I'll start with the 150 meter shots. The current readings that were taken were 3 days after the night shots were taken. The batteries had in all lights a small amount of use as the weekend before these shots were taken for the first time but were not good enough to show. The batteries were not topped up in between.
The aiming point was a 20 liter white bucket hanging in the tree. The pictures are about what I was seeing at the time.
1. 10 Degree XML-U2 TIR 2.8 amp driver.
2. Ultrafire SK98 std. 1.75 amps tailcap. This light was provided FOC for review which ia a work in progress.
3. Ultrafire W878 std. 2.2 amps tailcap. This light has a larger diameter lens than the light above.
4. Ultrafire IPX7 std. 2.1 amps tailcap.
5. Starry Light warm tint std. Group buy.
6. P60 DeDo XPG-2 3C. 2.1 amps tailcap.
7. EA4 Warm tint std.
8. Ultrafire G4. 1.75 amps tailcap std.
9. Tangsfire C8 std. 3.25 amps tailcap.
10. Ultrafire C12 std. 2.9 amps tailcap.
11. OL Build C8. 2.4 amps tailcap. There is not a good contact at the switch I'm guessing as the current reading should be a lot higher.
12. A60 DeDo XPG-2 3C. 1.5 amps tailcap.
13. HD2010 std. 4.5 amps tailcap.
14. HD2010 mod. XML-2 on copper. IOS 5 amp driver. Driver and led changed since this build.
15. HD2010 MTG-2. 2.7 amps. 3 amp driver.
16. TN32 std.
17. TN35 std.
18. DST XML-2 DeDo. 5 amp driver. Led dedomed since the build.
19. DST MTG-2. 5 amp driver. Only running 3 x 26650s now.
20. Monster light MTG-2. 9 amp driver.
And finally a group hug.
