If you nitpick hard enough, there are plenty of reasons to consider passing. Unfortunately until the testing is complete I won’t make a final recommendation on whether or not it’s a good buy.
Please let us know what you think when you get it.
I received it today. It's ok, but I would recommend spending a few dollars more for SpidercoGonzo (maybe call them Gonzaco's). It did not have threads on the holes for the alternative clip positions. So no tip up carry for now. One of the clip screws was stripped upon arrival. Has nylon washers. Finished on the blade could be better. Blade is nicely centered and is wicked sharp right out of the box.
It is Spiderco branded, but I doubt it's a Spiderco reject.
Wheeler, you got the lower quality liner lock version of the C81 clone. There are two different versions of the C81 clone. A lower quality liner lock version and a compression lock version that is just like the original C81 (Paramilitary 2) If you look hard you can still find the higher quality compression lock version, usually a few bucks more. (Just received one today, read below) I brought this up in a post a few pages back (post #700) Here’s some of that post:
Quality is very near to the ones I got a few months back, the only difference is the handle is nearly 1mm thicker and the blade is not as well centered, but only very slightly off center (I haven’t disassembled it yet, but upon a quick inspection the blade centering issue may be due to one of the pivot washers is thinner than the other, the thinner washer appears to be a yellowish brass color and the thicker washer is more of a reddish copper color) Still I think its better than the nylon washers that are on the cheaper version.
Other than that its identical: EDIT (see below) Compression lock (top lock) version with the better thumb ramp and choil jimping, bronze washers, tight lockup, blade thickness 3.7mm at the thickest part, spyder hole ID: 14mm, all four clip positioning holes are threaded.
(EDIT) looking more closely now I’ve found some more slight differences between the one I just received ($15.99 - link above) and the Lime Green one I previously got (now $28.00 - link at bottom) The blade is a smidgen thinner (3.7mm vs 3.9mm) and the edges on the inside of the spyder hole are a bit sharper. The green one having the bit thinner handle has closer tolerances in the pivot area.
Even with the minor differences I’m not at all unhappy with it for the paltry sum of $15.00 that I paid for it, like the others it’s amazing sharp right out of the box, passes the paper cutting test and shaves the hair off my arm.
I selected ePacket shipping and paid the additional .77 cents (recommended), the knife arrived here in the USA 22 days from order date, it actually was shipped via PostNL (Netherlands Post)
So I agree if you are getting the Liner Lock version C81 clone you would be better off getting the Ganzo since it has AXIS lock. BUT, I highly recommend the better Compression Lock C81 version clone if you can find it. (Right now its only $15.99 at the shop where I got the one I received today, link above)
Also for these I prefer Tip Down carry for faster opening using the Spyder Drop technique, which I have found to be the fastest way to open one of these from pocket draw, and has become my preferred method.
Tip up works too but upon drawing you need to re-positioning your hand to pinch the Spyder hole because you’re grabbing the knife at the opposite end of where the hole is. With Tip Down when you draw your fingers are already right there. Although you have to do a quick “flick-up-then-down” motion instead of just the down motion, it’s still much faster from draw to open in my testing than tip up.
Thanks Beam0 for your input.
How’s the deployment on the one you have? Smooth?
I’ve been wanting to get one of these but want to make sure I get one with compression lock.
Could you please check your first link? It doesn’t seem to work.
Thanks.
Ganzo G716, from Dealsmachine.
For the price…wow what an amazing knife ! The blade was dull as f* out of the box though, but nothing a godd Lansky sharpener can’t fix.
I have 3 of these, the deployment is smooth on them as in there’s no gritty feel and they aren’t sticking.
The nicest one by far is the all black one with “Anso” pattern scales (last link, version “A” $28.00) those were on sale fpr $19.99 when I got mine from that seller. I got the all black version “A” and a lime green one. I like those two better than the one I just received. (I edited my previous post with some more about the differences), but I am not unhappy with the one I just received and it was well worth the $15.00 I paid.
I’m considering getting another one of the version “A” even at the higher price but I’m going to message the seller and see if he can do any better.
Yes I agree, I researched very well to be sure I got a compression lock version after seeing all of the cheaper liner lock versions popping up, there were several that showed the better version in the photos so to be sure I messaged the sellers to confirm but most did not reply so I couldn’t trust them.
Another seller that showed photos of the compression lock version I read in feedback a buyer got “bait and switch” and received the liner lock instead, so after seeing that I want to hear from the seller confirm it before I buy.
The one I just received (first link) was the only one that replied and also one of the buyers posted photos of it in the feedback and you could clearly see it had the compression lock.
Well I don’t have the SpyderGanz yet to compare in person, but…
Before I got the one I just received I already had two C81 compression lock clones, the custom “blackout” one with acid wash blade and Anso scales, (version A) and the lime green with satin blade (version C). I wanted another one like the lime green/satin blade but this time with black G10 handle.
Around that time is when the Axis lock SpyderGanz (G729) became available, being an AXIS lock fan I immediately thought I’ll just get the Ganzo, however when I looked more closely at it I noticed it didn’t have the nice jimping like the C81 compression lock clones. Although the Ganzo appears to have some “mild” jimping on the thumb ramp (and none on the choil) I was concerned it may be similar to the cheaper liner lock C81 clones that have no jimping at all.
So for those reasons I decided on another compression lock clone instead of the SpyderGanz. I’m a big fan of jimping and I love how the C81 blade has a steep thumb ramp with agressive jimping. So for me I was sold on the better compression lock clone mainly because of the jimping. But knowing Ganzo’s outstanding quality I plan on eventually also getting a G729 AXIS lock SpyderGanz.
So if you’re into the excellent jimping, get the C81 compression lock clone, but if having the AXIS lock is outweighs the jimping maybe get the Ganzo. If you want something really custom looking and excellent quality get the black “version A” C81 clone with the Anso scales, all black hardware and black acid wash blade.
Yes, exactly what I was saying in my previous posts.
The “good” (better) ones are the ones with compression lock.
Clones displayed on ali usuallysometimes will have the blade markings blurred out in the photos for obvious reasons. But for the photos of the C81 with blurred out/not visible compression lock area, it could mean they will send you the liner lock version.
”OEM” is aliexpress code word meaning: “it has fake OEM logo”
OK my bad, I never noticed or bothered to take a count to see what the ratio was, when I wrote “usually” I didn’t mean “most” but now I see how it sounds that way, I meant “sometimes” and I wasn’t looking at all those other brands clones. Post edited.
And I wasn’t trying to snub you when I said “for obvious reasons” but again I see how it might have been interpreted that way. 0:)
The vendor is reputable in the sense that he answered my pre-sales questions, delivered the item as described per those inquiries and shipped out within a reasonable time. I can’t vouch for them being reputable in any other perspective.
