Last weeks I received some parts I was expecting to make some triple builds/mods. I had some issues making them “happen”, and they are not the final result I expected in some of them, but they are my new “babies” and I will treat them well!!
When building them I was confronted with some interesting aspects, namely the TIR lenses and the resulting beams.
So I decided to explore that, make some pictures and let people see what they can expect from some triple TIRs and LEDs.
First, a description of the lights, from left to right! All the images below will follow the same order.
(all the external links are non affiliated, they merely indicate where I bought the parts)
S2+ Desert Tan with 18350 tube : AR Coated Lens (brownish coating, not purplish); Carclo 10507 (Narrow Spot) ; XP-G2 S4 5A (4500K, “Warm Yellow”) ; Regular S2+ Pill and retaining ring soldered with kiriba-ru spacer ; BLF X5/X6 driver ; Metal button ; Pocket Clip
S2+ Black with 18350 tube : Clear glass lens; Carclo 10508 (Frosted Medium Spot) ; XP-G2 S4 3C (5500K, “Warm White”) ; kiriba-ru S2+ Triple Pill with custom retaining ring; 17DDm MTN driver with guppy3drv ; Forward Switch (mix of this and this ) ; Pocket Clip
S2+ Mini (“blueish”, not gray) : Clear glass lens; Carclo 10511 (Frosted Narrow Spot) ; XP-G2 S4 3D in Noctigon ; Regular S2+ Pill soldered with kiriba-ru spacer & custom retaining ring ; TA Bistro HD OSTM Driver from Lexel ; Lighted tail switch ; Blue tailcap ; Pocket Clip
Sofirn SP32A: Original AR Coated lens; XP-G2 S4 1A (6000K, “Cold White”) ; Jaxman Optics (equal to Carclo 10507 :???: ); Spacer: a piece of brass that I cut and arranged for this light (Modded HERE) ![]()
Some photos now ![]()
[Click on them to enlarge the photo on new window]
All lights have a piece of glow-in-the-dark (GITD) tape around the TIR optic!
:sunglasses:
BTW, I guess that on lower output levels, and against white surfaces, the GITD has some influence and reflects a bit, “shifting” the tint. (Top: DT >>> Black ; Down: Blue >>> SP32A)
Above paper, the beams’ shape in close-up!
_
Some thoughts!
- The Clear lenses (10507) are the ones that show more the shape of the LED, and seem to have the worst beam pattern and highest tint shift, specially with Cold White LEDs! Despite this, maybe these are the lenses that allow more throw, specially with CW leds.
- The Medium Frosted (10508) allow a nice floody beam, and if used with Neutral White Leds (or eventually Warm White) will make an excellent combination for close range use.
- The Narrow Frosted (10511) give a nice combination of flood (less than the 10508) and hotspot. However, it seems to me that they allow some tint shift, despite I don’t know if this is mostly caused by the LEDs. The S2+ Mini, with the 10511 lens, has the same type of LEDs as my Emisar D4 (XP-G2 S4 3D), and both have the same issues despite the lenses: yellowish hotspot on lower outputs and a rosy outer spill on highest outputs. Maybe a completely Frosted Lens could avoid this?
- The Jaxman triple boards (I bought 1 of each) are quite nice, but the holes for the TIR legs are narrower than those of the Noctigon MCPCB. If this helps to hold the TIR in a better way, it makes it harder to change and continuously experiment different lenses with different LEDs.
- Also, I would prefer the Neutral White and Warm White (or Warm Yellow) LEDs over the Cold White ones, despite I think that all of them would look very nice and with few shifts if used with completely Frosted lenses (10508).
Or maybe using some kind of diffuser, as DC-Fix or something alike :+1:
And this is it!
If you have comments, questions or experiences with triple TIR lenses and XP-G2 LEDs, bring’em on ![]()
Best regards!
