OLcontest, modified light: 20cm fresnel lens thrower
127 posts / 0 new
PolarLi
PolarLi's picture
Last seen: 1 month 6 days ago
“Meet the Vir-O-blast C19”
This is my kind of humor Wink Really great build!
Scallywag
Scallywag's picture
Last seen: 2 hours 55 min ago
djozz wrote:
I bought it a few years ago actually, on aliexpress. They are cheap (under 10 dollar for a 20cm diameter lens) and pretty good, here is a link, I expect it to be the same quality as the ones I got. I chose 200mm focal length as a compromise between the amount of light catched by the lens, and image quality (a very short focal length lens will catch/transmit a large percentage of the light but also show a lot of image distortion at the edges which will negatively affect the beam and throw).
https://m.aliexpress.com/item/32650652778.html?spm=a2g0n.productlist.0.0...
I just wanted to thank you for this build and the fresnel lens link. I’ve ordered a few sizes to try out and I think this will really scratch my thrower itch. Who knows, one of the lenses could even end up in the next OL contest…
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
MtnDon
MtnDon's picture
Last seen: 2 hours 10 min ago
Thumbs Up Me too!
djozz
djozz's picture
Last seen: 1 hour 56 min ago
Nice! I have two findings for these plastic fresnel lenses:
1) the focal distance should not be much shorter than the lens diameter (maybe a focal distance equal to the diameter, as I used in the viroblaster is close to optimal), otherwise the the edges of the lens makes such a bad image that it is wasted for forming a good focal image and throw is ruined.
2) their imaging is pretty good but not good enough for very small light sources: it makes a mess of my LEP flashlight (stock lens removed) and I’m not sure that a White Flat will produce a good image (bad image=bad throw). I could test that btw one of these days.
Skylight
Skylight's picture
Last seen: 1 hour 46 min ago
So leds with big die size would be better? Is it noticeable in the projection if the led has a quad die, for example a XHP70?
I have an Amutorch TC500 with fresnel lens and White Flat 1. The beam is said to throw 1000m but it is quite colored in vicinity.
Scallywag
Scallywag's picture
For one of the smaller lenses I ordered, I’m thinking of trying my dedomed XM-L2 behind it. I recall for your thread (and re-read before I ordered) you mentioning the focal length a bit.
