Appreciate that avrdude line, I definitely want a backup of the FW on the new lights.
I found level_calc.py, but I have no clue what parameters to use in that script to make the d4v2-2channel have 0-150 on each channel, aka 1 channel turbo.
This is the ramp from d4sv2-tintramp.
// has two channels of independent LEDs
#define USE_TINT_RAMPING
// how much to increase total brightness at middle tint
// (0 = 100% brightness, 64 = 200% brightness)
#define TINT_RAMPING_CORRECTION 0 // none, linear regulator doesn't need it
// main LEDs
// output: unknown, 2000 lm?
// FET: absent / unused?
// 2nd LEDs
#define RAMP_LENGTH 150
// abstract ramp (power is split between both sets of LEDs)
// 1-130: 0 to 100% power
// level_calc.py 5.01 1 130 7135 2 0.2 2000 --pwm dyn:64:16383:511
// 131 to 150: 101% to 200% power
// level_calc.py 6.44 1 150 7135 1 0.2 2000 --pwm dyn:74:16383:1022
#define PWM1_LEVELS 2,2,2,3,3,4,4,5,6,7,8,9,10,11,13,14,16,17,19,21,23,25,28,30,33,35,38,41,44,47,50,54,57,60,64,67,71,74,78,81,84,88,91,94,97,99,101,103,105,106,107,107,107,106,105,102,99,95,90,84,77,68,58,47,34,36,38,40,42,44,47,49,52,54,57,60,63,66,69,73,76,80,83,87,91,96,100,104,109,114,119,124,130,135,141,147,153,160,166,173,180,187,195,203,211,219,228,236,245,255,264,274,285,295,306,317,329,340,353,365,378,391,405,419,433,448,463,479,495,511,530,550,570,591,612,634,657,680,705,730,755,782,809,837,865,895,925,957,989,1022
#define PWM_TOPS 16383,13234,9781,13826,9593,13434,9973,12021,12900,13193,13150,12899,12508,12023,12666,11982,12181,11422,11393,11247,11018,10731,10826,10434,10365,9927,9767,9565,9332,9076,8806,8693,8395,8096,7928,7626,7439,7143,6948,6665,6393,6203,5946,5700,5465,5187,4926,4681,4451,4195,3957,3700,3463,3213,2983,2718,2476,2231,1986,1742,1501,1245,997,756,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511,511
#define DEFAULT_LEVEL 70
#define MAX_1x7135 150
#define HALFSPEED_LEVEL 10
#define QUARTERSPEED_LEVEL 2
Speaking of the K9.3, what is the last working build?
