First Impressions of a stock Sofirn HS10 w 2700K LH351d.
Compatible w 16340 LiIon.
The manual does not list CR123 as an option, I just tried a CR123 that is at 3.1V and the Red low battery indicator light on the switch came on.
More pics in this photo Album: Sofirn HS10 w stock 2700K LH351d - Album on Imgur
The light arrives in stepped ramping mode and turns on in High Mode. My meter says the output steps are:
0.8
28
115
320
630 lumens
(w battery at 3.87V as received)
There is a smooth ramping mode, enabled by 4C from on
Although the ramping is a little quick, I can reach other outputs than the stepped modes.
There is last mode memory.
The light also works while charging, even with the battery removed.
The lens produces some rings in the outer beam, but in actual use my eyes focus on the middle of the beam.
things I like:
Easy to find the button by feel
Once pressed, the button reports battery status, which is very convenient.
The headband is super comfortable and lightweight with the light installed… Makes for a very convenient HeadLamp.
There is also a tailmagnet that could work attached to a car body during a tire change, or to attach to the open rear hatch of a car, for a tailgating party.
Im a big fan of the ramping UI option.
The built in charging is great for gifting the light to a muggle.
things I dont like:
the stock LED is on the yellow side of the bbl, but its not that bad at such a warm CCT
the pocket clip is not deep carry, and the bezel prevents the clip from fitting in front. When using the headband, the clip gets in the way of the loops that hold the light. Overall, I see little benefit to installing the clip.
The flicker modulation depth is severe, I would prefer a more stable regulation, but for the price, I think it is still a great light. It can be gifted to a muggle, kept in a car kit, or used around the house or at camp. I keep an HS10, installed in the headband, in my backpack as part of an emergency kit, with a firestarter and a knife. I also consider the HS10 as a backup battery carrier. My EDC is also 16340 compatible.
All things considered, I enjoy the HS10, as an inexpensive, lightweight, and convenient Headlamp.
UPDATE: LED swapped to 219b, details in this thread
