It’s not available online. However you can find a local Home Depot that might have it using the online stock checker
Enter the store number local to you and it shows all local stores that might have it. Find it on homedepot.com (hint: Redlands store #1013)
Stock level between higher than five but lower than 35 means they have it on the floor somewhere.
Stock level of 35 means they have it but may not be on display.
Stock level of zero means they are out.
Redlands store #1013 currently has stock of 28. It should be close if your location really is Highland / San Bernardino.
1151 W Lugonia Ave
Redlands, CA 92374
(909)748-0505
I would agree with ILF that the FF STL-V6 throws a little further than the A60. I have both and use them heavily for hunting purposes, and my Maxtoch SN6X-2 aka FF STL-V6s will just shade the A60. Very little in it in terms of distance, but its much greater lumen output gives the FF a much better quality throw - vastly more usable at all ranges.
However - and strange as it may seem - after importing 30-40 of these Maxtoch/FFs for hunting mates (and testing them all) I have to say rdfronty may also be right !! In my experience 1-2 of the Maxtoch/FFs had up to 15% brighter hotspot and better throw than others. This is a big output variance, and if rdfronty has a couple of very good A60s and a lesser FF then I’ve no doubt the A60s will shade his FF STL-V6.
From the dozens I’ve tested the distance decision goes to the STL-V6. It is however its huge usable output down range which makes the STL-V6 such a star.
A good piece of news….Maxtoch the OEM manufacturer who actually make the Maxtoch SN6X-2 and rebrand it for other companies as Fandyfire/Skyray STL-V2 etc have just told me they will have an upgraded version of this flashlight on the production line shortly. It evidently tests out 30% brighter at 10m. Given the Maxtoch SN6X-2 tests out at 52k lux at 1m, the new model at +30% at 10m could be round 67k? Physics here?
I will have samples of the upgrade to test soon. Am not sure all Fandyfire/Uniquefires run to same 52k spec as specifically the Maxtoch/Skyray, but no doubt the new performance upgrade will filter out to all of the brands of this light eventually.
A60 a great little scope mounted rifle light. Crazy bargain at just $15. Its a wee legend - but so too is the Maxtoch/Skyray/FF and it does all the same jobs just that much better.
And I wanted to mention here that the EagleTac M3C4 U2 version I have will probably put out around 65,000 lux and it out throws my Crelant 7G5 and Olight M3X by say 10%. Just passing that on since the M3C4 was mentioned earlier.
Hello, Now that the V6 is shipped, I still have another problem, not having enough batteries… Can anyone recommend me some quality and cheap 18650s?(Would prefer protected) Is this good? The review says that it is abit longer from other 18650s. Thanks!
Yeah that’s what I bought for it, but they barely fit, super tight, actually denting the protection circuit neg terminal. My AW’s are shorter and I am running them in the STL-V6 now, and the Panasonics you recommended have been re-assigned to my L2P’s.
I would look for 18650’s that are a little shorter, IMHO.
I’ll be modding to 2x18650 (spacer, sleeve, and driver swap). A mod to 1x18650 seem fairly easy (spacer and sleeve) if you don’t mind the extra wasted tube space. There’s no way I’ll keep using this as a C-cell light.
Why the problem with C-cells? You can run rechargeable nmh batteries and have the option of readily available alkaline C -cells in a pinch. With lion 18650’s you have nothing to fall back on.
NiMH C cells are tough to find, and buying a set for just one light doesn’t make sense. I like the idea of a fallback to standard batteries, and I’m looking at a buck driver that can go down to 3V and should fit with a minor trim. This maintains the backward compatibility to C cells.
Does anyone have a tailcap reading on their V6? Mine seems to be very low at .76, but then I don’t know what a tailcap reading “should” be for a 2-18650 light.
That was another reason I didn’t recommend the v6. Mine seems way underpowered. I changed the emitter to a U3, which helped a lot, but still have that .76. Did I get a bone as usual?
I’m thinking of putting my favorite xm-l driver in and buying another a8, then I can run 1*26650 shorty or change back to 3c at reduced output. I can live with that situation, and may see about some tenergy nimh c cells. Out of interest, how do sub c’s compare to c cells in length/voltage?
Well that explains why mine is so lackluster at .76, unless it’s some weird driver. It wants to throw and does throw, and the spot goes a long way. It’s just not especially bright. Anyone recommend a 2-18650 driver for the V6? Don’t have it with me, so I can’t measure the size. I assume 20mm, but I could be wrong.
