Up for sale are 2 NON BLF X6 running 3up nichia leds,FET driver with (guppydrv) with copper pad & braided tailcap .....everything is new asking $60 shipped ea
User Selectable Groups:
2% - 25% - 100% | Memory
100% - 25% - 2% | No Memory
2% - 25% - 100% - Strobe - Beacon | Memory
2% - 25% - 100% - Strobe - Beacon | No Memory
15% - 100% | Memory
100% - 15% | No Memory
100% Only
100% - Strobe | No Memory
Strobe - 100% | No Memory
ML - 5% - 33% - 100% | Memory
100% - 33% - 5% - ML | No Memory
ML - 5% - 33% - 100% - Strobe - Beacon | Memory
ML - 5% - 33% - 100% - Strobe - Beacon | No Memory
ML - 100% | No Memory
100% - ML | No Memory
ML - 100% | Memory
ML - 5% - 15% - 50% - 100% | Memory
ML - 5% - 15% - 50% - 100% | No Memory
100% - 50% - 15% - 5% - ML | Memory
100% - 50% - 15% - 5% - ML | No Memory
2% - 15% - 50% - 100% | Memory
2% - 15% - 50% - 100% | No Memory
Guppydrv Instructions
To switch mode groups: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
Example: To select mode group 3, tap the switch 8 times quickly to enter programming mode. As soon as the light enters programming mode and starts flashing, tap the switch three times (for group 3). The light will blink to recognize the mode group change.
By the way, I have no high discharge 18650 at the moment, which battery would you recommend to run with this beast of a pocket rocket? Safety first of course. Is there such a thing as protected high discharge cells?
