Zebralight SC64c LE w/High CRI Nichia 219B R9080 $150
157 posts / 0 new
Calzoner
Last seen: 1 month 6 days ago
Thumbs Up Thumbs Up
Bob_McBob
Last seen: 13 hours 19 min ago
Invoices all sent out for the new batch of lights Smile
Bob_McBob
Update: I am currently building lights. My new method is to build one light at a time from start to finish, generally one or two per day at most. I do them in the order I received inquiries and sent invoices, and I will PM you when your number is up and try to send a couple teaser photos as well. I’m being more methodical about getting them done now so all current orders should be cleared in the next 1 1/2 weeks or so. Just watch out for a PM Smile
Also, I have a handful of LEs in stock to mod that are unspoken for. They are a fair bit easier to acquire now Zebralight is finished transitioning from the original XP-L2 model.
Bob_McBob
Here’s an interesting option I’ve been wanting to try for a while. This is a dedomed 5000K Samsung LH351D “dog fart” (SPHWHTL3 DA0GF4RTS 6). Nothing fancy, just a razor blade slice without any polishing.
The stock SC64c LE looks pretty decent on H1. I’ve tested quite a few, and they usually sit in the range of Duv 0.0004-0.0008 with CRI ~9070. Lower outputs get increasingly green with slightly higher CRI. Good examples are usually around 0.0033 at L1 (fairly green), while the worst one was 0.0061 (very green).
Djozz’s testing has shown that slicing the LH351D tends to lower CCT and Duv and create a pleasantly rosy tint. The “dog farts” seem to behave a little differently in that they lose a lot of CCT, have more CCT variation, but also end up quite rosy on low modes. In the SC64c, H1 is is a very nice Duv -0.0005 at CRI 9151, and by L1 it’s -0.0031 and CRI 9675. Because the “dog farts” are a higher flux bin, H1 output is about 690 lumens vs. 745 lumens for a stock LE even with the dedoming loss. This isn’t an ultra rosy sw45k, but it has a great tint at any level and maintains most of the stock output. Because it’s a dedomed LED, throw increases from 123m to 165m, the hot spot is smaller, the big blobby corona typical of LH351D is greatly reduced, and the spill is less purple. If a customer desired, I could trim the dome to the edge of the die to increase throw even more at the expense of corona and spill.
I’m interested to know what everyone thinks of this option. Is the SC64c DF something you would like to be able to purchase?
clemence
clemence's picture
Last seen: 9 months 2 days ago
Now I know you didn’t made up the “dog fart” terms. It’s actually the real part number….
All this time I thought it was you Facepalm
Bring it down lower the BBL Bob, shave closer to the phosphor layer Silly
[Clemence]
Pavlo
Last seen: 6 hours 14 min ago
Very cool results with the slicing of the Samsung LED.
I have read this LED is fairly floody. How does the sliced version compare to the 219b in terms of beam profile?
Bob_McBob
Pavlo wrote:
Very cool results with the slicing of the Samsung LED. I have read this LED is fairly floody. How does the sliced version compare to the 219b in terms of beam profile?
It’s similar to the 219B but the edge of the hot spot is more focused. Quite different from the stock LH351D with its blobby corona and larger hot spot. I’m going to take some comparison beamshots tonight to demonstrate better. Unless you really can’t deal with the smaller hot spot, it’s much nicer than the stock LE because the tint is great at every level rather than just H1.
Buzzy243
Buzzy243's picture
Last seen: 6 days 21 hours ago
clemence wrote:
Now I know you didn’t made up the “dog fart” terms. It’s actually the real part number…. All this time I thought it was you
Don’t blame it all on poor Bob. Those degenerates on /r/flashlight are the ones who noticed the DA0GF4RT part# for the 5000K and started giggling about it like middle schoolers.
Bob_McBob
In the home stretch! I decided I do a better job of finishing everything up when I press them in a big session so these are otherwise finished lights (well, except for the one with the loose driver) just waiting to be pressed and shipped.
goshdogit
goshdogit's picture
Last seen: 3 hours 47 min ago
Keep up the good work, Bob! Thumbs Up
How many of these have you modded now? Any catastrophic fails along the way?
I use mine every day and am still wowed by the tint.
I was already a fan of Zebralights and 219B sw45k emitters, so this light is definitely in my top three favorites.
If anyone is on the fence about getting one of these, do it!
Bob_McBob
I’ve done…. maybe 30? A couple dozen for customers, but also a handful of my own personal lights. I have one completely dead light and one that misbehaves, but my success rate has generally been quite high. I’m also using a much more gentle reflow method I’m really happy with now. No takers on the dedomed LH351D yet, but I rather like the one I built for myself. A significant improvement on the regular LE since the tint is awesome on every level, not just turbo. I also recently built a 219B Zebralight H53 which is a neat little light. 165 lumens with an sw45k 219B.
https://imgur.com/a/YecNaby
Bob_McBob
Sometimes it doesn’t quite go as planned. This component was ripped off the bottom of the board because it was encased in excess adhesive used to hold the positive lead in place. Possibly repairable if I’m willing to put hours of effort into it and carefully reflow the entire board on both sides, but obviously not saleable anymore. There’s absolutely no way to avoid this kind of loss.
In more positive news, I shipped some lights today, and more will follow over the next day or two Smile
Bob_McBob
Heading to the post office to drop off three lights. If all goes as planned, three more tomorrow! You should receive a shipping notice from PayPal if yours was shipped, but please let me know if it’s missing a tracking number it should have.
Calzoner
Can’t wait for my tracking notification!
Thanks for your hard work Thumbs Up
Calzoner
Can you please send me tracking? My PayPal notification did not have it.
Thank you
Bob_McBob
I had a family emergency this afternoon and won’t be able to deal with any modding stuff for several days. Please rest assured any outstanding orders are essentially ready to ship, I’ve just been taking some time to understand an issue I was having. I should still be able to reply to PMs if anyone has any concerns.
Xenophon
Last seen: 2 years 1 month ago
Mr. Bob_McBob:
So sorry about the family emergency. Hope all works out OK.
Just received my Zebralight mod after it walked through Canada. I just wanted to tell you publicly what a wonderful job you did on a light I’ve always wanted – simply beautiful.
Big thank you for your efforts, expertise, and the kindness you’re showing your fellow flashaholics.
And for anybody on the fence: This is just what you wanted it to be. Looks and acts like factory, and subjectively much brighter than expected. This is a great, professional service he’s offering.
He even includes some perfectly-cut d-c fix, which was appreciated as I often use my EDC for a photo-fill light, but didn’t want to commit to a floody. This emitter produces great skin tones – just a richer, I don’t really want to say pink, mostly more accurate and warmer tone, and if you need to, you can correct it down a little and achieve truly superior results. It’s certainly not magenta-ish like an older digital SLR, just richer. Mine was a 45sk.
Thank you again! And good luck with your family.
jon_slider
jon_slider's picture
Last seen: 8 hours 45 min ago
x2
my heart goes out to the McBob family
and major respect to Bob for breaking the Nichia Barrier on Zebras, and offering my favorite LEDs
WTB Novatac Pocket Clip
mjgsxr
Just received my modded zebralight. I went for 4500k with frosted glass. I have to say it’s the best beam I’ve ever seen out of a zebralight( own 15+ ). This will be my new edc. Would you consider modding an 18650 powered zebralight headlight with a nichia?
Hope everything works out ok for you and your family.
Rdubya18
Rdubya18's picture
Last seen: 2 hours 44 min ago
Paypal ship notice received . Thanks Chris . Hope the family stuff is going well .
maukka
maukka's picture
Got my light as well. Wonderful job, Bob_McBob! The 219b is a funny emitter. Unlike the 219c or SST-20 it always looks good, no matter whether it’s on the BBL or significantly below. The sw35 in mine is quite perfect.
Output on H1 at ~30sec: 434 lumens.
Bob_McBob
Thank you for the kind words here and via PM. It has been a rough couple weeks, but nobody died or anything that serious, and things are looking up a little.
I’m pleased to say all outstanding BLF orders are now shipped. As usual, if you selected a tracked method, I don’t have any idea whether PayPal actually sent you the tracking number, because that’s how they roll. I will go through my records tonight and send tracking numbers where appropriate just in case.
noboneshotdog
Good to hear things are looking up for you Bob!
+1 regarding would love to purchase a 219b ZL headlamp! Thumbs Up
Thier ain’t no bones in a hot dog. F. York
Bob_McBob
I would love to be able to offer a Nichia Zebralight headlamp, but the only model with the correct pads and driver voltage is the H53. I built one of these to test, but it’s limited to about 165 turn-on lumens with the floody version. I personally find it a somewhat unsatisfactory mod to actually work on compared to the SC64c because you have to smash the glass, which does some (non-functional) damage to the exposed edge of the reflector and also requires using one of my limited stock of replacement lenses. Unfortunately with the 18650 models, the only possible emitter swaps are either a different XHP35 or XHP50, and the high CRI XHP50 models are good enough there isn’t anything better available to swap in.
This all comes down to the integrated driver Zebralight has been using since about 2011. The LED pads are on the driver itself, so you have to use an LED that fits the pads and has the correct voltage. Zebralight used XM-L2 in almost everything before switching to XHP, both of which have few worthwhile emitter swap options. The SC64c and the other XP-L2 models only exist because of the quirky requirement Zebralight used to have for tint binning with the high CRI models. The XP-L2 EasyWhite is guaranteed to be extremely green at 4000K, but it was the only option that met their tint binning requirement. It’s literally the only reason 3V Zebralight models with standard XP pads exist. The SC64c and the various AA models are the only ones that support the 219B, LH351D, SST-20, etc. Since Zebralight follows spec sheets religiously, we even got lucky with the SC64c being limited to 3A, which is right on the upper end of somewhat acceptable for the 219B with the excellent thermal management.
On the plus side, Zebralight came to their senses and changed the SC64c to LH351D after I posted my original Zebralight mod. It’s still a bit green on the low settings, but much better than the XP-L2 EasyWhite at any level. But, not an R9080 219B of course.
(Warning: this album contains a video with strobing lights)
noboneshotdog
Thanks for the explanation Bob. You are doing great work.
Headlamps are my go to for work. Just dreaming of one that had such a nice emitter as the 219b.
Do you know of a high quality headlamp that would work w the 219b? If so, maybe you can PM me and we can work out the details to purchase this mod. Wink
malkoff junkie
malkoff junkie's picture
Last seen: 1 day 12 hours ago
E21A would be nice if possible now…
Malkoff !
Calzoner
I received my sw45 last night and its everything I hoped it would be-really fantastic! Big thanks to Bob_McBob for this excellent service! I hope anyone who is on the fence, jumps on this great opportunity before its too late Smile
The_Driver
The_Driver's picture
Last seen: 23 hours 4 min ago
Basically the ultimate EDC light for us snobs. Smile
noboneshotdog
Hey Bob, hope you are doing well.
Are you able to do a triple Nichia with optics.
Bob_McBob
I just received a new shipment of lights. There are three unspoken for if you’re on the fence Beer
