Know what you mean.
It’s the anticipation that can sometimes get to us!
We all want it done by yesterday, but look at the problems that has caused, even recently on this site.
Patience is a virtue. (Repeat to myself until convinced……Patience……….)
Know what you mean.
I really would like to know the production costs of the A6 drivers….I am sure they could sell them dead cheap and make them the new standard so that the old nanjg can go to retirement.
Sometimes it sounds like people have decided that this is the best 17mm driver. Personally, I think it’s a bit early. Things seems to be moving at a pretty quick pace. The attiny25 is the same size as the attiny13. Lets see what comes out of the other attinies with more code space.
Except that the A6 driver design is proprietary (wight) even though TKs firmware is not. I think somewhere in that giant thread there are posts explaining that permission would not be given to Chinese makers to sell these drivers as stand-alone components.
Richard certainly has something close but it won't be dead cheap. Would you really want the "dead cheap" option after looking at some of the soldering photos we've seen recently?
No one thinks the Nanjg105C is the best driver, or the Qlite, or the LD2, but they are popular. There will always be better drivers.
There are three factors involved in popular 'standard' drivers: 1)must be pretty good (so not neccessarily the best), 2)must be easily available, 3)must be cheap enough.
Something is the matter with the last one. I intentionally did not say 'reasonably priced', because that is not good enough for a driver to be popular. Richard's drivers are very reasonably priced, considering the time and money that goes into them (I still wonder how he makes a living out of his business with the amount of work he puts into it). But the other perspective is that you still put 10+ dollar into a flashlight just for the electronics, I do not dare to explain that to my girlfriend.
Sorry you aren’t feeling well T.K.
The driver is proprietary, but still could be copied, just not exactly. And it would need some development to make it cheap and reliable to mass produce, anyway. The thermal sensitivity of the off time capacitor, for example.
I think most people don’t want direct drive high modes. Many of the cheap lights have resistor banks to reduce the on current, and 7135s are a clear improvement on that. The T.K. firmware is also for enthusiasts rather than for typical owners.
FWIW, I added attiny25 support to blf-a6.c, battcheck.c, and offtime-cap.c, and added some blf-a6 hex files for 13 and 25 calibrated for RMM’s drivers.
The OTC values are much lower… changed from 245/180 to 190/94. And the voltage values went up, 175/112 to 195/124. If you build your own drivers, you’ll probably need to do all the calibration again.
In any case, it all works on attiny25 now, and tiny25 build/flash/calibration tools are now included in the firmware repository. I didn’t add any new features yet though; that’ll happen later.
Wow TK, new features to come!
This is getting sooo exciting.
Get well quick. :bigsmile:
KT
Can I ask a slightly of topic question? I was researching info to get ready to maybe doing some aver programming, and saw info on attiny25 vs attiny13a, and it looked like the minimum voltage for attiny25 was higher than for attiny13a. Is that correct? And if so, would that affect performance in a flashlight?
I dispute that the delivered A6 driver is the same as Wight’s driver. The PCB is laid out differently. The circuit design is borrowed from the NANJG 105C with the addition of the MOSFET and OTC, so I don’t see how that can be proprietary. If this design is proprietary, then the Chinese makers can just add a resistor the the gate of the MOSFET and call their new design proprietary. This, by the way, would reduce the turbo-to-moon flicker and would thus be a better design.
I’m referring to the driver described here. If the A6 driver is a copy of another of Wight’s driver, please let me know and I will admit to being wrong.
You probably want the attiny25v-ssu. It’s the same size as the attiny13a used on common drivers, and supports a lower voltage than the non-v version.
Without the V, I think it’s only rated down to 2.8V. I got one to operate at 2.7V today, but I wouldn’t count on it. The higher voltage would potentially interfere with low-voltage protection, or might require setting LVP to a higher limit.
If I recall correctly, wight made some minor changes to that version of A17DD-L but only released it to the BLF A6 partners. I don’t know what the changes were though, aside from dropping a via to pin 3 for easy access.
A girlfirend is one thing m8…try explaining to the wifey
Anyway, as a casual user that buys el.parts mostly from the net A177DD and its versions costs me like 3.5$ per piece( with Samsung resitors and caps), like 40-50 hours “lost” training ( C programming, reading the TK topic about that matter est) and some soldering work.
I think that china folks could easy sell this one for 5-6$ if mass produced, but ofc we dont know the authors opinion about that matter( Cheers Wight, we DO miss you)
Attiny25 (non-V) official voltage range is 2.7v-5.5v.
Hi.
Managed to P.M. James at 3Tronics, and he replied:
“Hey,
Yep I stock the LD-2 driver, that was designed by led4power and permission from him to sell on my site, I’m happy to sell anything if I have a reliable source for stock, i don’t currently have the equipment (or time) to flash firmware, but if I have permission from the designer and a reliable source for stock I can’t see a problem.
James
I have no problem with you quoting me.
I can solder drivers that’s no problem, it’s just I don’t have the equipment to flash them.”
So that sounds quite hopeful for the unskilled ones of us in Europe
Interested to see in what form(s) this may pan out in the future.
I didn’t know that. Yes, if they used Wight’s layout, then it’s proprietary. But I still don’t see any reason why a Chinese company that can design a driver like the NANJG 105C can’t also design a board with MOSFET + 7135.
According to the 219C thread, this isn’t the only way to go.
Hmm? I’m not sure what you mean. Which 219C thread, and which way?
I think he’s referring to the fact that the 219c’s don’t work the best on FET drivers because of their very-low Vf’s.
Yes. Someone seems to have gotten too much current through one, with an A6, so I commented that it needs regulation.
