5+5 or something like that ..
thanks for doing this VOB
Rufus...I can easily do this for you if you like? I'll work off what you've described above but if you can PM any extra details it will help.
- Matt
BTW, most 10mm hosts want a thin star. 1.5 mm might be too thick for some. I measured a couple at around 1mm
If it don’t fit, force it!
I have many modded small lights with a head that does not tighten fully (eg, the 10mm board mounted 219 from IS is a pain to get into a light), quite annoying, I agree that 1mm is a better thickness.
bump.
I'd be in for 20 & 20, IF I can be reasonably confident they won't send us the rejects and save the decent ones for themselves. :~
Hi comfychair,
I think that is a reasonable expectation.
I can only speak from my own experience but I have found sinkpads QC to be very good. I have purchased around 3000 pc from them so far. Each piece is tested and the rejects are clearly marked out with black ink, and none of those are ever counted toward the purchase total. I reflow and test around 50 or so emitters per month and very rarely have I ever got a board that was "bad" that had not been marked. Maybe 1 out of a hundred.
Thanks for sending me that info about the 7135 driver hack by the way.
Did you notice a skewing of the silkscreen on the 16mm parts? It's almost like the ones from the top left of the sheet were perfect, but going down towards the bottom right they just got progressively worse. Don't even think about using the 14mm & 10mm cut lines and expect the LED to end up in the center. The really bad ones aren't on center even without being cut down, on some I have had to file the OD smaller than the pill just to get the LED centered, the original OD isn't even right.
The good ones are really good, but some are pretty awful. The 20mm parts didn't show any f those problems, though I've only seen a handful of those.
Cutting down a 16 to 10 or 11, the circle marking 10mm was off. I like to re-flow the emitter first, use the dome to center the turning star. ( I JB Weld the star to a 1/2” aluminum rod, mount that in my cordless drill) By spinning the star with the emitter on it, it’s easy to see that the emitter is perfectly centered.
I haven’t done but a few, but noticed it on the ones I did.
PCB fabs accept silkscreen that is off by quite a bit. Thats normally ok tho since silkscreen is only meant for markings that don’t need exact alignment.
I believe I recall the original BLF 16mm design had the 10mm cutting guide in soldermask or copper even. Perhaps sinkpad nixed it?
It's not just the silkscreen, the LED is not in the center of the board on the ones that are 'off'. All the layers are off.
opened march 11 I placed a large order for 16mm copper boards here is the design [image] another but with out B.L.F. and with sinkpad written thereTHE BOARDS WILL NOT BE LIKE THIS (mixed) [image] Please post here what u bought and in the paypal note add your BLF NAME and what u bought they will be $2.50 each and $4 S/H in the united states Canada $6 everyone else $12.75 if u like tracking it will run u $12-14 if u need my zip code to calculate shipping or tracking its 43452 …
It's as if the file for the cut lines was resized to 800x600, and all the other layers were resized to 798x598, and aligned at the upper left corner.
An exaggeration, but like this:
I get what your saying now. I suppose I never examined them closely enough to notice the print was off. I was thinking more along the lines of if the board electrical connections were functional.
It seems to me like since there wont be any of the lines, rings, drawings etec on the 10mm boards we stand a pretty good shot of not having to worry too much about that, but others may be more sensitive to the issue ( like color tint for some of us).
I just cant really say there will be any guarantee like that. In the rare case of a bad non working board I could probly warranty it out of my personal boards, but for something like that they just sort of are what they are.
Comfychair I'd love to have you on board with us, but I fully understand if you are not comfortable with it. I have not put you on the list yet, but I'd be more than happy to if you say the word :)
LED is off center…?
Wow, good job sinkpad! S)
Your link just goes to the top of the page for me. :~ What is the comment#?
edit
I missed this part until now.
The really bad ones aren’t on center even without being cut down, on some I have had to file the OD smaller than the pill just to get the LED centered, the original OD isn’t even right.
i would do 10 of each to start out with
Its asking for a password to sign in.
Those aren’t links to email attachments, are they?
Signed up with microsoft :Sp just to try the links.
Sorry, there seems to be a problem with Outlook right now
If those are indeed links to email attachments then no one else will be able to view them. You can download the files and upload them to a file host.
How about now?
Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use).
I tried loading the pictures to image shack so I could just post the image here, but image shack made it very grainy and much of the color was lost ( probly I just dont know what I'm doing) If anyone knows how I can get a quality picture from those PDF I'd be grateful.
Photoshop can take the picture from the pdf file. I’ll gladly do that for you if you don’t have Photoshop.
Shoot it to me in an email.
Nevermind, That works fine! 100 boards a sheet huh? Wow!
