Thank you and all the other folks posting requests, for coming with all these great ideas for us Anduril modders to implement!
For other folks that might be interested:
This mod is based on GChart’s rev.620 as per @jon_slider request (he said it has everything he wants – except my 8C_Quick_Aux_Switch mod, of course
– and nothing he doesn’t).
Before flashing it, I recommend erasing the EEPROM (with eg,
avrdude -e
), as @jon_slider detected during his tests a case where settings for other firmware could end up throwing the new one in a loop; -
Here’s the link for the HEX, tested and approved by both @john_slider and I: https://durval.com/xfer-only/anduril.ts10_-_gabe-anduril2_620_20220719_+_8C_QUICK_AUX_SWITCH_-_DM_20231001.zip
And here is the obligatory (as per the Anduril GPL License, are you listening @Simon_Mao?
) source code for the mod, adapted to the above base firnware:
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/aux-leds.h 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/aux-leds.h
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/aux-leds.h 2022-07-04 17:28:25.000000000 -0400
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/aux-leds.h 2023-10-01 13:48:21.670503492 -0300
@@ -83,5 +83,14 @@
#endif
#endif
+#ifdef USE_QUICK_AUX_SWITCH
+ #ifdef USE_INDICATOR_LED
+ uint8_t previous_indicator_led_mode = ~INDICATOR_LED_DEFAULT_MODE;
+ #endif
+ #ifdef USE_AUX_RGB_LEDS
+ uint8_t previous_rgb_led_off_mode = ~RGB_LED_OFF_DEFAULT;
+ uint8_t previous_rgb_led_lockout_mode = ~RGB_LED_LOCKOUT_DEFAULT;
+ #endif
+#endif
#endif
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/cfg-wurkkos-ts10.h 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/cfg-wurkkos-ts10.h
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/cfg-wurkkos-ts10.h 2022-07-19 19:43:49.000000000 -0400
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/cfg-wurkkos-ts10.h 2023-10-01 13:58:41.943828699 -0300
@@ -76,4 +76,7 @@
#endif
#ifdef BLINK_AT_RAMP_CEIL
#undef BLINK_AT_RAMP_CEIL
-#endif
\ No newline at end of file
+#endif
+#define USE_INDICATOR_LED
+#define USE_QUICK_AUX_SWITCH
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/config-default.h 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/config-default.h
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/config-default.h 2021-12-08 19:36:58.000000000 -0300
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/config-default.h 2023-10-01 13:48:21.682503908 -0300
@@ -194,4 +194,7 @@
// those oscillations
//#define USE_LOWPASS_WHILE_ASLEEP
+// enable quick switch to/from current aux mode to off
#endif
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config.c 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config.c
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config.c 2021-11-03 07:16:05.000000000 -0300
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config.c 2023-10-01 13:48:21.650502797 -0300
@@ -95,6 +95,15 @@
#ifdef USE_AUTOLOCK
autolock_time = eeprom[autolock_time_e];
#endif
+ #ifdef USE_QUICK_AUX_SWITCH
+ previous_indicator_led_mode = eeprom[previous_indicator_led_mode_e];
+ #endif
+ previous_rgb_led_off_mode = eeprom[previous_rgb_led_off_mode_e];
+ previous_rgb_led_lockout_mode = eeprom[previous_rgb_led_lockout_mode_e];
+ #endif
+ #endif
#ifdef START_AT_MEMORIZED_LEVEL
if (load_eeprom_wl()) {
@@ -174,6 +183,15 @@
#ifdef USE_AUTOLOCK
eeprom[autolock_time_e] = autolock_time;
#endif
+ eeprom[previous_indicator_led_mode_e] = previous_indicator_led_mode;
+ #endif
+ eeprom[previous_rgb_led_off_mode_e] = previous_rgb_led_off_mode;
+ eeprom[previous_rgb_led_lockout_mode_e] = previous_rgb_led_lockout_mode;
+ #endif
+ #endif
save_eeprom();
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config-fsm.h 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config-fsm.h
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config-fsm.h 2021-11-03 07:16:05.000000000 -0300
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/load-save-config-fsm.h 2023-10-01 13:48:21.674503630 -0300
@@ -95,6 +95,11 @@
#ifdef USE_AUTOLOCK
autolock_time_e,
#endif
+ previous_indicator_led_mode_e,
+ previous_rgb_led_off_mode_e,
+ previous_rgb_led_lockout_mode_e,
+ #endif
eeprom_indexes_e_END
} eeprom_indexes_e;
#define EEPROM_BYTES eeprom_indexes_e_END
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/lockout-mode.c 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/lockout-mode.c
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/lockout-mode.c 2022-07-04 17:28:25.000000000 -0400
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/lockout-mode.c 2023-10-01 13:48:21.658503075 -0300
@@ -185,6 +185,49 @@
#endif
+ #if defined(USE_INDICATOR_LED)
+ // 8 clicks: if indicator LEDs (aka "aux LEDs") mode is not off, save it and change it to off; if it's already off, change it back to saved
+ // See: https://budgetlightforum.com/t/anduril-2-feature-change-suggestions/218045/145
+ else if (event == EV_8clicks) {
+ uint8_t mode = indicator_led_mode >> 2;
+ uint8_t previous_mode = previous_indicator_led_mode >> 2;
+ if (mode) {
+ previous_mode = mode;
+ mode = 0;
+ } else {
+ mode = previous_mode;
+ previous_mode = 0;
+ indicator_led_mode = (mode << 2) + (indicator_led_mode & 0x03);
+ previous_indicator_led_mode = (previous_mode << 2) + (previous_indicator_led_mode & 0x03);
+ // redundant, sleep tick does the same thing
+ //indicator_led_update(indicator_led_mode >> 2, arg);
+ save_config();
+ return MISCHIEF_MANAGED;
+ #elif defined(USE_AUX_RGB_LEDS)
+ // 8 clicks: if RGB aux LED pattern mode is not off, save it and change it to off; if it's already off, change it back to saved
+ uint8_t mode = (rgb_led_lockout_mode >> 4);
+ uint8_t previous_mode = (previous_rgb_led_lockout_mode >> 4);
+ if (mode) {
+ mode = 0;
+ } else {
+ rgb_led_lockout_mode = (mode << 4) | (rgb_led_lockout_mode & 0x0f);
+ previous_rgb_led_lockout_mode = (previous_mode << 4) | (previous_rgb_led_lockout_mode & 0x0f);
+ rgb_led_update(rgb_led_lockout_mode, 0);
+ save_config();
+ blink_once();
+ #endif // end 8 clicks
+ #endif
return EVENT_NOT_HANDLED;
diff -ruN '--exclude=*.hex' '--exclude=*.o' '--exclude=*.orig*' '--exclude=*.elf' 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/off-mode.c 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/off-mode.c
--- 620/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/off-mode.c 2022-07-04 17:28:25.000000000 -0400
+++ 620-8C_quick_aux_switch/~gabe/flashlight-firmware/anduril2/ToyKeeper/spaghetti-monster/anduril/off-mode.c 2023-10-01 13:48:21.618501687 -0300
@@ -316,6 +316,49 @@
#endif // end 7 clicks
+ // 8 clicks: if indicator LEDs (aka "aux LEDs") are not off, change them to off; if they're already off, change them to low
+ uint8_t mode = (indicator_led_mode & 3);
+ uint8_t previous_mode = (previous_indicator_led_mode & 3);
+ if (mode) {
+ mode = 0;
+ } else {
+ indicator_led_mode = (indicator_led_mode & 0b11111100) | mode;
+ previous_indicator_led_mode = (previous_indicator_led_mode & 0b11111100) | previous_mode;
+ //indicator_led_update(indicator_led_mode & 0x03, arg);
+ save_config();
+ // 8 clicks: if RGB aux LED pattern is not off, change it to off; if it's already off, change it to low
+ uint8_t mode = (rgb_led_off_mode >> 4);
+ uint8_t previous_mode = (previous_rgb_led_off_mode >> 4);
+ if (mode) {
+ mode = 0;
+ } else {
+ rgb_led_off_mode = (mode << 4) | (rgb_led_off_mode & 0x0f);
+ previous_rgb_led_off_mode = (previous_mode << 4) | (previous_rgb_led_off_mode & 0x0f);
+ rgb_led_update(rgb_led_off_mode, 0);
+ save_config();
+ blink_once();
+ #endif
#ifdef USE_GLOBALS_CONFIG
// 9 clicks, but hold last click: configure misc global settings
else if ((event == EV_click9_hold) && (!arg)) {
