Thanks for posting that other tint comparison picture for others as well Boaz. This picture reminded me of a sunset with the orange street light shining in the corner. The LH351D'S are a bit brighter in this comparison as both lights are at level 130/150, but when the LH351D'S are throttled down a bit they match the 219B's pretty closely. Loving the zircon and Rosco filters. Very neat.
PM sent for some removal of some angry blue W1ās and to fix a few SST20 4000k lights - good CRI but I canāt stand the tint too yellow/green . Also this stuff fixes XPL Hi 5000k removing the green tint and making them a nice neutral tint.
Thank you for selling these films in small pieces!
I really like the #3 soft diffusion film. I added it to my Emisar D4v2 with the SST20 4000k emitters to smooth out the mild artifacts, and it does a good job without hurting the hotspot/throw much.
Then I decided to try the Carclo 10621 throwy optic in that flashlight. Normally I wouldnāt want to use that optic because I want a floody beam, and I donāt like the ring artifacts that optic makes. But with the #3 film on top of it I get a smooth, nearly artifact-free beam that is a little more throwy than with the 10622, but still has a good spill and a soft transition between hotspot and spill. Iām going to try that for a while to see how it suits me.
I just tried the #7 diffusion filter you gave me a small sample of. On top of the 10621 optic it diffuses the beam so much that it looks about the same as the 10622 optic. It pretty much negates the effect of the 10621, so thereās no point to using it in this flashlight. Its extremely fine frosting would make it a great diffusion filter if I wanted that much diffusion, though.
I also got the Z2 1/8 minus green filter to try out even though my SST20 emitters are not noticeably green (I must have gotten a good tint bin). The filter makes the beam slightly rosy, which I like. It is not enough to be off-putting, and I eventually stop noticing it, but I like the additional warmth of the beam. I am using that and the #3 film together.
To cut circles of film, I use the optic as a template and trace around it with a fine-point marker (I use my 10623 frosted optic because the smooth optics slide around too easily and I canāt get a good trace - Iād have to hold them in place with double-sided tape). By cutting just inside that line, I get a circle that fits perfectly in the head of the flashlight between the optic and the glass lens.
I got a few other films as well (#1, #5, #F4 (CCT Reduction), and #F5 (Red)). If I get around to experimenting with them and have any interesting experiences, Iāll report back.
How durable is the Lee 205 filter, compared to ones denoted as āZirconā? I know theyāre both the same brand, but wonder if thereās a thickness/durability difference.
Also, is the Lee 205 1/2 CTO similar to the Zircon 806 Warm Amber 2?
Two rather tough questions .
Not only are Zircon filters longer-lasting than their standard counterparts, theyāre sturdier, too.
Manufactured using a 180-micron material, they are more than double the thickness of a normal lighting filter. This makes them more durable and easy-to-use.
Zircon still delivers in excess of 85% efficiency up to 20 months after installation.*
* Test data based on 11hrs continuous illumination per day over 20 months at 1-2cm clearance between LED chip and Lens/Filter interface. Average reduction in efficiency across all tested lamps was 12%. Performance may vary dependent on the individual application .....
Is the Lee 205 1/2 CTO similar to the Zircon 806 Warm Amber 2?
-The Zircon Amber 806 warm amber 2 would turn a 6400K into a 3250K
while a 205 1/2 CTO turns a 6400K into a little above 3800K
I just got a 24" x 21" sheet of Lee 205 1/2 CTO that I bought off of Amazon. It was shipped in a sturdy cardboard tube. I didnāt employ it on a flashlight, but instead on a desk top lamp (actually using it as a bedside lamp). It feels pretty thin. After unrolling and re-rolling the sheet a few times, I did notice a slight crease/dent in a few places. However, it does the job beautifully. I attached it using optical adhesive (no air bubbles). My lamp CCT is about 6000k. Now it feels more like 4000k.
The camera white balanced automatically... so it's harder to see it in the first photo on the right. But the photo below has both front and main LED banks on, forcing it to balance. You can see the CRI difference.
Question for all you DC-fixersā¦ I love my D4V2ās with E21Aās in them, but they ship with the diffused optics for good reason. I have tired the clear tight focus Carclo optics and they really screw with the final beam. Would DC-fix fix that issue? I really want just a tad tighter focus, but really not down with the ugly beam.
Number 3 might be inbetween.
Just added some #1 to my SC31 and itās a huge improvement for my usage. Made an okay light so much better. Thanks for offering these small pieces Boaz, much appreciated.
Happy I could help you out Natcho.
by the way ... Nice first post
This is what I have done so far. I needed to warm upā¦.I mean downā¦. my D4V2. Picture is the most realistic tint comparison to real life that I have been able to achieve. Like it says in the pictureā¦I used Z-2 once and doubled up on F-4. I kept trying different sheets until I achieved the closest tint to a candleā¦ 100% what I was going for!
I had misplaced my order of diffusion films, but it finally showed up the other day, and I upgraded my Convoy M21B GT FC40 with a layer. Thatās an amazing torch by itself, but, diffused, itās a really satisfying beam.
PM sent. Thank you!
Happy to help in any way I can :)
New stuff just came in.
Supply chain issues and two increases in postage ...ain't no thing
Ordered now a set of some films, better late then never ā¦ thanks for your service Boaz !
7+ years of selling smaller pieces of Dc-fix and minus green filters to members here on BLF .
Think it's time for another giveaway .
Thanks to all you guys who I've had the privilege to be in contact with over the years .
My 12 year BLF anniversary is coming up and ...I don't plan on going anywhere :)
Just wanted to say thanks
Hi Boaz,
those minus green filters sound great
PMāed you for an order
Finally put an order in to try some DC Fix at last!
Thank you Boaz!
PM incoming!
