A description of management:
SC - single click, DC - double click, TC - triple click, LC - long click
From OFF state
SC = LO
DC = MED
TC = HI
LC = TURBO. No preflesh to LO, directly go to TURBO after 1s
From ON state
LC - switching between LO-MED-HI. Switch works only in one direction.
SC - OFF
DC - Turbo
From Turbo SC always translate to the previous mode of operation, if any, was not (the lamp was turned on by LC) that translates in the LO
All activities except LC occur when the button is released
Turning the lamp occurs in about 0.1 s after the first press of the button. When the delay is palpable with powering to LO mode by the SC, powering to HI mode seems that flashlight power on instantly.
Switching modes is activated at about the same delay as the powering on, ie almost instantly.
On personal feelings switching modes close to the ideal, because all modes are available from OFF state.
Dont worry about accidentally pressing the button, it is not necessary, why - is clear from the gallery:
Group photo with other my flashlights
Photos of disassembling
All parts at one photo. Very thin back cap
Thickness of negative post. Insulator thickness around 1.3mm so back side has near 1mm.
Head without besel. Button front view. It is recessed relative to the ring around it.
Head without besel. Button side view. Button move around 1mm. Accidental pressing unlikely
Head without lens. Standart microswitch
And at last v4 has heatsink layer!
Driver removed from head with heat and not so brute force push from lens side. just pushed it with toothpick
It has no thermal compound on heatsink. Heatsink are super thin.
Inside adhered at two locations on the gray thermally conductive adhesive.
However, the thermal conductivity will be much better than in the third version since battery presses pill to the head of fl. And if we add thermal compound on the edge, it will be absolutely wonderful moderately good. But this pill is no substitute for normal pill, no.
As a design feature in this case it is necessary to note the presence of foam insulator required by the (+) as it plays an important role in the pressing pill to a head and, in addition, does not allow to push the positive contact of the battery. прижимать
There are serious suspicions that the heatsink is actually organized on the positive battery contact.
Beamshots and other tests on the way.
