How to install it?
It sticks pretty well on an even glass lens surface. Best position is to place it between the lens and bezel for secure fit.
What is it good for?
Protects the lens (if inserted on the outside)
Makes a throwy light floody
Evens out an uneven tint (Cree rainbow)
Before (with a noticeable tint shift, green ring around the hotspot)
After (also a minus green filter added to reduce overall greeniness)
How much does it reduce output?
5-10%
Does it affect tint?
It evens out the tint throughout the beam so yes, the hotspot will probably be different if you used it on a light with a horrible emitter.
Thanks maukka for doing the testing for us. Now, could someone make those before and after CRI test charts into a mouse-over so that the miniscule differences can be seen quickly?
Thanks for taking the time to do this. It’s good to have this sort of information documented.
Long term, it might be nice to have this kind of information indexed somewhere for easier access than sorting through forum threads.
Also, has anyone ever done a controlled comparison of DC-Fix vs. a matte finish tape like Scotch “Magic?” I’m curious if the DC-Fix diffuses a different amount, is more durable, sticks better, etc.
I haven’t done the math or the measurements so this is just a guess, but it might just be a function of lens size. Bigger lens = more diffusion film = more diffusion.
Just an educated guess. If you already have a somewhat diffused light (eg small heavy OP reflector or frosted optics), naturally adding more diffusion doesn’t have the same impact as diffusing a very narrow beam (large SMO reflector).
Okay, here’s a thought. It would be nice if someone would test this hypothesis. Compare a small, but throwy light (such as Convoy C8), to a larger, floodier light (such as BLF Q8), both with diffusion film. I’d love to see measured results.
Doesn’t sound right. It seems to me that
Bigger lens = less light hitting any spot = just like lower mode = no effect on diffusion.
Though when pattern size is large in relation to lens size that would be different.
