the hotspot of the triple is more than twice as large as the single emitter
and it takes more than twice as many lumens from the triple, to get similar illumination on a target
so I would say the throw of the triple is about half that of the single
but I have no way to measure throw, Im only guesstimating, based on the test posted here:
I found a shorter clip in one of my boxes from some older model Jetbeam and installed it. Aesthetically, it looks identical, but is much shorter. It fully clears the ring.
The new clip feels somewhat flimsier than the original clip. Not as good as the longer clip if you use the clip to actually hold the light to your belt or pocket.
As an anti-roll device the shorter clip is much better. It doesn’t interfere with the ring action. Since that’s pretty much all I ever use a clip for if I leave it installed, I prefer the shorter clip in this light.
I have a flat top 18350 and at first tried a 1x3mm magnet to get the contact to work on the RRT-01… but it was troublesome because while the brass contact point matches it, there’s open space around it so the magnet can slide off target while screwing the body together. I just got 1x5mm magnets and yes, this works really well now. I didn’t want to bother with applying solder to the battery, given how long it takes for me to drain the cell on this light (it’s not my EDC).
Apply a bit of solder to the center post at the top of the battery compartment.
Remove the Driver retaining ring at the top of the battery compartment and use an x-acto knife to carve down the plastic cover to expose the post.
Note that either of these solutions remove the phyiscal reverse polarity protection. Make sure to always double-check you are putting your cells in the correction direction.
Yeah, that’s why I didn’t want to make a permanent solution. The 1mm x 5mm magnet is excellent. It’s just thick enough to make contact, but thin and wide enough so as to not slide off contact.
I’ve had issue with the magnet solution in mine… it’s to be expected though, si on the positive since it’s a magnetic control ring !
I had some bumps from low to higher levels, with sometimes no light at all until half of the course…
Anyway, solder blob resolved that issue
You can put a tiny blob of solder on the brass contact of the driver, it’s permanent but reversible as you can remove it later with your soldering iron. Mine doesn’t need it, my flat top battery is protruding enough to make contact.
Received mine. Had to put a soft solder blob to use my with Vapcell 18350 1100mah. Not to impressed so far, prefer the old model styling. But the built quality s very good, I like the driver retainer ring, best I’ve seen. Clip is good, rather on the soft side but easier to use this way.
Measured only put out 770lm OTF lumens. Still running several runtime test now. So far, so bad…
I’ve tried the Jetbeam USB 16340 that they put in the box… only 2,6A and 680 lumens
Then I tried my 1200mAh KP 18350, the current jumped to 3,6A and the output to 920 lumens
The first battery had o problem. resting voltage was in the “save” recoverable 2,58V. The second battery died few minutes early from overheating. And you’re welcome, I did the test for all of us.
