A while back when I had the hair brained idea of running 4S 26650/26500’s XHP35’s in L2/L6 and the Jaxman X6, Richard developed his driver(s) for it, and by chance, he had a customer who Loved the L2 shorty but didn’t want the extension tubes, and because of the cost of shipping, he let Richard have them, so I acquired them.
So 2 extensions and a main tube give me 4S/26650 and 1 extension and a main tube for 4S/26500’s.This was way before the 26350’s came out by the way.
Just got done building a l2 with a xhp35hi e2 3a mtnmax buck driver at 2.5 amps.I got about 2.58 amps at the tailcap for 2450 lumens.I got 289 kcd at 5 meters.I got mtnmax standard with no memory.Probably shouldn’t have got that the way i use it should have just got 1 mode 100%.
I’m really likng this l2 with the xhp35 but i don’t like the mtnmax standard ui with no memory.Does anybody know if this can be changed or can i send it back to richard.All i want is 100% one mode.
I pulled out my L2 last night to get all of my flashlight batteries charged up, and realized how little I actually use this light. I want to say I put a dedomed XM-L2 U4 1C and the color is just God awful. It has a weird green, burnt orange color and it just doesn’t produce the output I was hoping for (compared to some of my other lights).
So, I’d like to do something with this thing instead of it being a heavy paperweight. I’ve never modded a light with XHP’s so I’m wondering if it would be possible to put one of them in here… but still keeping it a single cell light. Is it possible to run a single 26650 with a boost driver with a XHP35/50/70?
I definitely want to keep it as a single sell powerhouse, as I have an L6. But I’m not sure if there is a driver that would fit the bill.
You should easily be able to put a boost driver to run an 6V emitter like the XHP-50 or 50.2, or 70/70.2, but the problem is it’s difficult to find such a driver that really pushes very hard. So the end result isn’t all that great for most of us here that like output. The 12V boost drivers are fairly pathetic as well, so running a single XHP-35 from a single 26650 is also fairly disappointing.
If you’re ok with it not being a powerhouse, then the 50.2 or 70.2 are very viable options. I know several here have used drivers from KaiDomain but I can’t recall which it was. Someone will chime in, pretty sure. Kawiboy?
I need to get some bubble packages and prices from the post office, all I have are flat rate boxes that start at like $5.85 or something, not sure one of these extension tubes will fit in the small flat rate as it might be too big around.
Thanks for the insight DB; I wasn’t sure if there was such a driver or not. Maybe adding a longer tube is the way to go. The L2 is so heavy that I’d like to put that heat sinking ability to good use.
I was reading up about loneoceans’s GXB20 driver ( Thread Here ), but it looks like he made a few, figured out how to make it work, and then stopped. :weary:
I was hopeful of getting one of those from loneocean as well.
Directly above your post, ZozzV6 tells us what to use from KaiDomain.
The last L2 I got I had planned to use the XHP-35 and the LD-2 driver, when the light came in I really really liked it in single cell form. But I went ahead and used 3 extension tubes and the modified LD-2 driver, have it running around 2.6A I think, can’t really remember. It’s nice though. Long, like an old 3D Mag and with good throw, over 2000 lumens.
Edit: Ok, so I backed up in here til I found where I’d built up the L2 with it’s XHP-35… had forgotten I used Richards Buck driver and then modified it’s output…
“Somehow it seems I never mentioned it, but I changed the resistor on Richards Buck driver in this L2 such that it went up from 2.42A to 2.6A and up from 2352 lumens to 2518. Lux too is up, from 258Kcd to 285.75Kcd (274.5Kcd at 30 sec)”
