We’re back to the original purpose of this thread today, with some pictures of my headphone modification. Grado headphones are quite a famous name in the industry, causing probably more controversy among headphone enthusiasts than any other brand. Their sound signature and looks are both polarizing, to say the least.
Anyway, I had a pair of Alessandro MS1i (slightly modified Grado SR80i) for a while now and I enjoy them a lot. The only issue is - the people at Grado seem to actively look for the worst cables known to mankind and then mount them directly without any connectors. Truly terrible.
I had modified some SMC receptacles (RF antenna connectors that happened to fit nicely) in there before so I could add detachable cables, but since I got my second pair of headphones, Focal Elear, that came with one mono jack per side, I wanted to replace the receptacles of the Grado again so both headphones could use the same cables interchangeably.
First I had to file the holes in both the “inner” and “shell” part of the housings larger, as originally they were made for ~3mm thick cables, not full size headphone jacks. I decided to mount the jacks only to the inner part, and have the outer part slide over them. This makes them less noticeable, and makes it easier to assemble, as the receptacles screw and solder into the inner part only.
I kept a piece of the original headphone cable for wiring, so I would not have to solder onto the drivers directly. These can be quite temperature sensitive, depending on how they are built.
Since the original earpads are a bit too small (they are on-ear, not over-ear) for my taste, I am using Grado G-Cush pads, which are usually only made to fit on the larger top-end models from Grado. I made 3D printed adapter rings from rubber filament to adapt them onto the entry level grados.
All in all I am very happy with my mod. Being able to swap headphones while keeping the same cable makes it a lot nicer to use my two pairs now
Oh, the paracord wrap on the headband is obviously custom as well. I used Type V paracord without core in a cobra stitch. The bands themselves are only a single layer of artificial leather (aka plastic :D) over a thin spring metal band. Very uncomfortable for longer wear. The paracord softens it nicely.
Headphone cables are DIY as well, Sommer Cable Cicada-4 cable with Amphenol headphone jacks and Paracord sleeving. The thinnest, lightest weight cables I could make with a soft and nice to touch paracord sleeve. Amphenol jacks cost a fortune, but I just love how they look and feel, and the quality is impeccable, so I use them for all audio connectors.
