Glow in the dark tailcap or/and o-ring would be really nice.
What “np” means ?
Means 'No Preference' in respect to either Cool White or Neutral White.
GITD bezel o-rings go into the trash as soon as a suitable non-GITD replacement is acquired.
My current preference is:
1x NW
1x CW
if possible
Yeah… 300 units ordered! this sends a strong message to vendors…
Don’t mess with BLF
We got the power, man…
(Thanks for all the hard work, Krono)
Please leave the gitd o-rings for the little kiddie lights.
Thank You.
mu question is of there on the driver also voltage safety is ?
(for unprotected batteries that go unter the 3,7 volt) the flaslight go out ?
I think it’s fine as long as I can remove or replace it with a black one.
Seriously.
I’m a conservative old fart, but my grandkids might like it.
To my generation dope means stupid or on drugs. Sorry dude.
Yes I know dude is not correct, but I don’t care enough to find out what’s the word of the moment.
Scandinavian furniture, stainless steel and Audrey Hepburn fashion,
Classic & elegant minimalist style.
Why against last mode memory?
I like being able to chose where my light starts.
That’s me.
I like being able to make choices, not have them dictated to me by someone else.
With memory and ship to multiple addresses, I want 11, without 2.
You can hold me to that.
If both ways are possible, make some each way.
If a choice has to be made, run a poll of buyers.
Put whatever modes and blinkers that you want, I’m gonna swap drivers anyway. Did y’all see the latest addition to Dales OP in the give away post?
I am already at 86 and 87 for 2 CW. Put me down for 4 more, 2 more CW and 2 NW.
I use my flashlights on all modes depending on what I'm using them for, I use low modes more often than high. The flashlight's memory is way better than mine so when I switch the light on it is always a complete surprise which mode it is in, most annoying: I want low/moonlight and the d@#*rn thing blasts away on turbo. I don't understand how other people manage to use/like memory in actual flashlight use.
(that's why :-) )
With last mode without memory (strange way of saying it, but it has evolved this way) there's no surprises and with half-clicks I get within a wink to any mode.
start on high is good for my ,low too
a real flashcoholic have the button under control like a cowboy his revolver
Easy way to fix the low/moonlight vs Turbo surprise is to make moonlight a special function that can be accessed in a different way while the flashlight is off, so you always know what you’re getting when you turn your flashlight on that way: moonlight. This is how Olight Baton S20 works. Hold down button from off position, in two seconds you get moonlight mode. Cycling up through modes will cycle back to low, but not moonlight. The light must be turned off and started over with the hold button to get back moonlight. However, if the light is shut off while in moonlight, it will remember and start back there when it is turned on with a simple click the next time.
Here’s how I use this to control my light so there are no surprises: If I know I want moonlight, I go directly to it, not counting on the memory to be in the right place. If I want any other mode, I’ll simply turn on the light, then cycle up to it. When I know I’m heading out to somewhere that I want a specific mode for, I set it to that mode before I go, then turn it off. When I get to where I need the light, I know it is at the mode I want it at, and I can just use it. When I’m done using the light, I usually try to set it back to moonlight just to be in the habit of doing so. Then, if I forget to hold the button down, and simply click it instead to turn it on, I’m at the least dangerous light level.
On the subject, here’s how the S20’s strobe works: The light must already be on in any mode. You quick-double-click to get to strobe. From there, one click will turn it off. Turning the light back on resets it to the last non-strobe mode you had it set to. Also, while strobe is on, you can cycle out of it, starting at the last non-strobe mode you had it set at. From there, it will not cycle back to strobe. I like these UI choices. Both Moonlight and Strobe have to be accessed a special way, but leaving them is easy and will cycle back to normal mode selection of Low -> Med -> High -> (back to low, etc.)
It doesn’t really matter though, as we so far don’t have mode memory in this light. So, the “no mode memory” guys have already won, unless there is a change. But, just wanted to say that I think a good UI with mode memory is more flexible, meaning it can be used by more people comfortably than having several modes with no memory. Everybody has a bias toward a certain mode for their light. Some will only ever use this light on lower modes, some on higher modes, some on every mode in different circumstances. Some may be getting several of these lights with the idea of keeping them in different places for different uses, and may need some to start on low and some on high. Last Mode Memory is the only way to allow for this much diversity in mode preference, because it is the only way we can each have control over our own light. If someone doesn’t know how to use that control to their advantage, why should that stop the rest of us from having it?
Don’t all of the “hold button from off to moonlight mode” lights work using an electronic switch? The X6 will be a just a regular switch.
No long presses with a mechanical switch. Such is the way of things. No off time drain on the cell either.
Goes to show, you can please some of the people some of the time…
Hi, can you add me please for a one in Neutral White? thank you
Updated list.
1 kronological nw
2 kronological nw
3 Bigblockmopar cw
4 ImA4Wheelr cw
5 Legolas Jr. cw
6 Ryansoh 3 cw
7 Yourrid nw
8 Yourrid cw
9 aussiet6 np
10 harry218 nw
11 harry218 nw
12 Werner np
13 freeme nw
14 freeme nw
15 ohaya cw
16 aL1 cw
17 DBCstm cw
18 DBCstm cw
19 Muto cw
20 DanielM nw
21 Tom E nw
22 Tom E nw
23 troisanh cw
24 RaceR86 np
25 RaceR86 np
26 jmpaul320 nw
27 David EF np
28 David EF np
29 Chicken Drumstick nw
30 netjrb nw
31 Cereal_killer nw
32 Cereal_killer nw
33 Chazzy nw
34 velectron nw
35 cellguy np
36 downlinx nw
37 p_k nw
38 The Spaz np
39 Defaut Username cw
40 mrmatt np
41 Gj nw
42 aoeu
43 The Burgh cw
44 JohnnyMac cw
45 JohnnyMac nw
46 shimey nw
47 Kurt_Norway nw
48 djozz nw
49 Boro nw
50 Boro nw
51 Blinky1 nw
52 penumbra nw
53 cnrffl1 nw
54 bgyen cw
55 max cw
56 max cw
57 max cw
58 mhanlen nw
59 andyz nw
60 sunnycoaster np
61 spamman np
62 tkmckay nw
63 tkmckay cw
64 Buwuve nw
65 Strongest2004 nw
66 Strongest2004 nw
67 Light Dispels Darkness np
68 Light Dispels Darkness np
69 syracuse nw
70 GTsuperheros cw
71 The Burgh nw
72 tristanxoxo nw
73 zelee nw
74 HHCC cw
75 Ray-o-Light nw
76 Ray-o-Light nw
77 CJW np
78 LowLumen nw
79 Ejected Filament nw
80 Ejectef Filament nw
81 Beachlogger nw
82 Beachlogger cw
83 Qandeel nw
84 blueb8llz np
85 aoeu np
86 southland cw
87 southland cw
88 Nightbird95 nw
89 atrroger cw
90 retiro675 cw
91 gouldy cw
92 gouldy nw
93 backtoback np
94 cellguy np
95 Calmaja nw
96 Calmaja nw
97 hein11ag np
98 hein11ag np
99 Lightsaber nw
100 Aardvark nw
101 antoninodattola nw
102 cajampa nw
103 saypat nw
104 aslpg nw
105 Siata94 nw
106 Siata94 cw
107 NeoGeo np
108 meti nw
109 ledsmoke np
110 ledsmoke np
111 ledsmoke np
112 dodo nw
113 Billy X nw
114 Moridin nw
115 bikenber73 nw
116 Lyubo Yanev nw
117 johnnydoe nw
118 g60 np
119 Ricflair cw
120 sunnycoaster np
121 sunnycoaster np
122 BILL G np
123 chenko np
124 Default Username np
125 Boaz nw
126 bugsy36 cw
127 bugsy36 cw
128 buggy36 nw
129 dangerous np
130 banker nw
131 Slim Pickens
132 KawiBoy1428 cw
133 KawiBoy1428 cw
134 velectron np
135 ChibiM cw
136 flashination nw
137 18sixfifty np
138 alphazeta nw
139 Banglabob nw
140 dave_ nw
141 Fmc nw
142 Scooter000 nw
143 kafar cw
144 jealous57 cw
145 sbradd
146 lionheart_2281 cw
147 guitar89 nw
148 guitar89 cw
149 doslyn nw
150 doslyn nw
151 sandanbob np
152 dantemens nw
153 raven38571 np
154 bdiddle np
155 bdiddle np
156 litefella np
157 crowne np
158 crowne np
159 D10ten np
160 cicciocant np
161 processengr nw
162 B42 nw
163 allthumbs nw
164 allthumbs nw
165 luckyseven np
166 M78 np
167 peterscm nw
168 richnpc nw
169 thebaum np
170 soddo np
171 tapir cw
172 hideehoo nw
173 arekm np
174 Muto nw
175 Muto nw
176 gpapa693 np
177 flashpilot cw
178 aussiet6 np
179 drudragon np
180 akoposilester np
181 GeoCan46 np
182 GeoCan46 np
183 Rufusbduck nw
184 flashhole np
185 Legolas Jr. nw
186 Scotlarock np
187 Scotlarock np
188 flashination np
189 OscarM nw
190 SirPaul cw
191 MRsDNF np
192 grantman321 np
193 johm nw
194 johm nw
195 ohaya np
196 eebowler nw
197 keengeorge nw
198 theoldbill cw
199 KawiBoy1428 nw
200 KawiBoy1428 nw
201 big block Mopar nw
202 Bak nw
203 Bak nw
204 dperreno np
205 s1m88 cw
206 zeremefico np
207 tryps np
208 glowz nw
209 angler np
210 mizjif np
211 antilop65 np
212 NobleX13 np
213 the nw
214 the nw
215 scdaf np
216 torchjinkie np
217 BLightSam cw
218 magnet np
219 lamper np
220 meteorxs nw
221 ACmech cw
222 ACmech nw
223 locusto03 nw
224 locusto03 nw
225 2DOGS np
226 Ohaya nw
227 Wojto nw
228 fireblade893 nw
229 Fireblade893 nw
230 The Burgh nw
231 mhemling33 np
232 saypat cw
233 Saigon cw
234 Saigon nw
235 DanielM nw
236 Charga cw
237 LSX cw
238 LSX nw
239 raccoon city nw
240 flitsmal nw
241 WarHawk-AVG np
242 Down_South nw
243 Down_South cw
244 will manners np
245 Lightning Bub np
246 Lightning Bub np
247 keengeorge cw
248 keengeorge nw
249 keengeorge cw
250 I ant np
251 LANTUS nw
252 chesterqw cw
253 Boaz nw
254 mhanlen np
255 nthesame np
256 Buwuve nw
257 Kafar cw
258 Kafar nw
259 tristanxoxo cw
260 DanielM nw
261 Ray-o-light nw
262 Nbabu nw
263 Pulsar np
264 Pulsar np
265 rchiang nw
266 rchiang nw
267 C-channel nw
268 C-channel nw
269 Lotus_Darkrose nw
270 Peetz nw
271 Peetz cw
272 saypat cw
273 chenko nw
274 chenko nw
275 jacktheclipper nw
276 Mikk0 nw
277 Mike72 nw
278 iron potato nw
279 264 nw
280 eta np
281 0elcid0 nw
282 nitro np
283 nitro np
284 ouchyfoot np
285 processengr nw
286 processengr nw
287 processengr nw
288 processengr nw
289 HBomb nw
290 peterscm nw
291 peterscm nw
292 peterscm cw
293 peterscm cw
294 calmaja cw
295 saypat cw
296 Adoby np
297 Adoby np
298 ilovejesuschrist np
299 jealous57 nw
300 billyx cw
301 JohnnyC nw
302 JohnnyC nw
303 vuanhquoc np
304 apt323 nw
305 Slow2go cw
306 Slow2go cw
307 Slow2go cw
308 Lopan nw
309 Mot cw
310 Mot cw
311 Mot cw
312 Lyubo Yanev nw
313 djozz nw
314 djozz nw
315 strayz np
316 theoldbill nw
317 banker cw
318 southland cw
319 southland cw
320 southland nw
321 southland nw
322 GioLight nw
323 CrashOne cw
324 netjrb nw
325 netjrb nw
326 netjrb nw
327 andyz nw
328 texas shooter nw
329 texas shooter nw
330 texas shooter nw
331
Yeah, you need an electronic switch, which this light does not have. Just answering the question of why anyone would want mode memory or find it useful.
Well, I’m in for two anyway, and as long as it goes from lowest to highest, as I think it does, it will still be useful to me, just not quite as interesting. I’m in for your GAW of the heavily modded version of this light as well. Really looking forward to winning that one!
