Update 15.12.2015.
Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
Specifications
Led type: SMD 3535
Led color : Ultraviolet
Chip(die): Semileds
Package size: 3.5×3.5×2.0 mm(XP footprint compatible)
Dominant wavelength: 365-370nm
LED Power rating: 1W
Forward current: 350mA
Peak pulsed current: 700mA
Typ. forward voltage: 3.5V
Typ. radiometric output: 410mW(+-7%)
(If=350mA,Tj=25C)
Viewing angle: 120deg
Operating temp. range: -20~+80C
Already tested by djozzTM
here : https://budgetlightforum.com/t/-/36025
Great review as usual,so I want to thank djozz once again,and I will copy/paste just his conclusion about this LED here:
"Conclusion: I think this led is a great one, the UV-output is at least close to 365nm and the amount is impressive, more than the Nichia NCSU276A U365, and it comes from a small XP-E size die, so it can throw as well if you like that. The only drawback is the large amount of visible light it puts out as well, like most 365nm leds btw. I solved that by using a UV-pass filter, but these filters cost some money, between 10 and 20 dollars.
Thanks for reading!"
So this LED has efficiency similar to high-end UV leds like nichia 276A,or about 3 times more than decent lower cost LEDs like mentioned RY3535UV,or 10-15 times more than cheap ebay UV leds!
Notes:
*Power rating of this LED is 1W (350mA),so overdriving affects led characteristics like lifetime and wavelength,just like in case of white leds.According to djozz's tests,it seems that max./optimal driving current for this LED on Noctigon should be around 700mA.
*This is budget/low cost LED,so there may be tiny imperfections like little off-centered die and dust on lens that doesn't affect output of this LED.
Price:
5.9$/piece
_______________________________________________________________________________________________
ZWB2 20x1.5mm filter lens
Price:
1.9$/piece
Shipping: Priority airmail shipping(pretty fast): +2$
Tracking number option: +5$
Estimated shipping times:
EU 3-5 days
World 5-20 days
Paypal fees-included
Paypal and contact/info: led4power@hotmail(dot)com (replace (dot) with .)
Note:for Italy only tracked shipping is available
Thanks
