LUMINTOP THOR I LEP (Alu & Ti) Group Buy
400 lumens | 1200m Throw Distance | 342,000Cd+
Our Test Results
Do account 10-15% margin of error for all our measurement values.
GROUP BUY PRICING:
Titanium (polished/ stonewashed)
Price: $209.97 (usual $279.95)
Freeme's Coupon: Reply below
Aluminium Black / RAW
Price: $124.50 (usual $166.00)
Can't wait for our reply??
Price: $254.95 (usual $299.95)
Freeme's Coupon: NDNA
Price: $153 (usual $180.00)
Since the button is flat and 12mm wide, it is not difficult to balance the light in upright position. However, it will only work on flat surfaces.
Specifications
ANSI/NEMA FL1 | LOW | MED | HIGH |
OUTPUT | 30 Lumen | 150 Lumen | 400 Lumen |
Runtime | 2H 20MIN | 58M | 5M+ 40M* |
INTENSITY | 342000cd (Max) | ||
DISTANCE | 1200m (Max) | ||
IMPACT RESISTANCE | 1m | ||
WATERPROOF | IPX-8, underwater 2m | ||
SIZE | 96*32*22.5mm (Length*Head Ø*Tube Ø) | ||
NET WEIGHT | 102g (Aluminum) | ||
LIGHT SOURCE | White Laser Emitter | ||
POWER | 9W (Max) | ||
BATTERY | 1 X 18350 Li-ion (excluded) |
Notice: The above appropriate parameters are lab-tested by using a 3.7V/900mAh 18350 Li-ion battery, it may vary due to the difference of environments and batteries. *The runtime on High is accumulated due to the over-heat protection setting.
Operation Instruction
ON/ OFF: Fully press the switch for ON, fully press again for OFF. The auxiliary rear light is ON when the light is OFF.
Output change: From ON, half-press the switch to change outputs.
Mode memory: Turn on the light again after 3 seconds off will recall the last used output.
Warning!
1) This device is a super high-intensity flashlight. To avoid potential injury, it is forbidden to shoot directly to the eyes.
2) Keep away from children.
FOREVER COPYCAT
https://1thedeals.com/blf-flashlight-group-buy/
