Can anyone tell me what a good driver upgrade would be for the A60? Anyone experimented for more Lux? I’ve got one enroute from DX hoping it will be here soon!! Also got a small sun C10 coming too with a 105c driver from intl outdoor (which could take an age to get here) for my first mod tryout.
Well I don't own any multiples of the same lights (ahem . . . yet). Well, unless you count Maglites, but those were bought for modding purposes when found at good prices (and before Old Lumens buys them all up!).
I have aleady swapped the emitter to a green one in one of them. Maybe this is my maglite. Lol :bigsmile: plus im giving one green modded one to my buddy to mount to his AR15
I suggest a 2,4-2,8 A drive current for max effect. You should be able to rech something around 65 kCd with that. But bear in mind it is a 20 mm driver inside so the 17mm drivers wont work directly.
But the easiest upgrade is to tighten everything up and feed it unprotected batteries. Maybe do a spring resistance mod (small wire soldered from +batt spring end to driver +batt and from -batt spring end to -batt tailswitch connection.
Also screw the head off and press hard on the led retainer disk (made of press fitted plastic, just make sure it is pressing hard down on that led star)
If you are lucky then you will then see tailcap draw of about 2,2-2,5 A.
Just received mine, it throws like crazy, has a minuscule hotspot, but a con is that it heats up like crazy. It has barely any heatsinking fans and it’s so small it burns your hand it it’s turned on for more than 5 minutes indoors. It’s just like a skyray king on high.
EDIT: I don’t really have a use for it, even though it’s small. My crelant 7g5v2 w/ collimator head has more than double the lux AND has about a third bigger hotspot. Oh well it’s only $15… maybe I’ll try to dedome this sucker
Not that easy to mod, infact not that easy to tighten up or dismantle, gonna have to find a tool that fits nice. It would make a decent template for other manufacturers to make a decent light from, single cell, massive head lights are cool just make it XML with 60k+, NW ,no PWM and hi-med-lo only. I don’t want much…. Oh and keep it at around $15
I dedomed mine. Its very easy because of the metal ring. Keep thr star down, use pliers and just pluck it off, 90% of the gel comes off too. I got 86k lux then tried to clean up the led. I broke a bond wire.
Btw the beam after dedoming is minuscule and is very ringy. Not useful at all.
Ans to lumatic, i dont need it because i have something better in brightness, hotspot size and throw. I just think compared to all my xml throwers the A60 has too thin a beam. But its fun to play around with if you dont have a better thrower.
The Uniquefire UF=V3 is the buy of the year. You will not be sorry.
I just used it tonight for over 20 minutes and it behaved well, Heat control is excellent.
Thanks,
Keith
You seem quite fond of your collimated 7G5v2 Slewflash. Rightfully so. It is very nice. Arguably not very ‘budget’ though. I think Lumatics point was you’re comparing apples & oranges… or honda & porsches… the A60 is a fraction of the cost! It is unrealistic to consider such a mismatch an accurate comparison. They are in different leagues.
Muto - thanks for your input. I think you may have convinced me to pull the trigger.
