Something a little different for you today, a bolt action operated triple output flashlight incorporating white, red and 365nm UV emitters.
CRX Bolt Action Luxeon V2, XP-E2 Red, Seoul Viosys 365nm UV - KD I3N - 18350 - Bolt Acion Sw - 420lm.
Hand made.
Brass construction.
Lumileds Luxeon V2-5070
Cree XP-E2 R2 N4 620nm Red
Seoul Viosys 365nm UV Z5
20mm triple Noctigon MCPCB
8mm thick aluminium heatsink
22mm x 1.5mm ARC glass
Dual TIR/ Reflector optics
Diffuser film
KD I3N 3 channel 2 mode driver (Max 1500mA)
6mm x 1.5mm green tritium vial
17mm glass tail
Bayonet sprung body lock
Felt lined battery tube
Momentary on switch
Bolt action locking tail switch
Max - 420lm OTF (White)
Length – 95mm
Width – 25mm
Weight – 176g (with 18350 cell)
I drilled out & replaced one of the TIR wells with a small reflector filed down to size as the plastic does not allow UV light to pass through, also a disc of diffusion film was added.
Sprung bayonet head to body locking system. Glass covered tritium vial.
KD I3N three channel two mode driver, simple operation:
LED 1 On (High) > LED 1 On (Low) >
LED 2 On (High) > LED 2 On (Low) >
LED 3 On (High) > LED 3 On ( Low)
The light works by the side bolt in the tail, momentary On and a locked On position is available by pressing the bolt down and across in the channel. It has a very smooth natural feel to it operating by thumb :THUMBS-UP:
