BLF Kronos X6/X5 GB - Group Buy now closed.
:beer:
or some teflon tape on the threads
It is not the same firmware.
Flaslight:
Driver:
That 9 mode groups Bistro is Rev 208.
While the BLF X5/X6 Bistro with 8 mode groups is Rev 206
I suspect these drivers will have the same firmware version as the BLF X5/X6 ie Bistro Rev 206,
and that Banggood has wrongly linked to the latest Bistro revision which is Rev 208.
Bistro Rev 206 used by Manker for BLF X5/X6:
~toykeeper/flashlight-firmware/blf-x6v2 : Contents of ToyKeeper/bistro/bistro.txt @Revision 206
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/blf-x6v2/view/206/ToyKeeper/bistro/bistro.txt
Best Regards,
George
Hi guys
I need your help
Where can I get spare tail switch for x6 version ?
I don’t have the light, but check if this guy is a match:
https://www.fasttech.com/product/1203605
Excellent analogy. I’m no scientist (EE / IT guy), but this just makes sense to me. To have the audacity to proclaim ‘we’ have it all figured out is just evidence that we’re essentially clueless …
:person_facepalming:
Repeating a long-ago plea:
Also quoting from earlier:
Still good advice? I got myself some after reading that and now I’m wondering, should I?
Or swap in a non illuminated switch pcb. No soldering required.
Does swapping the switch out improve the temperature management?
Does that change the electrical situation for the driver somehow?
I know there was discussion but don’t know if it was resolved.
I just got my set after ordering them after the group buy. It was raining last night so I was only able to stand on the porch and shine them across the street and at some trees, but what beautiful lights. Instead of BLF they should be called BAF X5 and X6: Bad-A$$ Flashlights!
I can’t wait to play with them some more.
I have a Nichia 219C triple in a S2+ with Bistro firmware and the thermal lag between emitter and driver is a problem (gets too hot, them backs down to far, repeat).
I packed two thermal cubes into the driver cavity to try to help but it didn’t make much of a difference. A true PID algorithm might help, or putting a temp sensor on the mcpcb.
Kronos, any news on the wooden box for X6 and X5? Would love to get couple of them for my aluminum X6 and X5…
LOL, if I ever make a flashlight company I’ll have to call it BAMF or BAMFF. :slight_smile:
So I put in a 4.19v keeppower 14500 840mAh cell in my Cu X5
3-15-16
Today 5-13-16, protection killed the tailcap. 2.59v on wake up.
The X6 had a 4.19v NcrB 3400mAh on the same date. Down to 3.92v
Neither saw any use apart from being eye candy. :slight_smile:
Just throwing out some more data points.
My X6 was off the other day, tailcap didn’t work AND the light did not camo on.
So I took out the Keeppower unprotected hgh drain cell and measured 0.8V
:frowning:
took the charger outside
LOL it charged to 1.2V
Had t place it several times and then the charger got t and took it to 4.2
Internal resistance was not elevated much. And it did not get warm so I still use it.
But I don’t get how t could get so low, could I left it on moon or something?
I used it a week or so before and always do voltage check and never let it go down lwer then 3.6V since I like the high blast of light when I use it.
It must have stayedon on a lower mode.
Now I do lockout to be sure.
Bad Ass Mother F? Bad Ass Mother F**ing Flashlights? :person_facepalming: :stuck_out_tongue:
Only explanation I can think of, if you are sure of these facts, is a bad cell or there's some sort of short or issue in the tailcap, causing high drain, like there's a flaky solder bridge across a tailcap LED, or some other kind of partial short. If your springs look good and everything still works fine, nothing got fully shorted I would think. You could check amps/voltage drops through the tailcap using a DMM.
