Some of my mods to the small DQG flashlight range.
CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Button & Twisty Tail Sw - 1600mW.
Made from a DQG Titanium pill capsule with Ti extensions & hand made copper parts, a little pocket monster
Osram PLTB450B 1600mW 450nm 5.6mm TO56 Diode
3-Element collimating glass lens assembly
9.5mm x 0.7mm ARC protective glass
Copper diode housing & heatsink
Head twist focusable
Upgraded focusing spring
Silicone compression focus O-ring
0-1600mA adjustable potted single cell boost driver
Brass lined body parts
Magnetic momentary tail switch button
Lock-out able
Blue GITD glow inserts
Magnetic tail & keyring holder
Max - 1600mW, 1.6A (Around 1120mW OTF with 70% efficient 3-E Lens)
Length - 79mm
Width - 12.7mm
Weight - 35g (With 10280 cell)
The centre glow part in the tail is the magnetic momentary button, surrounded by an 8mm x 4mm neo ring magnetwhich fits into a magnetic keyring holder.
CRX DQG Titanium 10180, 10280, 10440 Pocket Charger/ Spare cell carrier.
This titanium spare cell/ pocket charger, being modular can carry and charge 10180, 10280 and 10440 cells.
It has a 100mA charge rate.
Made from a DQG titanium pill capsule & extension pieces plus a charger unit from a 10180 rechargeable flashlight.
The section with the brass rings can be removed & used to extend the laser to use a 10440 cell and the remaining sections will still house the other 10280 cell that the laser normally uses.
This is made to accompany my:
CRX CuTi Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW Laser.
DQG Hobi Ti+ Seoul Viosys 365nm UV & Petrol Lighter - ZWB2 - DD - 10250 - Twisty Sw - Rechargeable
A torch in both senses ;)
Seoul Viosys Z5 series, 365nm UV LED, CUN66A1B
10mm sinkpad soldered to brass pill
Ground down 11mm ZWB2 filter
Direct drive, single mode
10250 cell
2 x 6mm x 1.5mm green tritium vials
Magnetic detachable tail unit
USB rechargeable
DQG petrol lighter
Max current 500mA
Seoul Viosys UV on some currency
djozz UV Emitter Tests
CRX Utility Keyring - CRX CuTi Atom, Ti Hobi+ 365nm UV & Petrol Lighter, Ti Pen & Toothpick, CuTi 1.6W 450nm Laser.
DQG Hobi Ti 532nm Green Laser - 10250 - Mo, Twisty Magnetic Tail Sw.
Powered by a 10250 cell and has a magnetic mometary/ twisty tail switch, this is made from a DQG pill capsule and three extension pieces.
The beam is extremely visible at night but can be seen in daytime too with the aid of some smoke blown on as shown below.
DQG Fairy Brass XP-E Red - SD - 10180 - Twisty Sw - 140Rlm
CRX Brass DQG 10180,10250,10280 Charger - 70mA - 200mA
DQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Twisty Sw
DQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Fw Clicky Keyring Tail Sw - Anodised
CRX DQG PCL - XP-L HI v2 1A - Hobi+ Driver - 10180 - Twisty, Mo Magnetic Sw - 90lm
DQG Hobi Ti & Brass Aspheric XP-G2 - DD - 10250 - Tail Charger Module
DQG Hobi Ti XHP50 J4 3C - FET 10 - 2x10250 - Mo Side Sw, Tail Twisty - 1600lm
DQG Hobi Ti & Cu XHP50 J4 3C - FET 10 - 2x10250 - Twisty Sw - 1600lm
DQG Hobi Ti SST-40 - QTC/ DD - 10440 - Twisty Sw - 1300lm
DQG Spy Ti XP-G2 NW - SD - 10180 - Twisty Sw - 100lm - NeckChain
DQG Spy Ti runtime graph:
DQG Hobi Ti Dual XP-L HI & XP-E2 Amber - SD - 2x10250 - Twisty Sw - 120lm
With XP-L HI v2 1A and XP-E2 Amber emitters. 2 x MBI 10250 cells.
DQG Hobi Ti Nichia 219C 5000K - SD - 10180 - Fw Clicky Magnetic Tail Sw - 110lm
DQG Hobi Ti Nichia 219C, magnetic forward clicky tail switch. Can work by tail switch or twisty, starts on low or high mode.
DQG AAA Clicky Samsung LH351D 4000K 90 CRI - SD - 10440/AAA - Fw Clicky Sw - 174lm
DQG AA Ti XP-L HI v2 1A - FET 10 - 14250 - Fw Clicky Tail Sw - 924lm - Rechargeable
XP-L HI v2 1A on 16mm Noctigon
Narrow spot TIR
FET 10 driver
Potted
Graphite aesthetics
Forward clicky magnetic tail switch
Green 6mm x 2mm tritium vial
Micro USB charging port (300mA)
ME4056 charging board
Max - 924lm OTF
69mm x 18mm
Weight - 45g with 14250 cell
Unscrew the head to reveal the micro USB charger port.
Forward tail clicky soldered into brass tube and fixed to tail cap with brass contact ring. Brass contact points in head unit.
Charging unit is potted inside a copper housing.
A 300mAh 14250 cell is used with this light.
To charge, remove flashlight head, turn on the clicky switch and connect USB lead.
Red indicator for charging and green for charge complete.
The charge current is 300mA maximum, around 1C for this 300mAh 14250 cell, charge time about 1hr:10m
DQG Slim SS Seoul Viosys 365nm UV - ZWB2 - 3x7135 - 14250 - White RV Clicky Sw
Noctigon MCPCB
Hand made copper pill
Ground down 15mm ZWB2 filter
3x7135 driver, single mode
Reflectored
14250 Cell
Lighted reverse clicky switch
Max current 1000mA
DQG Slim Ti Samsung LH351D 4000K 90 CRI - FET 15 - 14250 - Rv Clicky Sw - 924lm
DQG Slim Ti SST-40 - FET 15 - 14250 - Rv Clicky Sw - 1500lm
DQG Slim Ti SST-40 - FET 15 - 14500 - Rv Clicky Tritium Sw - 1500lm - USB Rechargeable
I made an optional charging module for my DQG titanium extension tube light.
Made from copper, brass and carbon fibre tube this has a micro USB charging port supplying a tiny ME4056 charger board modified to supply 350mA charging current. Red & green charging indicators.
Remove the flashlight head to reveal the charging unit, click the tail switch on and plug in USB lead to charge.
Luminus SST-40 on 14mm Noctigon
MTN 15mm FET driver with GuppyDrv3 firmware
Cyan GITD LED surround
Hand made copper pill, charging unit & switch housing
Reverse clicky tail switch with green Tritium Vial
Magnetic tail
Length - 104mm
Width - 17mm
Weight - 62g with 14500 cell
Max around - 1500lm OTF
