USB-C Charging lights that only work with a USB A to C cable?
34 posts / 0 new
nottawhackjob
Last seen: 16 hours 52 min ago
Geeeee wiz.
For some reason this thread reminds me of this thread…… LOL Shocked
https://budgetlightforum.com/node/78095
PS. Sorry, Amish. Not hijacking ya. I just couldn’t help myself. Wink
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
UNBLF
UNBLF's picture
Last seen: 19 hours 33 min ago
This is a big headache for me as well.
I’m in the process replacing all my cables w/ C – C and C – Lightning, thus eliminating A ports all together. However I found a ton of made-in-China (no prejudices, most of mine just happen to be made in China) small electronics w/ C-inputs only support A – C.
If you ask the manufacture of most lights w/ C-ports they’ll tell you they only support A – C charging, especially smaller brands.
*On The Road M4 – Fail
*Nitecore T4K – Pass
Lyyyyghtey
I routinely charge my Acebeam EC65 from an early Anker 12V charger having one C and 3 A outputs, using the C port to do it. The cable is a several-years-old one from Home Depot. From this thread it sounds like it’s the earliness of the Anker USB C charger that makes this possible, maybe combined with having randomly stumbled on a compatible cable. Ugh!!!
