The luminous tape below gasket. Kapton tape is the amber yellow. You only need paste the luminous tape around the led. The luminous tape is adhesive but you can use kapton to secure it and to isolate positive and negative about the aluminum reflector.
Do you have the exact item number for the glow tape? If you have other glow items (tape, powder, etc.) how does the glow time of the tape compare?
Asking because different glow tapes have huge variation in glow brightness and duration. Last glow tape I bought from Aliexpress is the weakest I’ve ever tried out of 5 different tapes form various sources.
Duration is good. Very good. At last 10 minutes at high and several hours minutes on low.
Any indirect light can charge it and in a pitch black room is visible with adapted eyes.
This is for the tape nude. On flashlight is less visible after 15 minutes because is below a gasket. The luminous tape is very good and if is not below something can shine several minutes. Only a few expose to sunlight or artificial light charge it. I am very happy with this tape and I was skeptical before trying it.
This the silicone ring round the glass. Is less luminous but works ok a few minutes.
If you not have the needed long cut two pieces and join it carefully. Works very well and result is like it was one piece.
No, my error. No luminous ring on L21B. It is a reflection from the luminous tape.
I have installed the luminous ring on other flashlights BUT the L21B is deep and the Ring is most hidden.
The photo seems to have a ring around glass but not.
I have installed the Convoy green luminous ring in other flashlights but it is not visible on L21B.
Only luminous tape in this mod.
Hi, mine was made with resin and glow in the dark powder. The tape idea is also pretty good, especially for lights with TIR, as you can have a lot more tape surface to glow.
Another question: which tape width did you order? Looking through the reviews, it looks like reels with different width are made with different materials, and some are much worse than others.
4 cm width and 3 meters. The photo might be showing varying degrees of light exposure.
It doesn’t make sense to me that the materials would differ based on the width.
Perhaps the product quality has changed to better following someone’s complaint.
I’ve just been looking at some photos now, and some look different. I would go with a width of 3 or 4 cm.
In my case, the 4 cm wide one works really well; I ordered a second one a month later than the first for backup, and turned out just as good made of the same material than the first.
Thank you very much for this information! It’s really helpful to hear trusted experience rather than random photos off the internet.
Interestingly, I looked through a bunch of listings for glow tape, and 1cm width almost always looks very green, as if the plastic itself were colored green. I have a sample of such tape and it is extremely weak. The one that looks whitish in daylight is much better. I suspect different widths are manufactured by different places, which then sell the same rolls to different sellers.
Yes, that’s likely how it is. The narrower widths might come from a different manufacturer. I’ve had good luck with the 4cm version from that particular shop. However, there are many other shops on AliExpress that might also carry the 4cm or 3cm widths.
For example this other shop seems to have same product: aliexpress.com/item/1005013364558300.html
I received the 4cm 5m tape, and it is the best glow tape I’ve used. Here are some quick tests against 2 glow tapes I had around, plus a glow button I made. All photos are taken after 1 minute in the dark; the exposure is not fixed.
Interestingly, the relative performance between tapes changes depending on the charging method. The next 3 photos are (1) long, high-intensity 365nm UV charge, (2) long, high-intensity visible light charge, (3) short, high-intensity visible light charge.
While the glow tape outperforms all other glow tapes I’ve tried, it does not match the brightness and duration of a solid glow object. This is unsurprising since glow powder is somewhat translucent, so thicker layers will be brighter.
Next is a photo after half an hour of low-intensity charge (by the ceiling lamp around 200 lux), plus how the objects appear under the ceiling lamp.
Finally, to test whether UV or white light is better for charging green glow objects, I subjected identical items to a long, high-intensity charge by both sources, before bringing them together for comparison. White light (LHP531) on left, UV on right.
Visible light has a small advantage over UV, at least for charging green objects. The UV-charged object glowed brighter for a fraction of a second, followed by a faster drop-off compared to a charge by white light. For shorter-wavelength colors, UV may still outperform visible, which contains less light below the emission wavelength of the powder.
