Tbh I have no idea, I never even found out what my number was. Stuff always seems to come slower if you check the tracking number
Still zero movement on my tracking number :(
Got mine today. Good shape. Donāt like the tint. Installing XML-2 5B1ās on Noctigons from IO ASAP.
I ordered two. They came in today, un-announced. USPS still says they are in some California sort facility. The box looks like it was sat upon by a herd of overweight elephants pregnant with quadruplets. Lights survived elephant attack intact.
Tossed one into the Sphere āo Many Mysteries:
High: 1900 lumens, 7.4 amps @ 4.0V, 6475K
Med: 1064 lumens, 3.9 amps
Low: 257 lumens, 0.8 amps
Strobe: 10 Hz
ALL modes, including high, show 615 Hz PWM.
Parasitic drain is minimal (< 3 microamps).
Thanks for the tests texaspyro! Now what is the ETA on those drivers?! :p
I THINK that my driver can be made to work in the M6ā¦ havenāt tried it yet.
You would need to remove the old driver, install the M6 driver retaining ring, wire up my driver, and then fasten the bottom edge of my driver to the top of the retaining ring with some easily removable adhesive (like a couple of spots of Fujik or other weak silicone adhesive). Just something to keep the driver from flopping around. The contact rings of my driver would sit up 3mm above where the M6 driver sits up. The M6 springs easily compress 7mm (the top rim of the cells stick up 5mm). There could be some fit issues with protected cells.
I played around with my new light in the dark and it is super but because it has no handle and because it is so short it gets to hot to fastā¦30minutes on middle and its unholdable
So has anyone found a handle for itā¦maybe from some furniture or door handleā¦
Edit: I just searched my 15 year old flexible mini tripod and it works nice as a handle.
if/when you get your driver in it, you going to take new readings?
eeek, itās a pity thereās PWM even in the high mode.
How noticeable is it?
FINALLY!
My light has moved. Well, more of teleported, because thatās as much sense as the tracking makes. It left the LA ISC facility and appeared in Renton, WA a mere 1,100 miles away.
Notice Left August 5, 2013, 4:19 pm RENTON, WA 98058
Processed Through Sort Facility July 28, 2013, 4:43 pm ISC LOS ANGELES CA (USPS)
Well heck. Iām in Texas too and still havenāt received any tracking info showing mine is even in the US yet. Supposedly left China on the 27th and nothing since then.
Oh well, glad you have yours and that they are doing just fine.
I didnāt see any. I think it is like the Qlite/Nanjg drivers where they donāt program the PWM generator correctly and it puts in a tiny pulse to off every PWM cycle (like 1/256āth of a cycle of OFF time). Still, itās bad form.
Great, thatās a relief. I thought it would be as bad as the Small Sun ZY-T11 light.
Thanks for your reply.
Here is a full test run I did of the light:
So it looks like supfire has mixed up some of the tracking numbers. The package notice I got on my door today didnāt match what I had been given. At least somebody is able to track your package, even if it isnāt you!
If thatās the case, I hope that the number I have is wrong, cuz my package hasnāt moved in tracking in over a week now :)ā¦
This is whatās happening with mine atm. 6 days to show movement from China. 1 looks like itāll be here next day or 2, the other looks to be stuck in China still lol
NULL PVG US 20130729 0836
Depart USPS Sort Facility
August 5, 2013
LOS ANGELES, CA 90009
Registered Mailā¢
Processed through USPS Sort Facility
August 4, 2013, 9:20 pm
Origin Post is Preparing Shipment
Acceptance
July 25, 2013, 8:21 pm
CHINA
Results 2
Registered Mailā¢
Acceptance
CHINA
Where/what are you using for trackiing?
My 2nd pc is now stateside. Hereās the units tracking:
Processed through USPS Sort Facility August 5, 2013, 1:12 pm LOS ANGELES, CA 90009 Registered Mailā¢
Origin Post is Preparing Shipment AcceptanceJuly 25, 2013, 8:21 pmCHINA
Hereās my first one during the same leg:
Processed Through Sort FacilityJuly 28, 2013, 4:43 pmISC LOS ANGELES CA (USPS)
Origin Post is Preparing Shipment AcceptanceJuly 23, 2013, 6:38 pmCHINA
My 2nd one took a week longer to get here for some reason. Maybe they had labor dispute?
Add the fact Supfire had to manually check emails and pms to get the phone numbers straightened out, that may have added to the delay some are experiencing.
Anyway, hope no one else has any more broken glass.
my tracking never move. still staying at Origin Post is Preparing Shipment. letās see if they gonna get here this week.
