to be more evident when the light is standing on a non thermally conductive surface, not lying on its side generating a convection current past the hot spot with cool air.
Beam me up!
Pete7874
Pete7874's picture
Last seen: 6 hours 56 min ago
Below are my temperature measurements, using a fully charged Samsung 30Q cell. I ran the test for 60 minutes, measuring every 10 minutes with an IR thermometer. The measurement is the highest temperature observed on the base of the lantern, which was not actually the tail cap but a spot on the base just to the side of the tail cap, for some reason. Temperatures leveled off and started dropping from about 60 mins onward.
I ran the test twice:
(1) Base Temp 1 lantern position:
(2) Base Temp 2 lantern position:
The lantern was sitting on top of a speaker cabinet. Starting/ambient temp was 25 deg. C.
teacher
teacher's picture
Last seen: 3 years 18 hours ago
Thanks Pete, that looks like another well done & documented test… with decent results as far as the lantern goes.
Same goes for you JasonWW… well done with excellent documentation. Thumbs Up
JasonWW
JasonWW's picture
Sorry. Maybe I’ll do that the time time I’ve got a chance to measure again.
Maybe I’ll just let it run 40-50 minutes straight on a hard wood surface then measure the battery temp.
JasonWW
JasonWW's picture
The most important thing is the battery temp, right?
Is it safe to assume the battery temp is always going to be a few degrees cooler than the tail cap temp? That’s what it seemed like on my tests.
So I’m guessing Petes batteries got up to 53°C or 54°C?
Pete7874
Pete7874's picture
My battery temp did not exceed 50 deg C.
JasonWW
JasonWW's picture
So your batteries ran at least five to six degrees cooler than your tail cap temperatures? Interesting.
Was the hottest part of the battery the negative base plate?
tatasal
Last seen: 6 hours 54 min ago
My T1 arrived today. Now fully-charged in the office, I will simulate the above 60-min test with my ir meter later tonight when I’m home.
Would you believe that the ‘Weather Station’ clock/thermometer/humidity/barometer is a product of Henry Xu of Opus?
Photo below shows the closeness of the ir’s reading to the Inside Temp of the Weather Station.
Later tonight I will start the 60min temp reading test..
Started the discharge test at 8:17 @ room temp of 26.8cel : (lantern standing on wood table during the duration of the test, except when taking temps)
After 17min., IR temp reading at 43.7c:
After 36min. : 52.3c
After 48min: 55.9c
After 1hr, 1min.: Temp started to decrease by 1.2degrees to 54.7c
After 1hr, 2min: Temp steadily decreasing to 53.1c
Removed cell while light is still on, cell temp 51.4c, Cell voltage: 3.66v
Definitely just fairly warm for electrical components standards, so it’s safe to use using even with the unknown OEM cell that came with it.
Zulumoose
Zulumoose's picture
Well it appears, from Pete’s results, that the battery tube gets hotter when the light is upside down, which seems odd. This would seem to indicate that the heat concentrating at the tail cap is not due to that being the bottleneck of heat dissipation. If that were the case the light would cool more effectively upside down.
This makes me think that the outside diffuser is dissipating much more heat than it is given credit for, obviously it won’t appear as hot, as it has a much larger surface area. Maybe not such a bad design then, just slightly overpowered for its overall heat dissipation capability?
Beam me up!
tatasal
Just concluded a discharge temperature test on post 114. Beer
Pete7874
Pete7874's picture
My bad. I must have measured cell temp incorrectly before. I re-ran the test (lantern in position 1), and after 60 minutes, lantern base was at 56 deg C, and cell temp was 56 deg C as well. This was the temp on lower half of the cell. The upper half was cooler.
Cell was at 3.83V at the time of measurement.
teacher
teacher's picture
Thanks tatasal for posting your test results. Good info & well documented…. Thumbs Up . Beer
tatasal
Cool
JasonWW
JasonWW's picture
DBSAR, what kind of conclusions have you made about this temperature related issue on the T1?
In our own tests it seems most of the battery tubes never exceeded 60°C and the batteries themself seemed to range from 50°C to 56°C. (I haven’t had time to sort through all the posts)
You reported 67°C in your battery tube, right? Do you think your T1 was an anomaly or maybe we should test these lights in a hotter environment?
I looked at a few battery data sheets to see what kind of temperature related info I could find. It seems there is a regulation Per UL1642 that says cells have to withstand 130°C without exploding or burning. Edit: I see that the Panny B has an 80°C limit.
An operating range of up to 60°C surface temp seems to be the norm for most cells.
Do you think this means the T1 was built within the safety specs and your T1 had an issue? Even as hot as your battery tube got, your battery should not have been anywhere close to its danger limit.
Samsung 35E:
3.12 Operating Temperature (Cell Surface Temperature) Charge: 0 to 45°C – Discharge: -10 to 60°C
9.4 Heating Test
Test method: To heat the standard charged cell at heating rate of 5°C per minute up to 130°C and keep the cell in oven for 10 minutes. Criteria: No fire, and no explosion.
Sony VTC6:
2.6 Allowable Environment Temperature Charge 0~+60℃ - Discharge -20~+60℃
2.8.2 Discharge Conditions
Discharge at cell surface temperature below 80℃.
I couldn’t see a max heating test.
LG MJ1:
2.9 Operating Temperature Charge 0 ~ 45℃ Discharge -20 ~ 60℃
4.5.4 Heating Test
Cells are charged per 4.1.1 and heated in a circulating air oven at a rate of 5ºC per minute to 130ºC. At 130ºC, oven is to remain for 10 minutes before test is discontinued (Per UL1642).
Specification: No explode, No fire
Samsung 30Q:
3.11 Operating temperature (surface temperature) Charge : 0 to 50℃ (recommended recharge release < 45℃) Discharge: -20 to 75℃
9.4 Heating test
Test method: To heat up the standard charged cell at heating rate 5℃ per minute up to 130℃ and keep the cell in oven for 10 minutes. Criteria: No fire, and no explosion.
Sanyo/Panasonic 3400B and 3500GA
5.12 Operating Temperature
Charge 0 ~ +40℃
Discharge -20 ~ +60℃
(2) High Temperature
“Do not use or place the battery near fire, a heater or a high temperatures (more than 80℃).”
The battery’s polyolefin separator may get damaged from the heat and could cause an internal short circuit. This may cause the battery to catch on fire, smoke, explode, or
cause heat generation.
JasonWW
JasonWW's picture
It looks like Wimpy Water got removed from the forum (I wonder what he did). I wish he was here so he could apologize for accusing me of sweeping these temperature related issues under the carpet. He was way paranoid. Facepalm
HKJ
HKJ's picture
Last seen: 1 month 1 day ago
JasonWW wrote:
Cells are charged per 4.1.1 and heated in a circulating air oven at a rate of 5ºC per minute to 130ºC. At 130ºC, oven is to remain for 10 minutes before test is discontinued (Per UL1642). Specification: No explode, No fire
In this test venting is allowed, i.e. the cell is not usable after this.
The 60°C rating is not really maximum there is some safety included. This can be seen from some cells where the specifications allows up to maybe 80°C when using thermal cut-off.
