19 days ago I ordered this light. For a long time I had wanted 4 XM-L King.. I pulled the trigger on the light I linked to.
Pictured 2nd from the left, with "SRK logo", not "securitying" as advertised.
XM-L2 (CW, around 6500K), not XM-Ls. Nice surprise, which seems to be more and more common these days. Nicely centered too (it looks).
Stainless steel bezel, and in general quite good build quality.
Threads looks like the typical cheap SRK, but they feel pretty good. Just needed a little but of extra oil/lube.
Driver circuit was easy to get out (through switch hole). It uses two of the channels. Looks to be as easy to resistor mod as most other SRK lights.. I measured about 6,5A on the tail (with a single Samsung 20R), so its well driven.
All emitters on one MCPCB which sits on the typical fairly thin aluminium screw in pill.
Other:
No O-ring under switch
No glue anywhere :)
MCPCB is well secured with fujick or something like it.
Reflector underside have room for wires (its not flat)
So its quite obvious, this is a great 4x XM-L2 king considering the low price and quite good build quality right? NO, not exactly..
The emitters does not go high enough into the reflector which makes the beam have an ugly ring due to not being properly focused. You probably loose some throw and lumens as well. The reflector sits as low as it can on the pill. But the emitters are just not high enough. This will probably be fixed automatically when I upgrade to copper MCPCB (and some other emitters, and new driver, and springs...). And if that does not solve it, Ill just add some copper under the MCPCBs, which I might end up doing anyway...
All in all, I will rate this a good light based on first impression, especially for the price. But its only good if you can fix the focusing issue. If you don't mod, find another light..
PS. Like with all SRKs. They have a tendency to change, so just because you order from same seller, I can not guarantee that you get the same light..
