[review] Sofirn D25L high-CRI headlamp, nice revision!
59 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 1 hour 17 min ago
The D25L is Sofirn’s newest addition to the dual-emitter D25 headlamp line. I already have the original D25, which I like, and having dual LH351D emitters is something I couldn’t pass up.
I’ve been using it a while, and quite like it. It’s the same dual-emitter setup as the original, has the same onboard charging, and is otherwise the same, so no big surprises there. But the benefit of having high-CRI (color-rendition index) emitters is great vs the usual lower-CRI emitters.
The headlamp comes in a really compact box, sturdy (folded over sides and a locking lid), nothing fancy but still secure.
sturdy Sofirn box (click the pic!)
Inside the box is the light itself with included cell (be sure to remove the insulation tab to use it) and headband as a unit, a folded-sheet manual, and 4 clips which look quite useful but I have no idea what they’re for. LOL
(Edit: apparently they’re to adapt the headband/headlamp to construction hats.)
D25L box and contents
As usual, the semigloss black ano is flawless with no dings or voids. No sharp edges on any fins, ‘though the corners around the emitter-box(?) feel a bit pointy, but not sharp enough to scratch or anything (you can press on the corners quite hard with your fingers and won’t get hurt). So just to be safe, though, I wouldn’t carry it in a pocket next to a cellphone screen or anything.
First thing is do is to remove the insulation tab from the included cell and charge the light. You have to unscrew the cap opposite the button, easy enough. Threads were a bit scratchy, so some more lube is definitely in order, but there was no binding or grabbing. The cell slides right out, everything reassembles easily, and the opposite cap is captive and only unscrews a few turns to reveal the nicely sealed charging port. Red while charging, green when done, the usual.
D25L headlamp, tailcap, and included cell
The UI (user interface) is quite simple. Single click for on/off, press’n‘hold to change modes, doubleclick for strobe. Okay, I have no idea why anyone would want to wear a headlamp while it’s strobing away unless you actually want to induce an epileptic fit, but it’s there, just in case. LOL Press’n‘hold increases through the 5 brightness levels, but if you let go and immediately press’n‘hold again, you’ll decrease through the 5 brightness levels.
Modes are very evenly spaced, which is useful. I’d prefer a shortcut to hold-for-moonlight, but low is okay. I’m a little surprised there isn’t the usual hold-for-moonlight and 2click for brightest, but zipping through 5 modes is fine. I usually just use the lowest level anyway unless I need something brighter. Silly
The beam is a nice wide circle, great for walking, but might be a bit narrow for close-up (eg, reading). There aren’t any artifacts in the beam, no nasty rings or cloverleafs or anything. The ’351 gives good color rendition, too. Lowest levels might seem a little greenish (as with all ’351s), but it’s not bad at all (and I really dislike green tints). Brighter levels, any hint of green disappears.
The headband is pretty comfortable, and I didn’t even adjust it but left it as it came, a bit snug but not squeezing my head. Big Smile It feels soft and almost cottony even though it’s quite elastic. The holder uses 2 ‘C’-shaped clips to hold the light snugly and without slipping, so you can tilt it up/down as needed.
D25L headlamp and detachable headband
So with just some lube on the threads and a tweak to the UI, it’s a pretty ideal little high-CRI light. It’s an all-in-one light, including the cell and having on-board charging, so there’s literally nothing else you need to get started. Nice!
All in all, I’m quite happy with the new addition to the family. Big Smile
chadvone
chadvone's picture
Last seen: 6 hours 25 min ago
Amazon question says it has a ML level. Are you saying it does not?
I am actually Okay with a 30 lumen low in a headlamp.
Does it bounce much while running or jogging?
Thanks for doing this review.
Lightbringer
Unno. Whut’s a “ML level”?
I don’t jog with it or anything, just grubble through things two-handy vs having a light in one hand and grubble with the other.
It fits pretty snugly for a 2-band light.
raccoon city
raccoon city's picture
Last seen: 15 min 15 sec ago
I think ML is moonlight.  :THUMBS-UP:
Lightbringer
Oh, amazon link is… https://www.amazon.com/dp/B095WH2V3W , in case anyone wants.
27bux – 10% clicky.
Lightbringer
Ach…
I just saw some light with actual bubble-levels(!), and was wondering wtf’s a “ML level”.
Gnope, just verified, 5 levels starting from low, 2click for strobling, another 2click for beacon, click out of it to normal light.
Didn’t see any mention of moonlight in the amazon page, unless I missed it.
xevious
xevious's picture
Last seen: 24 min 25 sec ago
Sofirn had this listed in a discount posting. Got a code from them, plus an additional coupon on the Amazon page… and I paid $17! I had a few other small items to buy anyway, so that put me over the free shipping threshold.
This is a screaming deal, all things considered. UI wise, I do miss press+hold for moonlight, which is becoming standard in many lights these days that offer this mode. Mode memory can be annoying. Tint is quite good. Cooler than my LH351D 4000K in my Zebralight, but separately the eyes adjust and it looks very neutral.
Headband comfort is OK, but I prefer my Thrunite TH20, where the bracket is silicon and easily conforms to your head—much more comfortable for long wears. Also, the TH20 is smooth all around, no sharp edges. As lightbringer said, the corners on the D25L aren’t rounded off, so they can feel like a potential to “dig in.” But that won’t happen when worn properly on your forehead. The metal casing is good with fine quality anodizing, though I’d say the TH20 feels a tad more solid. The switch has a florescent green rubber cover… would’ve been nice if it was GITD.
Again, overall? VERY nice value. I have both lights with me. If anyone wants a comparison photo of the two, let me know.
ShyOne
ShyOne's picture
Last seen: 2 weeks 5 days ago
“ML” is probably meant to be “Medium Low”… which is really “Med1”.
There is no Moonlight on the D25L.
Great review & thanks for mentioning the 4 clips. Those had me stumped.
I am really liking my D25L. ✅
stephenk
stephenk's picture
Last seen: 1 hour 21 min ago
Looks like a great budget headlamp. Personally I would prefer one LH351D and one Red (?SST-20 or XP-E2) emitter, maybe with the double click turning on the Red instead of strobe (who needs strobe on a headlamp?).
xevious
xevious's picture
You could always put a red filter over just one of the emitters…
Lightbringer
xevious wrote:
Goggled some pix of the TH20… looks a lot like the D10, predecessor of the D20 (?) and D25.
Sofirn
Sofirn's picture
Last seen: 9 min 15 sec ago
We’ll have the headlamp with white and red leds in the future.
Sofirn
Sofirn's picture
Thanks for your detailed review! LOL
slmjim
slmjim's picture
Last seen: 6 hours 1 min ago
The single-strap headband is a deal breaker for me.  Adding a additional over-the-head strap would move me to buy, even if it's somehow made removeable.
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
CR888
Last seen: 1 week 1 day ago
I have one of these on the way from Sofirn. I hate my Olight perun2 headlamp. It’s just too bulky/heavy. The upgraded D25S is a proven design & just works.
CR888
ShyOne
ShyOne's picture
slmjim wrote:
The single-strap headband is a deal breaker for me.  Adding a additional over-the-head strap would move me to buy, even if it’s somehow made removeable.
slmjim
That is what I first thought also… but I tried it anyway.
After using it a while, I do not miss the top strap one bit.
stephenk
stephenk's picture
That’s great news. Most headlamps with red are very dim (around 5 lumens), so a red light that is much brighter (but with low modes as well) would be greatly appreciated.
Tinman
Tinman's picture
Last seen: 4 days 9 hours ago
Top straps are highly overrated. This headband works very well.
Fescron
Last seen: 1 day 10 hours ago
Great to hear Big Smile Any idea when? A few weeks or months?
pennzy
pennzy's picture
Last seen: 8 hours 18 min ago
Press and hold only cycles up with my D25S and L.
Tinman
Tinman's picture
Once it reaches highest level release button. Quickly press again and it reverses. Just confirmed this with my D25S.
pennzy
pennzy's picture
Not mine .
Edit: I got it to do it. I was pushing it to fast.
Renato Azevedo
Last seen: 10 hours 40 min ago
[quote=Sofirn]We’ll have the headlamp with white and red leds in the future.
Nice!
Good to know you are reading and participating in this thread
Thanks for hearing the BLF
Wouldn’t want to bother but since you are already here how about a coupon code for this light ?
Lighten up
alpg88
Last seen: 1 week 5 days ago
if you own a 3d printer you can print your own holder for 2 straps, there are stl files available, made by gchart, https://budgetlightforum.com/node/66009?page=5 i designed some holders too, but for 1 strap, but a wider one, 35-40mm, i actually printed my own holders for all my headlamps to be used with wider straps, they hold better, never felt the need for a second strap with wide straps
Lightbringer
I still much much prefer the kind like is on my Boruit RJ02, ie, the one with the 2 rubber loops. No chance they’ll break off, easy to adjust up/down, self-adjusting as far as how much “grab” they have, etc.
The ones with the prongs, if they “stretch” out of place, they stop grabbing, and you’ll end up with puddle-illuminators instead. Worse, if even 1 prong breaks off, that’s pretty much it for the holder.
And one wrong bump, and the light can go flying off the holder. (Ask me how I know.)
The rubber ones pretty much last forever no matter how much abuse they take.
diablo2424
Last seen: 1 month 1 week ago
Thank you for the review, after doing some research, I am going to pick up one of these for my girlfriend for our next camping trip. I plan on ordering a Sofirn BLF LT1 as well for the campsite, so I’ll throw this in the cart too while I’m at it. Are there any coupon codes for the forum members?
EDC: RovyVon Aurora A28 Nichia 219C White/UV
Warm Light: Noctigon KR4 QUAD Cyan 4x SST20 4000k 95CRI Flood - SkyLumen Custom
RGB Light: Rayus A10 RGB
Thrower: Nitecore P16
Old EDC: Nitecore Tube EDC - Nichia 219
OG EDC: Nitecore Tip 2017 CRI
dthrckt
dthrckt's picture
Last seen: 7 hours 9 min ago
Please make this headlamp w/ 3 reflectors, instead of 2 – 1 white high CRI, 1 red 660, 1 UV 365.
Couchmaster
Last seen: 5 days 18 hours ago
Great write up Lightbringer. I love these Sofirn headlights. You can toss them in a backpack and not worry that the USB port fills up with floatsum from your pack. They’re too heavy for a runner, but for normal people out for a walkabout, the single strap/heavy light works fine. The origonal D25 might be the best price to quality ration stuff out there for any headlamps. Sofirn makes good stuff.
Sofirn has the D25S on sale with battery for an insane $13.99/ea right now. Looks like it’s 1 per customer and $3,99 shipping. Still a fantastic deal. https://www.sofirnlight.com/products/ship-from-usa-d25s-powerful-1200-lu...
Lightbringer
Good choice, as I really like the beam from the ’351s.
Dunno about any codes on Amazon, though, unless you ask Sofirn. There are a few deal threads here…
Lightbringer
So… basically stick a WK30 on a headband? LOL
dthrckt
dthrckt's picture
EXACTLY! wk30 is in the mail lol. maybe i’ll duct tape it to my hat.
