Sofirn C01S SST-20 4.000K 95CRI / Low-High version available again!
859 posts / 0 new
MoreLumens
MoreLumens's picture
Last seen: 34 min 17 sec ago
Unheard wrote:
There was a question which inexpensive honeycomb TIRs would fit:
Left: Original optics, right: ‘AE’ optics
https://aliexpress.com/item/32989679045.html
$1.18 incl. s&h, 5 pcs.
It is not the quality of those TIRs someone found in Bulgaria (artifacts at the white wall), but you’ll see no artifacts in real situations. Much, much better than the original optics with its rings. Can recommend them.
Nice find and good pics! (Cleaned your link a bit so it won’t mess up language settings.)
What degree optic that is? 60 or 90? My C01R has waited something like this.
Unheard
Unheard's picture
Last seen: 6 hours 21 min ago
45°
Smile, you cannot kill them all.
Agro
Agro's picture
Last seen: 1 min 3 sec ago
Maybe these Yajiamei lenses would work as well?
Cemoi
Last seen: 7 hours 25 min ago
@Unheard: how did you manage to open the head and hence swap the optics?
It seemed to me it was glued and therefore impossible to open.
Ultrafire C3 2AA / Akoray K-106 / Nitecore LR10 / Manker E03H / Fenix HL10 / Zebralight H501R + H51W + H53c / DQG Hobi / Astrolux M01 / CooYoo Quantum Ti (lost) / BlackWater Kite Al / Emisar D4v2 (Nichia E21A) / Sofirn C01S / Skilhunt E3A
Unheard
Unheard's picture
There’s red threadlock. Brute force and maybe heat helps.
Agro
Agro's picture
Disappointing. Sad
Unheard
Unheard's picture
Agro wrote:
Disappointing. Sad
It’s very little threadlock. Sofirn just made sure the pill won’t stuck in the battery tube when loosen the head. This problem has been reported a few times.
Cemoi
The pill doesn't seem to be screwed in the head, but force fit (judging from the two notches).
So you need to pull it out with a tiny screwdriver tip, correct?
Pictures of the process would be helpful wink
SammysHP
SammysHP's picture
Last seen: 3 min 22 sec ago
Cemoi wrote:
The pill doesn’t seem to be screwed in the head, but force fit (judging from the two notches).
What you see in the picture is the shell which holds and protects the optic. You have to grab the head at the threads and then unscrew the bezel.
Unheard
Unheard's picture
No, it is screwed.
Don’t touch the PCB. The threaded part is actually part of the pill.
Cemoi
Thanks SammyHP and Unheard, it's clearer to me now. So the way to go is to:
  1. Remove the O-ring,
  2. Gently heat with a hairdryer (hot enough?) or a cigarette lighter (not too close),
  3. Grab the thread with plyers, inserting e.g. a rubber sheet to protect them,
  4. Same for the bezel.
Correct?
Unheard
Unheard's picture
Yes. Before applying heat, see if you get it loose without. A lighter is very hot, not recommended.
Sari33
Last seen: 4 min 8 sec ago
https://de.aliexpress.com/item/32989679045.html?spm=a2g0s.9042311.0.0.41...
We talked about these 45° Lens,glad you like them.
The Beam is larger but also dimmed than stock lens. For outdoor I’ll try 20° or frosted 25° white holder that need be removed https://m.aliexpress.com/item/32982811233.html
Unheard
Unheard's picture
For outdoor, maybe the original optics will do. It gives a lot of throw. I recommend using a 219C at 4000K, that gives a nice beam and a larger hotspot. This is my only C01S still with original optics.
Sari33
Thought the Led die size on TIR lens had no effect for the hotspot width. Good to know it does Thumbs Up
Also,maybe in real there is small difference betwin frosted 25° and 45 ° lens
MoreLumens
Yes, ordered those optics + some 20 mm ones too. Total was only 0.6 € with coupon.
Also ordered GREEN C01S from Sofirn. Innocent
Cemoi
I had to apply moderate heat, using a hair dryer, then unscrew very hard using two pliers.
Once opened, I replaced the stock optic with a 20° Shamian (frosted) from Yajiamei Optics, like I did to successfully improve the beam of my Skilhunt E3A.
No more rings, but although I don't have a way to measure it, I notice a noticeable decrease in brightness WRT the original optic, both in direct lighting and in a ceiling bounce test.
A piece of DC film on the original optic gives as good a result on the beam, without any noticeable brightness loss.
Strangely I had not noticed such a dimming effect on the E3A with the Yajiamei optic, but maybe I did not compare both options carefully enough.
MoreLumens
Remember that also boiling water works pretty nicely to get glue loose. Did that when I swapped 219b into my Fenix MC11. Probably trying same trick with C01R when optics arrive if that is also glued. Min or two in boiling water and glue seems to soften and off goes the bezel.
