Thank you, raccoon!
Edit:
hang on, let me reinstall the stock firmware and i will confirm how many clics that version needs to get to a 100 lumen ceiling… this will take about 5 minutes…
ok, on the stock Orange TS10 V2, it takes 75 clics to drop the ceiling to about 100 lumens
so, since one long clic equals 10 short clics, use: 7 long clics, plus 5 quick clics
Thank you, Jon. Will try that tomorrow. Never thought I’d be programming flashlights at my age. lol. Flashlights have come a long way in a short time
me neither… lol
btw, I liked the way you asked a clear question
specific 100 lumen output goal correlated to a specific ramp number.
That should be 75 clics down, so 7 long, plus 5 fast clics
my ceiling goal is about 340 lumens, as that is about the highest thermally sustainable output of this little host… it is at 50 clicks below max so I do 5 long presses…
Update on my TS10v2 that turns blue:
After doing a turbo run for the warranty claim’s video, I disassembled it to inspect for damage, because I noticed it was turning blue faster.
All of the emitters have noticeable burn spots on the phosphor already, with one that’s pretty dark.
@Wurkkos_Terry could you please help me out?
Are these emitters soldered correctly?
My older TS10 brass was not doing any of these things like turning blue despite several uses of turbo…
So we have now 2 cases of burned LEDs, so far I know…
I can’t speak about the soldering as the light came this way.
The burned out emitters seems like an issue only with the TS10v2, older lights had a different batch of emitters, and a brass TS10 has a decent bit more thermal mass too.
I have now 14 TS10s and this is the first one to damage the emitters with the stock battery.
Since these CSP2323 have no dedicated thermal pad (see test) they rely on heat dissipation through the solder pads. The heat dissipation here is primarily limited by the LED board used, not by the thermal mass of the host.
This is the reason, why these are burned. The current (heat dissipation) is simply too high. I am wondering why this wasn’t the case with the older TS10, maybe they changed LED manufacturer or using another type of CSP LED. These things are manufactured by many companies in this size, so visually it is not clear if these emitters in the TS10 V2 are really LatticePower CSP2323.
The driver give too much power in turbo.
This is the reason why my default level is 100 and with turbo I see smoke so I stay safe.
I think in this second batch the LEDs are not the same as the first batch
I believe turbo and highest ceiling are unsafe to be the defaults with the TS10.
I would like to see the highest output modes disabled by default but available as an option that can be enabled by the user if desired.
@Wurkkos_Terry is this something that you are aware of or could consider for future revisions?
So the firmware defaults are set wrong for the TS10 V2?
Maybe they changed the specs on the mcpcb?
or maybe it needs more Thermal Paste under the mcpcb?
who wants to remove the mcpcb to check?
or maybe the Thermal Ceiling is too high?
who wants to test a lower ceiling on a TS10 that turns the LEDs blue?
If anyone chooses to update the firmware, I believe it uses a higher thermal ceiling… probably more likely to burn the LEDs
does anybody know what the Thermal Ceiling default is w the stock Orange V2 firmware?
Good idea.
Maybe it’s the same problem I had with several Convoy S21F: burrs and rough edges on the edges on the underside of the MCPCB. As a result, it does not sit evenly in the host and heat dissipation is massively impaired, especially if there is too little thermal paste underneath.
Report of TS10 V1 w H10 battery:
“It ran well for a couple of days on normal modes, but after about 5 seconds on turbo it failed.”
It was a modded light. It’s anybody’s guess what happened.
Just wanted to thank you Jon, for going out of your way to find the 100 lumen setting. It is much appreciated. Oh, and it worked, too! Way cool, or should I say cooler.lol
