Tested the 3v XHP50.2 with the same 19amp 30T, had to add 2 copper rings to the head end to fit the tail cap on with out crushing anything…. the results…the first hit 4220lm, second hit (battery must of warmed up ) 4260lm.
Ha ha, we all do this from time to time.
M4D M4X recently burned his gray table cover testing lights in a video.
I made a video showing how to set the thermal step down in NarsilM using my mini L6 and pointed the light at a dark blanket to keep from over exposing the camera lens. It started smoking. I posted the video anyway. It was funny. Lol
I always use white paper when I’m testing amp draws, but sometimes you just don’t think about it, then smoke!!! :disappointed:
Can someone recommend a good 18650 e-switch host and driver for a build like this, ideal small like my favorite convoy s2+! I think may be fun to build a super powerful single led flashlight like kawiboy!
No sure what you mean, I said I would create the 3b on these 2 boards, this is now on the site as promised. I can offer a flate AUD20 ship rate for all these
Cheers
Mark
@crx
Please add me with 4 bare 3B emitters. My Q8 needs a power update. Usually i take 1 more than i need in case i screw something up. But money is a bit tight. So i will have to risc it.
I have a hard time lying in this hospital bed, not able to do some really nice work on some flashlights.
But its looking better than last week. So i might be ready when the parts come in.
I am thinking about the Q8 driver. Would it be better (from a efficiency point) to go with a driver which uses more channels and a bank of 7135?
I like the higher output of the XHP50 but i use this light a lot and would like to get good runtimes on the lower levels.
I didn’t want to miss out in case this group buy doesn’t go through so I ordered a bunch from KD. Another tint though, 2A? I wonder how many more tints are going to show up?
I’m still on for some 3Bs and 1Ds if this group buy works out though, but I’d change my order once again.
3 x bare 3B
2 x 16mm 3B
2 x 20mm 3B
3 x bare 1D
2 x 16mm 1D
2 x 20mm 1D
These numbers will stand unless yet another tint option pops out. Will pay up front of coarse!
@Docc, if you use the Q8 a lot I would consider leaving it stock, with the XP-L 3D emitters it is a well balanced flashlight with good tint, with 3V XHP50.2 3B leds it does have the impressive output on highest level, but on all other levels you have a worse tint, slight donut, more tint shift over the beam and less throw.
I’m doing the mod because I have more than 1 Q8 (4), so there are at least 2 to play with.
Thanks djozz
Because i usually need a more fooldy light i use dcfix on the front of my Q8 (if i could get one i would buy a OP reflector for it). I think this also would help with the XHP50 (if the dcfix foil can withstand the power of 4 XHP50). My main concern is that the light is draining the batteries faster.
Damn that Sofirn cancled the extension tube and instead brings out a new light similar to the Q8 with the extension. . .
